What is the relationship between force and velocity in objects in side contact?
  • Context: Undergrad
  • Thread starter Thread starter Entanglement
    Force
The discussion revolves around the relationship between force and velocity in objects that are in side contact, particularly in scenarios where they may be moving at the same velocity. Participants explore concepts related to apparent weight, kinetic energy, and the conditions under which forces are exerted between objects in contact.
  • Some participants propose that if two objects are in side contact and moving at the same velocity, they do not exert a force on each other, likening it to being at rest together.
  • Others argue that even when objects are at rest together, such as a bowling ball on a toe, there is still an applied force due to weight.
  • A participant suggests that in a falling elevator scenario, if both objects are falling at terminal velocity, their energy can be considered as kinetic energy with zero potential energy, and a change in velocity would involve a transfer of kinetic energy to potential energy.
  • Another participant clarifies that the analogy of the elevator was not meant to imply that the objects were in a moving elevator but rather to illustrate the forces at play in different conditions.
  • It is noted that the sum of forces on each object divided by their masses can allow them to remain at relative rest without a force between them, assuming no rotation is involved.
  • One participant questions the assumption that no force exists between the objects, stating that just because they are at the same velocity does not mean one cannot be applying a force to maintain that velocity.
  • The case of free-fall is highlighted as a special scenario where gravity causes objects to fall at the same speed without exerting force on each other.
Participants express differing views on whether forces are exerted between objects in side contact moving at the same velocity. There is no consensus on the conditions under which forces arise or the implications of being at rest together.
Participants reference various conditions, such as free-fall and terminal velocity, which may influence the discussion. The assumptions regarding the nature of contact and motion are not fully resolved.
Entanglement
Hey Everyone,
When I was reading about the apparent weight in an elevator I started to think about something. I think If two objects are in side contact moving at the same velocity, neither of them applies a force on the other, because it's as if they were at rest together. A force doesn't arise unless the further objects moves at a less velocity than the other. I guess this is true but I can't explain it to my myself in a proper way. I have the intuition for it but I'm not able to reach a neat explanation. Can it explained in terms of relative kinetic energy? I'm not sure.
If I put a bowling ball on my toe, they are at rest together. But there is most certainly an applied force exerted.
NewtonsFellow said:
Hey Everyone,
If these are the conditions: the elevator is falling within a gravitational field. If the elevator is falling at terminal velocity and the objects are not moving in the elevator, then the objects are falling at terminal velocity as well.
Then you could say: the energy of both objects is kinetic energy, zero potential energy. If one object slows down and is no longer traveling at terminal velocity, then it has transferred some kinetic energy to potential energy.
I think that works.
Yes, I meant both of them are in contact such that neither of them is exerting its weight on the other.
I think that works.
I never meant that these objects are in a moving elevator. I just wanted to create an analogy by imagining that two objects were in side- contact, and I tried to imagine the force that one would act on the other at different conditions.
It's about the sums of all other forces on each object divided by their masses. If those are the same, they can remain at relative rest without a force between them. Ignoring rotation.
NewtonsFellow said:
Hey Everyone,
Do you mean in free fall or some other speed? To go at any speed other than free-fall, there are non-gravity forces at play on both objects. In general, one object might be transferring some force to the other. You say they are side-by-side, so it sounds like you are stating that they are not applying force on each other. Then it is logically wrong to question if there is force between them, when you stated otherwise as an assumption.
That is wrong. Just because they are at the same velocity doesn't mean that one can't be applying a force to keep the other at that velocity.
PS. The case of free-fall is special. You know that gravity alone will make two objects (in a vacuum) accelerate and fall at the same speed. So there is no force between them. If they were at a non-free-fall speed, then you know that there are other forces involved and you don't know if those forces are separately applied to the objects or if one object is applying some force on the other object.
  • · Replies 35 ·
  • · Replies 22 ·
  • · Replies 128 ·
12K
