What is the PDE for photons proposed by Bialynicki-Birula?
The discussion revolves around the search for a suitable partial differential equation (PDE) for photons, particularly in the context of the Schrödinger equation and its applicability to massless particles. Participants explore various theoretical frameworks and interpretations related to the behavior of photons in quantum mechanics, including connections to classical electromagnetism and relativistic quantum theories.
  • Some participants assert that the Schrödinger equation cannot be applied to photons due to the absence of rest mass, as noted by the presence of mass in the equation's formulation.
  • Others propose that the wave equation for the four-potential \( A^\mu \) serves as an equivalent to the Schrödinger equation for photons, representing the zero mass limit of the Klein-Gordon equation.
  • A participant mentions that while a relativistic Schrödinger equation can be formulated, it faces issues related to locality and causality, which complicate its use for photons.
  • There is a suggestion that a Schrödinger equation can be constructed for systems involving both matter and photons, incorporating terms for interactions and free photons.
  • Some participants express skepticism about the connection between the Schrödinger equation and Maxwell's equations, indicating a perceived lack of coherence in the literature.
  • One participant references the work of Bialynicki-Birula, suggesting that there are attempts to define a PDE for photons that may provide insights into this issue.
Participants generally do not agree on the applicability of the Schrödinger equation to photons, with multiple competing views on how to approach the problem. The discussion remains unresolved regarding the best framework for describing photons within quantum mechanics.
Participants highlight limitations in the existing literature regarding the connection between different equations and the treatment of massless particles. There are unresolved issues concerning the transition from classical to quantum descriptions and the implications of using various theoretical models.
This discussion may be of interest to those studying quantum mechanics, particularly in the context of relativistic particles, as well as researchers exploring the foundations of quantum field theory and the behavior of photons.
birulami
Neither in Sam Treiman's http://books.google.de/books?id=e7fmufgvE-kC" I was able to find the Schrödinger equation for a photon, i.e. a particle without rest mass. The Schrödinger equation straight from Treiman's book (typos are mine, if any)
[tex]-\frac{\hbar^2}{2m}\Delta\Psi + V\Psi = i\hbar\frac{\partial\Psi}{\partial t}[/tex]​
with potential [itex]V[/itex] and the Laplace-Operator [itex]\Delta[/itex] applied for all coordinates except [itex]t[/itex], does contain the (rest)mass [itex]m[/itex] in the denominator, so I guess this won't work for the photon.
How then does the equation look like to cover massless particles? Or does it not apply?
Thanks,
Harald.
You are not going to find the Shrodinger equation for photon anywhere in literature. Check my responses #95 and #96 in the thread What really is a photon?
The wave equation for A^\mu is the equivalent SE for a photon, with A^\mu being considered the wave function of the photon. It is the zero mass limit of the Klein Gordon equation. This interpretation is in the literature.
birulami said:
The Schrödinger equation [...] does contain the (rest)mass [itex]m[/itex] in the denominator, so I guess this won't work for the photon.
Note that the photon is highly relativistic, and the Schrödinger equation is non-relativistic. The SE contains the classical definition of kinetic energy, translated into operator form:
[tex]K = \frac{1}{2}mv^2 = \frac{p^2}{2m} \rightarrow \frac {1}{2m} \left( -i \hbar \frac{\partial}{\partial x} \right)^2 = - \frac{\hbar^2}{2m} \frac {\partial^2}{\partial x^2}[/tex]
(in one dimension)
Autsch. I wondered already why in one part of a book I find Maxwell's equations and a description of the photon, and in other parts of a books I find the Schrödinger equation. But a connection between the two is suspiciously absent.
Too bad.
Harald.
Come on now. We can certainly write down a Schrödinger equation for a system composed of matter and photons (in Columb gauge to be specific).
\frac{i\partial}{\partial t}|\Psi> = H |\Psi>
H = H_{\rm matter} + H_{\rm free photon} + H_{\rm interaction}
H_{\rm free photon} = \sum_{k,j}a^{\dagger}_{k,j}a_{k,j} c \hbar k
where c is the speed of light and k is the wave-vector and j is one of two polarizations. And \Psi is some god-awful wavefunction.
(sorry for not putting TeX wrappers around the TeX... my TeX comes out completely different from what I wrote when I do that. Anyone else have this problem?)
Klein-Gordon equation is not a consistent generalization of the non-relativistic Shrodinger equation. The second order (in respect to time) PDE does not become first order PDE in the low energy limit. Classical fields do not become quantum mechanical wave functions either, since they usually have different dimensions.
With the photon these problems are not so obvious because there is no non-relativistic limit anyway, but the fundamental problem with relativistic quantum theory is still there.
We can write down a relativistic SE easily as
[tex] i\partial_t \Psi = \sqrt{-\nabla^2 + m^2}\Psi[/tex]
and it is easy to substitute m=0 also and get
[tex] i\partial_t \Psi = \sqrt{-\nabla^2}\Psi[/tex]
but the mainstream story goes on so, that having found the relativistic SE, we next notice that it cannot be used for some locality and causality related reasons.
Working in momentum space is closer to hiding the problem than solving it. You wouldn't bother transforming this into the position representation?
Not now, but I remember having some problem like this once. I think I just edited it until it started working. Like through deleting and rewriting.
hmhmh... or did this happen before I had understood that one has to reload the page once after editing the equations in order to see the correctly? I'm not sure...
Nah, I'm happy with that Hamiltonian the way it is.
I'm interested in practical things such as calculating scattering amplitudes for x-ray experiments, so I do just fine in momentum space, thank you very much.
I saw an interesting attempt to find PDE for photons made by Polish physicist Bialynicki-Birula:
http://www.cft.edu.pl/~birula/publ/APPPwf.pdf
http://www.cft.edu.pl/~birula/publ/reconstr.tex
http://www.cft.edu.pl/~birula/publ/CQO7.pdf
  • · Replies 17 ·
  • · Replies 21 ·
