What Is the Potential Difference When a Proton's Speed Increases?
7 replies · 7K views
suldaman
Potential difference question...
A proton (mass = 1.67 10-27 kg, charge = 1.60 10-19 C) moves from point A to point B under the influence of an electrostatic force only. At point A the proton moves with a speed of 60 km/s. At point B the speed of the proton is 80 km/s. Determine the potential difference Image .
Vb-Va = 0
a) +15v
b) -15V
c) -33V
d) +33V
e) -20V
im stumped with this one...any help would be appreciated.
delE = q(delV)
OR
Change in E(energy) = charge*change in V(potential)
for starters
actually, I don't get near any of the answers there. Don't take my word for it, let me look into it more
ok, I did get within .4 of one of the answers there (i wasn't paying attention to units when I calculated last time)
so that way should work, methinx.
i get within .4 of the answers a well
i guess they want you to round them off
now decide which is right... a or b
if you did it right, you should get either a or b, not both. They are 30 units apart.
I get point b about -14.6 volts relative to point a. Can't tell from the question whether that means answer a or b is correct. Probably b :rolleyes:
I didn't bother doing any calculations, but I can tell you the sign of the answer. Think of it this way: the final velocity was greater than the initial velocity, right? So the particle's kinetic energy increased. It moved under the influence of a conservative force solely, so the increase in kinetic energy came at the expense of a(n) ______________(increase/decrease) in potential energy. As a result, considering that the charge is positive, its final electric potential is ______________ (larger/smaller) than its initial electric potential. Therefore, the change in electric potential between the two points (final minus initial) is ______________ (positive/negative).
Fill in the blanks...:-p :devil:
