What is the notation for angular distance travelled?
The notation for angular distance traveled by an object in circular motion is often represented as θ(t), defined as the total radians traveled from an initial angle θ0. Depending on the context, θ(t) can be constrained within the range of [-2π + θ0, 2π - θ0] if measuring from the origin, or simply within [-2π, 2π] if not. If θ(t) exceeds these bounds, it represents the total angle traveled over time t. While θ is commonly used, any variable can be employed as long as it is clearly defined. The discussion emphasizes the flexibility in notation, with θ and φ being the most typical choices for angles.
AlbertE97
What is the notation for the angular distance traveled by an object moving in circular motion?
s is for regular distance (m,ft,inches, etc.).
What I want is some x to be the distance in either degrees or radians.
How should I call that x?
I would just use ##\theta(t)## and defined it as the total amount of radians that the object has traveled. In your case of circular motion, I would have it be that angle away from its original starting point, ##\theta_0## if ##\theta(t) \in [-2\pi+\theta_0\leq\theta(t)\leq 2\pi-\theta_0 ]##. Only include the ##\theta_0## if you are measuring the angle from the origin. If you aren't, and you're measuring the angle from ##\theta_0##,it's just ##[-2\pi\leq\theta(t)\leq2\pi]##
BUT
If ##\theta(t)\notin [-2\pi+\theta_0\leq\theta(t)\leq 2\pi-\theta_0]##which means your not restricting it to one full revolution, than I would say it is the ##\textbf{TOTAL}## angle traveled by the object in time t. The comment about ##\theta_0## being included or not from above applies here as well. (The part about measuring from the origin or ##\theta_0##)
Does that answer your question adequately?
It'll suffice. We'll see if anyone has seen different notation though.
You can really use any notation you want, as long as you define what you're doing. For example I could use any of the following ( or anything else, really) for what we are describing, as long as It's stated somewhere.
\phi(t)\\
\pi(t)\\
\epsilon(t)\\
\zeta(t)\\
A(t)\\
Q(t)\\
\eta(t)\\
\text{etc.,}
But I don't think that's what you mean. Typically for angles you usually see either ##\phi\\ \text{or}\\ \theta##, which are known as phi and theta, as you may know.
This may help:
Likes AlbertE97
I do not have a good working knowledge of physics yet. I tried to piece this together but after researching this, I couldn’t figure out the correct laws of physics to combine to develop a formula to answer this question. Ex. 1 - A moving object impacts a static object at a constant velocity. Ex. 2 - A moving object impacts a static object at the same velocity but is accelerating at the moment of impact. Assuming the mass of the objects is the same and the velocity at the moment of impact...
  • · Replies 17 ·
  • · Replies 27 ·
9K
