Chemistry What is the Molecular Formula of Gallium Oxide from 1.25g Ga and 1.68g GaxOy?
  • Thread starter Thread starter kidvideo90
    Formula Molecular
To determine the molecular formula of gallium oxide (GaxOy) from 1.25g of gallium and 1.68g of GaxOy, first calculate the moles of gallium by dividing its mass by its molar mass (69.72 g/mol). Next, find the mass of oxygen in the compound by subtracting the mass of gallium from the total mass of GaxOy, which is 1.68g. Convert this mass of oxygen to moles using its molar mass (16.00 g/mol). Finally, the ratio of moles of gallium to moles of oxygen will provide the empirical formula for gallium oxide. Understanding these calculations is essential for solving the problem accurately.
kidvideo90
The question is as follows:
Gallium Oxide GaxOy forms when gallium is combined with oxygen. Suppose you allow
1.25 grams of gallium (Ga) to react with O2 and obtain 1.68 g of GaxOy. What is the formula of the product?
Can you explain how to solve this problem any help is appreciated, thank you.
What mass of th e1.68g of GaxOy comes from gallium? How many moles does that correspond to? How much of the mass comes from oxygen? How many moles of oxygen atoms does that correspond to?
Thank you for the help but can you please explain how to start it off fully, I tried to solve it but messed something up and got an answer that was not even close to the actual. As long as you explain how to start it off I should be able to do the rest myself. Thank you
Someone please help this is important work:(
Follow precisely Ygg steps. Write here what you did, and we will help you straighten things out.
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
9K
