What is the Moment Generating Function and How is it Used in Probability?
  • Thread starter Thread starter exitwound
    Functions Moment
4 replies · 5K views · last reply
exitwound
I haven't taken math for going on 13 years and I am having a hard time following what this all means. I'm not sure if I'm doing it right.
First of all, can anyone explain to me in English what exactly the Moment Generating Function is? The book does a poor job at it and the teacher wasn't very clear either. In fact, the book *never* says what it is at all, just how it's used.
If you toss a fair die with outcome X, p(x) = 1/6 for x=1,2,3,4,5,6. Find Mx(t).
[tex]M_x(t) = E(e^{tx}) = \sum_{x\in D}e^{tx}p(x)[/tex]
If we start with the Expectation equation above:
[tex]\sum_{x\in D}e^{tx}p(x) = \sum_{x=1}^6 e^{tx}(1/6)[/tex]
[tex]= e^{t\cdot 0}(1/6) + e^{t\cdot 1}(1/6) + e^{t\cdot 2}(1/6) + ... e^{t\cdot 6}(1/6)[/tex]
[tex]= 1 + \frac{e^t}{6} + \frac{e^{2t}}{6} + \frac{e^{3t}}{6} + \frac{e^{4t}}{6} + \frac{e^{5t}}{6} + \frac{e^{6t}}{6}[/tex]
First of all, is this correct so far? And if it is, since it's been umteen years since I've had algebra, what happens here? How can this be simplified?
Why do you start your sum with
[tex] e^{t\cdot 0}[/tex]
when none of the sides have 0 dots? Other than that your initial setup is fine. As for simplifying,
*notice a factor common to the sum of 6 terms, and factor it out
*how would you simplify the geometric sum [tex]1 + a +a^2 + a^3 + a^4 + a^5[/tex]
I'm not sure the simplified form is much less awkward than the original form.
The one in the beginning shouldn't be there because x=0 isn't a possible outcome of rolling a die.
The idea of a moment generating function is that if you write it out as a power series in t, the coefficient of [itex]t^n[/tex] is the nth moment divided by n!.<br /> <br /> To simplify your expression, note that if [itex]r=e^t[/tex], your moment generating function is<br /> <br /> [tex]M=(1/6)(r+r^2+r^3+r^4+r^5+r^6)[/tex]<br /> <br /> Use the formula for the partial sum of a geometric series to get it in closed form.[/itex][/itex]
You're right about the 0 sides on a die. My mistake on that one.
As for "using the formula for the partial sum of a geometric series to get it in closed form", that's speaking MoonMan. I haven't had geometric series in over a decade. I'll have to do some digging. Ugh.
Also, I don't know what you mean by:
The idea of a moment generating function is that if you write it out as a power series in t, the coefficient of is the nth moment divided by n!.
To be completely honest, I don't even know what t is. I'm not a math major and the language is mostly foreign to me.
If you expand the exponential as a Maclaurin series, you get
[tex]M_x(t) = E(e^{tx}) = E\left[1+tx+\frac{1}{2!}(tx)^2+\frac{1}{3!}(tx)^3+\hdots\right]=E(1)+E(x)t+E(x^2)(t^2/2!)+E(x^3)(t^3/3!)+\hdots[/tex]
So you can each term is proportional to a moment of x. If you have M(t), you can find the nth moment using the formula
[tex]E(x^n)=\left \frac{d^nM}{dt^n}\right|_{t=0}[/tex]
I don't know of an intuitive interpretation of what t is. I just view it as a bookkeeping device.
