What is the Relationship Between Bandwidth and RLC Circuit Parameters?
The discussion revolves around the relationship between bandwidth and the parameters of an RLC circuit, specifically focusing on the derivation of angular frequencies at which the current reaches a certain fraction of its maximum value. Participants are analyzing equations related to impedance and resonance in RLC circuits.
  • Participants explore the derivation of angular frequencies from the impedance equation, questioning the assumptions made about the relationship between current and voltage. There is also discussion about the implications of different roots of the quadratic equation formed during the analysis.
Some participants have provided insights into the nature of the roots derived from the quadratic equation, while others are questioning the validity of certain solutions based on the physical constraints of angular frequency. The conversation reflects an ongoing exploration of the mathematical relationships without reaching a definitive conclusion.
Participants are navigating through the implications of assuming certain values and the physical meaning of negative frequencies in the context of RLC circuits. There is an emphasis on ensuring that the derived frequencies remain positive, aligning with the physical reality of the circuit behavior.
IBY
and
I am trying to get from:
[tex]I_{max}=\sqrt{2}I=\frac{V}{\sqrt{R^2+(\omega L-\frac{1}{\omega C})^2}}[/tex]
to:
[tex]\Delta\omega=\omega_1-\omega_2=\frac{R}{L}[/tex]
From the equation above:
[tex]\sqrt{R^2+(\omega L-\frac{1}{\omega C})^2}=\frac{V}{\sqrt{2}I}[/tex]
Square the above:
[tex]R^2+(\omega L-\frac{1}{\omega C})^2=\frac{V^2}{2I^2}[/tex]
Subtract from both sides R squared and square root:
[tex]\omega L-\frac{1}{\omega C}=\sqrt{\frac{V^2}{2 I^2}-R^2}[/tex]
Now, I want to put it in the form of quadratic equation, so I multiply omega:
[tex]\omega^2 L-\frac{1}{C}=\omega \sqrt{\frac{V^2}{2 I^2}-R^2}[/tex]
Now I am stuck. It is not like I can turn V/I=R because that I there is root square mean current, and even if I did, I would end up with an imaginary term. The answer is not imaginary, nor complex.
What do ω1 and ω2 represent?
They represent the two solutions of angular frequency when the current of the circuit is 1/sqrt(2) of the resonance current (Imax).
The current is resonant when:
[tex]\omega=\frac{1}{\sqrt{LC}}[/tex]
That is because it turns this:
[tex]I=\frac{V}{\sqrt{R^2+(\omega L-\frac{1}{\omega C})^2}}[/tex]
into this:
[tex]I=\frac{V}{R}[/tex]
Okay, I looked further into it, and my mistake was to assume that the first equation was equal to Imax, so instead, I changed it like this:
[tex]\frac{I_{max}}{\sqrt{2}}=I=\frac{V}{\sqrt{R^2+(\omega L-\frac{1}{\omega C})^2}}[/tex]
Doing the same process from above gives me:
[tex]\omega L-\frac{1}{\omega C}=\sqrt{\frac{V^2}{I^2}-R^2}[/tex]
But since I=Imax/sqrt(2), that gives me:
[tex]\omega L-\frac{1}{\omega C}=\sqrt{\frac{2 V^2}{I_{max}^2}-R^2}[/tex]
I can finally turn V/Imax into R:
[tex]\omega L-\frac{1}{\omega C}=\sqrt{2 R^2-R^2}=R[/tex]
I set up the quadratic polynomial:
[tex]\omega^2 L-\frac{1}{C}-\omega R=0[/tex]
And then the formula:
[tex]\omega_1=\frac{R+\sqrt{R^2+4 \frac{L}{C}}}{2L}[/tex]
and
[tex]\omega_2=\frac{R-\sqrt{R^2+4 \frac{L}{C}}}{2L}[/tex]
But now I have another problem. When I subtract both solutions, the R/2L term disappears and that leaves the term in the squareroots.
I didn't actually work this out, but I can see how this works from the original equation for the impedance. You're looking at the wrong two roots. One frequency should satisfy
[tex]\omega L - \frac{1}{\omega C} = +R[/tex]
while the other satisfies
[tex]\omega L - \frac{1}{\omega C} = -R[/tex]
Somewhere along the way, you took a square root, and you need to consider both the positive and negative roots.
Oh right, thanks. One more problem, though, that leaves me with 4 solutions. The two of them is the one mentioned in my last post above, and two of them would be with the Rs in front shifted into negative.
Just to help you visualize the four solutions:
[tex]\omega_2=\frac{-R+\sqrt{R^2+4 \frac{L}{C}}}{2L}[/tex]
[tex]\omega_3=\frac{R-\sqrt{R^2+4 \frac{L}{C}}}{2L}[/tex]
[tex]\omega_4=\frac{-R-\sqrt{R^2+4 \frac{L}{C}}}{2L}[/tex]
The sign on two of those is negative. You can toss those solutions.
I see that if I subtract omega 1 with 2, that gives me the correct solution, but why do I toss out omega 3 and 4, though? Why wasn't the negative R tossed out? It seems completely arbitrary.
In the expression for ω3, is the radical less than or greater than R? Similarly, what's the sign of ω4?
Oh, because in those cases, angular frequency would turn out negative, and there is no such thing. It would turn out negative because R^2 is being added by 4L/C, and since without the 4L/C, the square root term would be R, then that square root term must be greater than the R outside the square root. Thanks!
  • · Replies 21 ·
