What is the polarization of a virtual photon
maxdil
I read in few places that the virtual photons have longitudinal polarization while in some papers they say virtual photons have both transverse and longitudinal polarizations.
Can anyone please help me to understand this
Virtual photons are not real photons. They are just mathematical building blocks in the perturbative evaluation of S-matrix elements. The internal lines of Feynman diagrams do not represent photons or particles but the propagator of the quantum field (in the vacuum case the socalled Feynman propagator of perturbation theory, i.e., the vacuum expectation value of the time-ordered connected two-point field-correlation function).
Depending on the gauge the propgator can have four-longitudinal components. E.g., in Feynman gauge, which is the most convenient one for perturbative calculations, Feynman propagator for photons reads
$$\Delta_{\mu \nu}(p)=-\frac{g^{\mu \nu}}{p^2 + \mathrm{i} 0^+}.$$
There you seemingly have four components.
In Landau gauge your photon propagator is made four-transverse
$$\Delta_{\mu \nu} (p)=-\left ( g^{\mu \nu} - \frac{p^{\mu} p^{\nu}}{p^2 + \mathrm{i} 0^+} \right) \frac{1}{p^2+\mathrm{i} 0^+}.$$
Here you seemingly have 3 components (two 3-transverse and one 3-longitudinal).
These would-be degrees of freedom are not all observable, because you can only make sense of asymptotic free states in terms of observable objects, and here gauge invariance comes to the rescue! For on-shell S-matrix elements finally only the two physical 3-transverse field-degrees of freedom of the quantized electromagnetic field contribute. The unphysical degrees of freedom in the one or the other gauge are cancelling out. In the Abelian case as is QED, current conservation is necessary and sufficient for this cancellation, which is formally encoded in the so-called Ward-Takahashi identities for the proper vertex functions and the connected Green's functions. In non-Abelian gauge theories you need also Faddeev-Popov ghosts (and for Higgsed models also the would-be Goldstone modes in non-unitary gauges) to make this cancellation happen. Here, the Slavnov-Taylor identities substitute the Ward-Takahashi identies of the Abelian case. An exception is the socalled Background-Field Gauge, where the simple Ward-Takahashi identities become available again, and that simplifies the proof of the (perturbative) renormalizability of non-Abelian gauge theories considerably.
Likes maxdil
maxdil said:
I read in few places...
Where exactly? You will get better and more helpful answers if you provide the source of the statements that you need help with (and providing sources is a PhysicsForums rule).
Likes maxdil
Thank for the replies.
I found about photon polarization in Richard Feynman's book "The Theory of Fundamental Processes" chapter 20. It provides the fact that, coulombic interactions are due to the non-transverse polarization components. However I am trying to modify the EM field in a 1D cavity/1D wave guide based on QED and wondering whether it is reasonable to consider only one (longitudinal) polarization of the virtual photon.
I guess that's in the Coulomb gauge. As I said, at the end you are left with the physical degrees of freedom!
Likes maxdil
@vanhees71: "at the end you are left with the physical degrees of freedom" ,so does that mean we can consider one polarization component of the virtual photon in 1D wave guide/1D cavity? Thanks
Not an expert in QM. AFAIK, Schrödinger's equation is quite different from the classical wave equation. The former is an equation for the dynamics of the state of a (quantum?) system, the latter is an equation for the dynamics of a (classical) degree of freedom. As a matter of fact, Schrödinger's equation is first order in time derivatives, while the classical wave equation is second order. But, AFAIK, Schrödinger's equation is a wave equation; only its interpretation makes it non-classical...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
Is it possible, and fruitful, to use certain conceptual and technical tools from effective field theory (coarse-graining/integrating-out, power-counting, matching, RG) to think about the relationship between the fundamental (quantum) and the emergent (classical), both to account for the quasi-autonomy of the classical level and to quantify residual quantum corrections? By “emergent,” I mean the following: after integrating out fast/irrelevant quantum degrees of freedom (high-energy modes...
