What is the polarization of a virtual photon
The discussion centers on the polarization of virtual photons, exploring whether they possess longitudinal polarization, transverse polarization, or both. The context includes theoretical considerations in quantum electrodynamics (QED) and implications for modeling electromagnetic fields in specific geometries, such as 1D cavities or waveguides.
  • Some participants note that there are conflicting views on whether virtual photons have only longitudinal polarization or both transverse and longitudinal polarizations.
  • One participant explains that virtual photons are mathematical constructs in perturbation theory and discusses the implications of different gauges on the photon propagator, highlighting that in Feynman gauge, there appear to be four components, while in Landau gauge, there are three components.
  • Another participant references Richard Feynman's work, suggesting that non-transverse polarization components are relevant for Coulombic interactions and questions the validity of considering only longitudinal polarization in specific scenarios.
  • There is a suggestion that in the Coulomb gauge, one can focus on the physical degrees of freedom, implying that this may allow for the consideration of a single polarization component in certain contexts.
Participants express differing views on the nature of virtual photon polarization, with no consensus reached on whether only longitudinal polarization can be considered in specific applications. The discussion remains unresolved regarding the implications of gauge choices and the physical relevance of different polarization components.
Limitations include the dependence on gauge choices and the mathematical framework used to describe virtual photons, which may affect interpretations of their polarization properties.
maxdil
I read in few places that the virtual photons have longitudinal polarization while in some papers they say virtual photons have both transverse and longitudinal polarizations.
Can anyone please help me to understand this
Virtual photons are not real photons. They are just mathematical building blocks in the perturbative evaluation of S-matrix elements. The internal lines of Feynman diagrams do not represent photons or particles but the propagator of the quantum field (in the vacuum case the socalled Feynman propagator of perturbation theory, i.e., the vacuum expectation value of the time-ordered connected two-point field-correlation function).
Depending on the gauge the propgator can have four-longitudinal components. E.g., in Feynman gauge, which is the most convenient one for perturbative calculations, Feynman propagator for photons reads
$$\Delta_{\mu \nu}(p)=-\frac{g^{\mu \nu}}{p^2 + \mathrm{i} 0^+}.$$
There you seemingly have four components.
In Landau gauge your photon propagator is made four-transverse
$$\Delta_{\mu \nu} (p)=-\left ( g^{\mu \nu} - \frac{p^{\mu} p^{\nu}}{p^2 + \mathrm{i} 0^+} \right) \frac{1}{p^2+\mathrm{i} 0^+}.$$
Here you seemingly have 3 components (two 3-transverse and one 3-longitudinal).
These would-be degrees of freedom are not all observable, because you can only make sense of asymptotic free states in terms of observable objects, and here gauge invariance comes to the rescue! For on-shell S-matrix elements finally only the two physical 3-transverse field-degrees of freedom of the quantized electromagnetic field contribute. The unphysical degrees of freedom in the one or the other gauge are cancelling out. In the Abelian case as is QED, current conservation is necessary and sufficient for this cancellation, which is formally encoded in the so-called Ward-Takahashi identities for the proper vertex functions and the connected Green's functions. In non-Abelian gauge theories you need also Faddeev-Popov ghosts (and for Higgsed models also the would-be Goldstone modes in non-unitary gauges) to make this cancellation happen. Here, the Slavnov-Taylor identities substitute the Ward-Takahashi identies of the Abelian case. An exception is the socalled Background-Field Gauge, where the simple Ward-Takahashi identities become available again, and that simplifies the proof of the (perturbative) renormalizability of non-Abelian gauge theories considerably.
maxdil said:
I read in few places...
Where exactly? You will get better and more helpful answers if you provide the source of the statements that you need help with (and providing sources is a PhysicsForums rule).
Thank for the replies.
I found about photon polarization in Richard Feynman's book "The Theory of Fundamental Processes" chapter 20. It provides the fact that, coulombic interactions are due to the non-transverse polarization components. However I am trying to modify the EM field in a 1D cavity/1D wave guide based on QED and wondering whether it is reasonable to consider only one (longitudinal) polarization of the virtual photon.
I guess that's in the Coulomb gauge. As I said, at the end you are left with the physical degrees of freedom!
@vanhees71: "at the end you are left with the physical degrees of freedom" ,so does that mean we can consider one polarization component of the virtual photon in 1D wave guide/1D cavity? Thanks
  • · Replies 36 ·
  • · Replies 29 ·
  • · Replies 41 ·
  • · Replies 16 ·
