What is the Optimal Water Flow Rate for Designing a Helical Coil Heat Exchanger?
The discussion focuses on designing a helical coil heat exchanger, emphasizing the importance of conducting an energy balance to determine the heat rate. Participants clarify that helical flow heat exchangers function as true counter-current exchangers, similar to shell and tube designs. The specific application involves a coil placed on ice, raising questions about the effectiveness of heat transfer in different setups, such as using an ice and water bath versus just ice. The need to establish the optimal water flow rate is highlighted as crucial for achieving the desired cooling effect. Ultimately, determining the number of turns in the coil is essential for maximizing heat exchange efficiency.
Davian Francis
really need help in designing a helical coil HE. i know i must first do an energy balance to find heat rate.but what next?to find the area needed and the number of turns etc
Helical flow heat exchangers with tubes are true counter-current exchangers and can be calculated the same as a shell and tube exchanger with one shell pass and one tube pass with the shell-side flow parallel with the tubes. Now, if you mean a spiral exchanger like this:
http://www.tranter.com/Pages/products/spiral/description-benefits.aspx
it's usually easiest to contact the vendor.
Hey thanks for replying. But i was talking about a coil with one inlet one outlet..it will be placed on ice in an ice room, so exit water can be cold.
Do you mean in an ice and water bath (good heat transfer, easy to calculate) or just buried in ice with no water (not so much)?
The coil will just be on ice basically. Room temperature water flows through the coil. So basically a need to determine the amount a turns and so forth to get the water cold.
Okay, what's your water flow rate?
Thread 'I need a concave mirror with a focal length length of 150 feet'
I need to cut down a 3 year old dead tree from top down so tree causes no damage with small pieces falling. I need a mirror with a focal length of 150 ft. 12" diameter to 36" diameter will work good but I can't think of any easy way to build it. Nothing like this for sale on Ebay. I have a 30" Fresnel lens that I use to burn stumps it works great. Tree service wants $2000.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
