What is the reason we don't "see" the Universe's expansion?
The discussion centers on why the expansion of the universe is not noticeable in everyday life. It highlights that while the universe is expanding, the rate of this expansion is extremely slow, approximately 2.26 x 10^-12 m/s for a point one meter away. This minuscule rate means that over a human lifetime, the expansion would only result in a change of about 0.00713 meters, making it imperceptible. Additionally, gravitational and intermolecular forces counteract the expansion, preventing objects like the Earth and humans from expanding alongside space. Consequently, the combination of slow expansion and strong forces keeps us from observing the universe's expansion directly.
MBBphys
Ok, so if the universe is expanding, and the scale of space itself is changing, then that means that even humans and the Earth is expanding right?
But is the reason why we don't notice this effect the slowness of it?
So v=Hd, where H is Hubble's constant, which has a value of about 70 kms-1Mpc-1
So if we convert that to ms-1m-1-->it becomes (70000/(3.1x10^16))-->2.26 x 10^-12, that means a point one metre away from me is moving away from me at a speed of 2.26 x 10^-12 ms-1?
So if we take an entire human life to be, say, 100 years-->speed * time=2.26x10^-12 x 100 x 365 x 24 x 60 x 60=0.00713 metres-->is this why we do not "see" the expansion?
V=Hd
(See above)
V=Hd
(See above)
If our rulers are expanding at the same rate as we are expanding, how will we be able to measure any difference? :smile:
V=Hd
(See above)
I think your figures are a bit out. The lifetime expansion per meter is nearer ##6*10^{-9}m##. Which would be hard to detect.
A better example is the Earth's orbit round the Sun. The expansion of space would amount to about ##1km## in a lifetime. But, the Earth and the Sun are gravitationally bound, which means that gravity counteracts the minute expansion and keeps the two in the same orbit.
A more extreme example would be an object sitting on the ground. A slow expansion of space could not counteract gravity and lift it slowly off the ground.
Similarly the intermolecular forces that keep things together prevent you from expanding, even slowly!
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
  • · Replies 49 ·
  • · Replies 23 ·
