What is the relationship between fuel economy and engine type in Europe?
  • Thread starter Thread starter BryMan92
    Stats
The discussion revolves around analyzing the fuel economy of vehicles in Europe, specifically comparing gasoline and diesel engines. The original poster is attempting to deconstruct average MPG data into separate values for gasoline and diesel vehicles, based on assumptions about their distribution and performance differences.
  • Participants discuss the potential bimodal distribution of fuel economy data and the original poster's method of using a lever analogy to estimate MPG values. There are inquiries about the adequacy of available data and suggestions for statistical techniques, such as the EM algorithm, to analyze the distributions.
The conversation includes various interpretations of the problem, with some participants providing mathematical formulations to estimate individual fuel economies. The original poster expresses uncertainty about their statistical background and the feasibility of applying suggested methods, while others offer encouragement and additional resources.
The original poster lacks specific data points beyond average MPG values and percentages of vehicle types, which raises questions about the reliability of their assumptions regarding bimodality. There is also mention of working with a government department for further data access.
BryMan92
I am analyzing fuel economy of vehicles in Europe. Since there are gasoline (lower MPG) and diesel (higher MPG) I assumed the distribution to be bimodal. I am trying to deconstruct the data into a gasoline MPG and a diesel MPG. I have attached an image to explain my approach.
2. The attempt at a solution
I'm no statistician, so forgive me while I break math. I figured I could treat this system like balancing a lever on a fulcrum. Essentially, I said a diesel vehicle is 40% more than a petrol vehicle and the red line is a given average of the MPGs. So, I did the following maths:
% of Cars for Petrol * x = % of Diesel* (1-x)
x=7/10, x'=3/10
So, I said the gasoline vehicles would receive a 70% (the distance) *40% (difference in fuel economy) reduction, or (1-.7*.4)(Average), while diesel would receive a (1+30%*40%)(Average). Would this, by any chance, work or be accurate??
Thanks guys!
Hey BryMan92 and welcome to the forums.
There is a technique known as the EM algorithm, and when you apply it to a mixture of normal distributions with their own peaks (i.e. in this case for diesel and other), you can calculate the PDF that converges to that particular distribution with the bimodal property.
From there you can calculate anything from expectation, variance, probabilities and so on.
Thanks, chiro! I am glad to know there is a way to do this. My problem is, I do not have a large stats background. From what Google told me, it doesn't seem likely that I will be able to learn how to do this.
I am curious, would I even have enough information to solve it? I know % diesel, % petrol, and the estimated difference in MPG. Is there some kind of formula I could plug into?
Thank you so much!
BryMan92 said:
I am analyzing fuel economy of vehicles in Europe. Since there are gasoline (lower MPG) and diesel (higher MPG) I assumed the distribution to be bimodal.[snip]
On a more basic level, have you looked at the data? Is it, in fact, bimodal?
I do not have the data, I just have an average of the ENTIRE MPG of the country. I know %diesels and %gas vary change, but other than exact #s, I have some data that shows the average of a gasoline is 48 MPG, while the average of the diesel is 69 MPG.
The difference in MPG between diesel and gasoline is pretty large, so I assume it would be bimodal. For some countries, the ratio between the amount of gasoline and diesel vehicles was close leading me to think the average is too high for gasoline and too low for diesel. This is why I assume bimodal. But, for countries that are 75/25 I just assumed the average was close enough to be treated as say a diesel estimate.
Image 1 shows equal amounts, while image 2 shows a bias.
Ok Bry, so what you're really asking is this:
- You have a fleet that consists of petrol vehicles P and diesel vehicles D.
- You know the percent which are P and the percent which are D. Say [itex]N_P/N = \alpha[/itex] and [itex]N_D/N = (1-\alpha)[/itex], where N is the size of the entire fleet.
- You know (estimate) that the average fuel efficiency of the diesel fleet is some given constant times that of the petrol fleet, [itex]\bar{D} = k \bar{P}[/itex].
- You know the average fuel economy (MPG) of the entire fleet, let's call it [itex]\bar{X}[/itex]
- From the above data you wish to estimate the values of [itex]\bar{P}[/itex] and [itex]\bar{D}[/itex], the individual fuel economies of the petrol and diesel fleets.
Is that a correct problem statement? If so this is very easily solved.
... continued.
The overall mean is just a linear combination of the two individual means,
[tex]\bar{X} = \alpha \bar{P} + (1-\alpha)\bar{D}[/tex]
Which gives,
[tex]\bar{X} = \alpha \bar{P} + k(1-\alpha)\bar{P}[/tex]
[tex]\bar{X} = [\alpha + k(1-\alpha)] \bar{P}[/tex]
Now rearranging for [itex]\bar{P}[/itex] gives,
[tex]\bar{P} = \frac{\bar{X}} {\alpha + k(1-\alpha)}[/tex]
and therefore,
[tex]\bar{D} = \frac{k \bar{X}} {\alpha + k(1-\alpha)}[/tex]
Uart, this is wicked awesome and exactly what I needed! Thank you so, so, so much!
I have a small amount of other, but I will neglect them! Thank you!
Just a (belated) observation on 'bimodal'. If I were you I'd hit some manufacturer websites and get an idea of the range of values. You might also try contacting your government department responsible for transport. Some are very helpful and have access to raw data that can give you good answers with no modelling.
I do have a small set of data that compares 10 vehicles with petrol and diesel engines (from the makers website), and a large amount from a website called fuelly.com. I hope this image will demonstrate the biomodality!
Also, I am actually working with my countries Department of Energy, already!
  • · Replies 39 ·
32K
66K
