What is the relation between unitary group, homotopy?
  • Level: Graduate
  • Thread starter PRB147
    Group Relation
7 replies · 3K views · last reply
PRB147
The O(N) nonlinear sigma model has topological solitons only when N=3 in the
planar geometry. There exists a generalization of the O(3) sigma model so that the
new model possesses topological solitons for arbitrary N in the planar geometry. It is
the CP^{N-1} sigma model,†whose group manifold is
[tex]CP^{N-1}=ƒ U(N)/†[U(1)\bigotimes U(N-1)]‡ =SU(N)/[†U(1)\bigotimes SU(N)\bigotimes SU(N-1)‡][/tex]
The homotopy theorem tells
[tex]\pi_2(CP^{N-1})=Z[/tex]
since [tex]\pi_2(G/H)…=\pi_1(„H)…[/tex] (when G is simply connected) and [tex]\pi_n(„G\bigotimes G')=\pi_n… („G)\bigoplus \pi_n(„G')[/tex]…. It is also called the SU(N) sigma model.
I don't understand the following sentences, what is the meaning of the following math expression?Would anyone gives a more detailed hints to the following sentences:
U(N) seems to be not simply connected.
What sort of mathematical objects are the ##U(N)## and ##SU(N)## items? If they are vector or tensor spaces, the expression with the ##\otimes## symbols can be interpreted as a tensor product.
U(N),SU(N) are unitary and special unitary group respectively
Based on this, I would guess that the ##\otimes## symbol is supposed to indicate semidirect product, which is more usually denoted by ##\rtimes##. The link gives an identification of ##U(1)## with a subgroup of ##U(N)##, and we could use the same principle to identify ##U(N-1)## with a subgroup, viz the group of ##n\times n## matrices formed by adding a row of zeros above and column of zeros to the left of a matrix in ##U(N-1)## and then putting a 1 in the top-left cell. Then we can take the semidirect product of those two subgroups.
Thank you very much, I admire mathematician!
The correct expressions are
##CP^{n-1} = U(n)/(U(n-1)##x##U(1)) = SU(n)/S(U(n-1)##x##U(1))## where x means direct product(not semi direct product) of groups algebraically and Cartesian product topologically.
##\bigotimes## usually means tensor product which in this case is meaningless.
From the long homotopy sequence of the fibration, ##U(1)\rightarrow S^{2n-1}\rightarrow CP^{n-1}## one has
##π_2(S^{2n-1})\rightarrow π_2(CP^{n-1})\rightarrow π_1(U(1)) \rightarrow π_1(S^{2n-1})## it follows that ##π_2(CP^{n-1}) = Z## since the homotopy groups of the 2n-1 sphere are zero below dimension 2n-1 and the fundamental group of the circle is Z.
##SU(n)## is simply connected which can be shown by induction starting with ##SU(1)## which is the trivial group. From the long exact sequence of the fibration,
## S(U(n-1)##x##U(1))\rightarrow SU(n)\rightarrow CP^{n-1}## one has
## π_2(SU(n))\rightarrow π_2(CP^{n-1})\rightarrow Z \rightarrow 0##
You need to show that ## π_2(SU(n))## is zero.
BTW: ##U(n)## is not simply connected. The complex determinant defines a continuous homomorphism from ##U(n)## onto ##U(1)## with kernel ##SU(n)##. Since ##SU(n)## is simply connected, the exact sequence of the fibration shows that ##π_1(U(n)) = Z##.
Lavinia wrote "You need to show that π2(SU(n)) is zero."
It is an interesting fact that for any Lie group G at all, π2(G) = 0. This is a rather deep fact using algebraic topology.
A somewhat simpler fact is that, loosely speaking, a Lie group resembles the cartesian product of odd-dimensional spheres. The precise statement is somewhat technical, but it is an amazing theorem:
The rational cohomology ring H*(G; ℚ) of a Lie group G is the same as the rational cohomology ring of some product of odd-dimensional spheres.
(This is "simpler" in the sense that its proof follows from the easy-to-prove observation that the cohomology ring of a Lie group is a Hopf algebra.)
For some examples:
H*(U(n); ℚ) = H*(S1 × S3 × ... × S2n-1; ℚ)​
H*(SU(n); ℚ) = H*(S3 × S5 × ... × S2n-1; ℚ)​
H*(Sp(n); ℚ) = H*(S3 × S7 × ... × S4n-1; ℚ)​
