What is the Python syntax for checking if a number is a palindrome?
  • Context: Python
  • Thread starter Thread starter mslate
    Python Recursion
The discussion revolves around finding the Python syntax for checking if a number is a palindrome, particularly in the context of solving a Project Euler problem that involves identifying the largest palindrome made from the product of two 3-digit numbers. Participants share code snippets, offer suggestions, and discuss the merits of different programming approaches.
  • One participant shares a recursive approach to check for palindromes but expresses concern about potential memory issues due to recursion depth.
  • Another participant suggests that Python does not handle recursion well and mentions an alternative approach using loops, noting issues with the original code such as string index errors.
  • A different participant provides a concise, iterative solution that checks for palindromes without using recursion, emphasizing readability and efficiency.
  • Some participants discuss the appropriateness of sharing complete solutions to Project Euler problems, with mixed opinions on whether it is acceptable.
  • Questions arise regarding specific Python syntax, particularly the string reversal technique using "str(n)[::-1]", with explanations provided about how it works.
Participants express differing views on the use of recursion in Python, with some advocating for iterative solutions instead. There is no consensus on whether full solutions to Project Euler problems should be shared, as opinions vary on the triviality of the problem and the appropriateness of providing complete answers.
Some participants note limitations in the original recursive approach, including potential infinite loops and the need for clearer boundaries in the problem's range of values. There are unresolved concerns about the efficiency and readability of the provided code snippets.
This discussion may be useful for individuals interested in Python programming, particularly those looking to understand palindrome checking techniques and the implications of recursion versus iteration in coding practices.
mslate
I'm doing the http://projecteuler.net/" problems for garbages and giggles, and was working on problem 4 which requires finding the largest number palindrome (e.g. 10301, 54345) that is the product of two 3-digit numbers.
Below is my code, and I'm pretty sure Python will reproduce the error that I'm getting if you try it. I'm using recursion to search backwards from the product of 999 x 999, stopping at 100 x 100. I'm not very familiar with Python or programming, but I suspect that the problem's arising from the recursive calls spinning out of control and taking up too much memory. Any ideas?
Code:
# Project Euler no. 4
# Find the largest palindrome made from the product of two 3-digit numbers
def checkPalindrome(num1,num2):
	prod=str(num1*num2)
	i=0
	l=len(prod)
	print num1, num2
	# prevents infinite loop by stopping recursion beyond checking 3-digit numbers
	if (len(str(num1))!=3 | len(str(num2))!=3):
		return 0,0
	# even
	if l%2==0:
		while (1):
			if prod[i]!=prod[-i-1]:
				a1,b1=checkPalindrome(num1,num2-1)
				prod1=a1*b1
				a2,b2=checkPalindrome(num1-1,num2-1)
				prod2=a2*b2
				return (a1,b1) if prod1 > prod2 else (a2,b2)
			if i==l/2:				# checked palindrome w/o error--is a palindrome
				return num1, num2
			i+=1
	else: #odd
		while (1):
				a1,b1 = checkPalindrome(num1,num2-1)
				prod1 = a1 * b1
				a2,b2 = checkPalindrome(num1-1,num2-1)
				prod2 = a2 * b2
			if i > l/2:    	# checked palindrome w/o error--is a palindrome
				return num1, num2
			i+=1
	return 0,0
if __name__=="__main__":
	a=999
	b=999
	print "Checking palindrome for 3-digit products..."
	num1,num2=checkPalindrome(a,b)
	print "The largest palindrome made from the product of two 3-digit" \
		" numbers is %d and results from the product of " \
		"%d and %d" % num1*num2, num1, num2
Technology news on Phys.org
I've got an event to attend in ~10 minutes, but I'll look at your code when I get home.
It's worth noting, however, that Python doesn't handle recursion well (at least, as far as I remember; I've since started using Haskell and Scheme). This isn't surprising, given Guido's hostility to functional programming (IIRC, he dislikes lambda expressions and map/reduce/filter, so it doesn't surprise me that he'd prefer imperative looping over recursion).
That being said, I got your program to stop displaying an error about recursion depth (check out sys.setrecursiondepth(); the default value is 1000), but when I did something else broke (one of your string indices was out of range). I'm skeptical about the approach used here anyway, but I can't say for sure without looking at it some more.
Hang tight, and I'll get back to you a little later today.
I hacked this up in about 5 minutes. It's a 15 line solution that takes about 1-1.5 seconds. It attempts no optimization or anything, but it's easy to read and runs fast enough.
Code:
def is_palindrome(n):
    return str(n) == str(n)[::-1]
def euler_four():
    highest = 1
    for x in xrange(100, 1000):
        for y in xrange(100, 1000):
            if is_palindrome(x*y) and x*y > highest:
                highest = x * y
    return highest
def main():
    print euler_four()
main()
Tips for your code:
- Recursion is not your friend in Python. Use a loop.
- while(1) is disgusting. Don't do that unless you absolutely have to. Remember that in Python, if you're going to do that, True == 1, and while(True) is a lot easier to read. But you really shouldn't have to do this all that often.
- You can check all n digit products by checking in the range [10^(n-1), 10^n) (for a product, you obviously have to loop this twice). Using a string is nasty and makes your code harder to read.
- Your two while loops contain code that is exactly the same. You could probably use a function to abstract something here.
- If you find yourself writing "# prevents infinite loop by stopping recursion beyond checking 3-digit numbers", then that should tell you something is wrong. 99.99999999% of the time, you should have a clear idea of what range of values you need to loop over. That is, you can easily set a boundary for this problem and check within that (as I explained above) without having to use an infinite loop.
If you have any questions, or feel that I made a mistake (I probably did), please let me know.
EDIT: Code inside spoiler tags does not work.
Thank you for the concise answer and style advice--your code certainly looks nicer :) I'll take the looping advice to heart
You are not supposed to give out full solutions to Project Euler problems. Please remove it.
Tell that to http://en.wikipedia.org/wiki/Project_Euler" .
It's a trivial problem anyway...
Agreed!
I've got one simple question about the Python code though. For most part Python seems quite readable (a bit like Pascal/Delphi which I'm very familiar with), but one piece of syntax strikes me as a bit odd. Could someone please explain the syntax of the code that apparently implements string reversal, "str(n)[::-1]".
Thanks.
uart said:
Agreed!
Thanks.
str() is called in order to convert the number we passed, "n", to a string. To reference a particular element of a string, we use [] just like we would with a char* in C. However, Python's string index is a little more fancy, and the "[::-1]" reverses the string for us. So the entire line just compares the string of the original number to the string of the original number, reversed. If they're equal, it returns True, and otherwise it returns False.
As for how the index itself works (i.e., what [::-1] actually means), think of the index like so:
[a : b : c]
To get an element "a", we would use myString[a] for short. To get multiple elements within a slice of the string, we'd use myString[a:b]. If we want to pull items in a sequence and skip a fixed number of elements, we would use myString[a:b:c]. We can omit parts of this index to get default values. If we omit a, b and c, we get the whole string. If we just add a c element to the index, we get every cth element of the original string. So, if we wanted every other letter of the string "abcde", we'd do
Code:
"abcde"[::2]
which returns the string "ace". So putting this all together, we pass a value of -1 for our "c" part of the index, which tells Python to walk through the string backwards (as you might guess, calling a string with myString[::1] just returns the original string, so making -1 the reverse just makes the notational logical and convenient).
Hope that helps.
Thanks vcxp, yes I figured out the "str(n)" part it was really just the [::-1] part that baffled me. Your post explains it perfectly. So there is really a lot of string handling syntax effectively built into the index notation.
In Pascal or Delphi the corresponding code would be :
Code:
function IsPalindrome(n : integer) : boolean;
var s : string;
 begin
  str(n,s);
  IsPalindrome := s = ReverseString(s)
 end;
  • · Replies 18 ·
  • · Replies 43 ·
  • · Replies 28 ·
