What is the method for solving vector problems with component form and addition?
  • Context: MHB
  • Thread starter Thread starter Coder74
    Review Vectors
The discussion revolves around solving vector problems using component form and vector addition. Participants explore methods for calculating the magnitude of the vector sum of two vectors given their magnitudes and directions, including the use of trigonometric functions and the Law of Cosines.
  • Homework-related
  • One participant expresses uncertainty about separating vectors into components and solving for x and y, indicating a need for clarification.
  • Another participant provides two methods for finding the magnitude of the vector sum, one using component form with trigonometric functions and the other using the Law of Cosines.
  • Questions arise about how to represent vectors on a graph and how to determine which values correspond to which sides of a triangle.
  • A participant seeks clarification on the use of both sine and cosine in the calculations, expressing confusion about the application of trigonometric functions in this context.
  • There is a discussion about the conditions under which the Law of Cosines can be applied, specifically when two sides and the included angle of a triangle are known.
Participants do not reach a consensus on all aspects of the problem, as there are ongoing questions and clarifications regarding the methods and reasoning behind vector addition and the use of trigonometric functions.
Some participants express confusion about the application of trigonometric functions in vector addition, particularly regarding the simultaneous use of sine and cosine. There are also references to specific angles and their implications for calculations, which may depend on the context of the problem.
Coder74
Hi everyone, I am taking my finals next week and I am really excited. But I forgot how to solve problems like these I know I'm supposed to separate them and solve for x and y separately but its still not ringing any bells.
Vector L is 303m long in a 205* direction. Vector M is 5552 m long in a 105* direction.
Find the magnitude of their vector sumx=303 + 5552
y= 205+105
^ Am I on the right track so far?
Thanks so much for the help!
Here are two ways I know of to find the magnitude of the vector sum. The first is by vector addition, so let's write:
$$\vec{L}=303\left\langle \cos\left(205^{\circ}\right),\sin\left(205^{\circ}\right) \right\rangle$$
$$\vec{M}=5552\left\langle \cos\left(105^{\circ}\right),\sin\left(105^{\circ}\right) \right\rangle$$
And so the vector sum $\vec{S}$ is:
$$\vec{S}=\left\langle 303\cos\left(205^{\circ}\right)+5552\cos\left(105^{\circ}\right),303\sin\left(205^{\circ}\right)+5552\sin\left(105^{\circ}\right) \right\rangle$$
And thus, the magnitude of the sum (in m) is:
$$\left|\vec{S}\right|=\sqrt{\left(303\cos\left(205^{\circ}\right)+5552\cos\left(105^{\circ}\right)\right)^2+\left(303\sin\left(205^{\circ}\right)+5552\sin\left(105^{\circ}\right)\right)^2}\approx5507.47415994496$$
The other approach is to draw a diagram and then use the Law of Cosines like this:
$$\left|\vec{S}\right|=\sqrt{303^2+5552^2-2\cdot303\cdot5552\cos\left(80^{\circ}\right)}\approx5507.47415994496$$
Thanks, Mark!
If I were to put this on a graph(triangle) how would I know which number goes on the corresponding side? How did you figure out that we needed to use cos to solve the answer?
I really appreciate the help! :D
Coder74 said:
Thanks, Mark!
Each vector has a magnitude and a direction...you have to match those up. :D
When you know two sides of a triangle and the angle they subtend, then the Law of Cosines will give you the length of the unknown side. :D
Thank you Mark,
I took my finals today and as it turns out since there were new students coming in for the late semester, they took off most of the material from the beginning of the year.. So this wasn't on the test.. But I'm still confused. Earlier when you were solving like this
And so the vector sum S⃗ S→ is:
=⟨303cos(205∘)+5552cos(105∘),303sin(205∘)+5552sin(105∘)⟩S→=⟨303cos⁡(205∘)+5552cos⁡(105∘),303sin⁡(205∘)+5552sin⁡(105∘)⟩
S =(303cos(205∘)+5552cos(105∘))2+(303sin(205∘)+5552sin(105∘))2−−−−−−−−−−−−−−−−−−−−−−−−−−−−−−−−−−−−−−−−−−−−−−−−−−−−−−√≈5507.47415994496|S→|=(303cos⁡(205∘)+5552cos⁡(105∘))2+(303sin⁡(205∘)+5552sin⁡(105∘))2≈5507.47415994496I think I understand why you used cos, but I thought only 1 of the trig functions were applicable per equation. Why are you using sin and how come there are two of the same values in the same line? (I apologize if my questions seem repetitive.. I really want to grasp this to perfection so I could know this for the future and help anyone else having trouble with it) I really appreciate you taking the time to help me. It means a lot
If we know the magnitude $M$ of a vector $\vec{v}$, and the direction $\theta$ in which it points, then we may express the vector in component form as:
$$\vec{v}=M\left\langle \cos(\theta),\sin(\theta) \right\rangle$$
And when adding vectors, we can sum the components to get the resultant vector:
$$\vec{v_1}+\vec{v_2}=M_1\left\langle \cos(\theta_1),\sin(\theta_1) \right\rangle+M_2\left\langle \cos(\theta_2),\sin(\theta_2) \right\rangle=\left\langle M_1\cos(\theta_1)+M_2\cos(\theta_2),M_1\sin(\theta_1)+M_2\sin(\theta_2) \right\rangle$$
  • · Replies 43 ·
