What is the purpose of adding 'class' before enum declarations?
  • Thread starter Thread starter dE_logics
11 replies · 3K views
dE_logics
An example of enum -
enum class {a = 64, b, c, d}
even if I -
enum {a = 64, b, c, d}
I will get the same results.
Printing class returns an error...so I was wondering what's the use of this name given before the actual declaration of the elements (in braces)...or in this example, what's the use of 'class'?
I think it makes the declarations more manageable...nothing more.
Edit: And yes, everything in c.
(You're talking about C, I assume?)
enum defines a new type. You can give this type a name -- in your example, the name is class. (This example wouldn't work in C++)
This is similar, incidentally to a struct declaration -- you need not give a structure type a name when you define it.
So how can I use this custom made type?
An enum is not a custom made type. It's simply a list of values a,b,c,d that all have type unsigned int.
If you want a custom type, that's a struct (or class in C++).
In C, enums are just another integral type -- the practical benefit of naming the type is just to make the your code more clear. e.g.
Code:
enum game_result { win, lose, draw };
game_result play_game(); // Definition elsewhere
static void print_taunt(game_result result)
  if(result == win) { printf("Haha, I won!\n"); }
  if(result == lose) { printf("You got lucky.\n"); }
  if(result == draw) { printf("Nyah nyah!\n"); }
int main(int, char*[])
  game_result result = play_game();
  print_taunt(result);
So game_results has no significance here...
Yes it does, game_result can only be assigned/compared to another game result - so using it the way hurkly showed stops you assigning any value to game_result that isn't in the list.
With no mane in the enum you can assign/compare the values with any int.
cixelsyd much?
Laptop on couch, broken keyboard (D,Y need hitting hard) and I can't touch type.
Game results has 3 constants -
win, lose, draw with values 1, 2 and 3 respectively.
So what does this statement -
Code:
Do apart from calling the function play_game?
And what does this function take as input -
BTW this is the call -
So what's this game_result doing in the print_taunt function?
Overall...I don't get a thing. :cry:
Code:
It's been too long since you programmed in C, Hurkyl. That won't compile. It would compile if the first line was
Code:
typedef enum { win, lose, draw } game_result;
Code:
That does not call the function play_game. This calls the function play_game:
Code:
For the compiler to make sense of this line, you need to told the compiler earlier in your code that play_game is a function that returns something of type game_result. This line does just that:
Code:
To make sense of this function declaration statement, even earlier in your code you need to have told the compiler that game_result is a new type. Something like
Code:
It obviously takes a variable of type game_result as input.
I guess I'll do it later on...thanks everyone!
