What is the Relationship Between Probability Amplitudes and the Sum of Terms?
The discussion revolves around the relationship between probability amplitudes and the total probability in quantum mechanics, specifically focusing on the equation for the probability of an event expressed as the square of the sum of wave functions multiplied by their respective coefficients. Participants explore the implications of certain conditions on the coefficients and wave functions.
  • Participants express uncertainty about how to utilize the given equation and the implications of the conditions on the coefficients. There are discussions about the nature of the wave functions and their mathematical properties, including normalization and orthogonality. Some participants suggest expanding the probability expression to understand the contributions of different terms.
The discussion is active, with participants questioning assumptions about the wave functions and the coefficients. Some guidance has been offered regarding the properties of normalized and orthogonal functions, and there is an ongoing exploration of how these properties affect the total probability calculation. Multiple interpretations of the problem are being considered.
Participants note that the problem is presented in a somewhat informal context, as it was posed by a professor without a formal structure, leading to varying levels of understanding and assumptions about the wave functions involved.
isochore
The probability of an event is ## \vert c_1 \psi_1 + c_2 \psi_2 \vert ^2 ##. If ## \vert c_1 \vert ^2 = \vert c_2 \vert ^2 = \frac{1}{2} ##, what can you say about the total probability?
See above
I am not sure what I can do with the equation. I realize that ## \vert c_1 \vert ^2 = \vert c_2 \vert ^2 = \frac{1}{2} ## does not mean that ## c_1 ^2 = c_2 ^2 = \frac{1}{2} ## or that ## c_1 = c_2 ##, so I don't know how to use it. I think ideally I might have something like ##P = \vert c_1 \vert ^2 \vert \psi_1 \vert ^2 + \vert c_2 \vert ^2 \vert \psi_2 \vert ^2 + ## (more terms involving ## \psi_1 \psi_2##), but is there a formula or something?
isochore said:
Homework Statement:: The probability of an event is ## \vert c_1 \psi_1 + c_2 \psi_2 \vert ^2 ##. If ## \vert c_1 \vert ^2 = \vert c_2 \vert ^2 = \frac{1}{2} ##, what can you say about the total probability?
Relevant Equations:: See above
What are ##\psi_1, \psi_2## and what can you assume about them?
PeroK said:
What are ψ1,ψ2ψ1,ψ2\psi_1, \psi_2 and what can you assume about them?
I think they're just supposed to be wave functions corresponding to some experiment, and ## c_1 ## and ##c_2 ## are supposed to be scalars.
What can you assume about ##\psi_1, \psi_2## mathematically?
PeroK said:
What can you assume about ψ1,ψ2ψ1,ψ2\psi_1, \psi_2 mathematically?
I guess I'm not following here?
Have you ever heard the terms "normalised" and "orthogonal"?
Yeah, I have, and it makes sense that it would matter. This is all the info I got with the problem (my professor just asked us to consider it, rather than it being a formal problem), so I guess they're normalised/orthogonal?
It's the same if that expression involved ordinary vectors. The magnitude would depend on the magnitude of the vectors and their inner product.
I think it's safe to assume ##\psi_1, \psi_2## are orthogonal and normalised.
Makes sense. My initial thought for getting something like ##P = \vert c_1 \vert ^2 \vert \psi_1 \vert ^2 + \vert c_2 \vert ^2 \vert \psi_2 \vert ^2 + ## (more terms involving ## \psi_1 \psi_2##) was by using the triangle identity, but I don't see a way to get the mixed terms. Is there a different direction to go in?
You need to find out what normalised (magnitude of ##1##) and orthogonal (inner product of ##0##) mean.
Note that the wavefunctions are functions/vectors not numbers.
You must have course notes on this.
I guess I can expand it, like
## P = (c_1^* \psi_1^* + c_2^* \psi_2^*) (c_1 \psi_1 + c_2 \psi_2) = c_1^* c_1 \psi_1^* \psi_1 + c_2^* c_2 \psi_2^* \psi_2 + c_1^* c_2 \psi_1^* \psi_2 + c_2^* c_1 \psi_2^* \psi_1 = \vert c_1 \vert^2 \vert \psi_1 \vert^2 + \vert c_2 \vert^2 \vert \psi_2 \vert^2 + c_1^* c_2 \psi_1^* \psi_2 + c_2^* c_1 \psi_2^* \psi_1##
So if they are normalised/orthogonal, ##\vert \psi_1 \vert^2 = \vert \psi_2 \vert^2 = 1## and ##\psi_1^* \psi_2 = \psi_2^* \psi_1 = 0 ##, so I would be left with ##\vert c_1 \vert^2 + \vert c_2 \vert^2 ##?
This seems to imply that ##\vert c_1 \psi_1 + c_2 \psi_2 \vert^2 = \vert c_1 \psi_1 \vert ^2 + \vert c_2 \psi_2 \vert ^2 ##, but my professor talked about the importance of differentiating between these two in experiments, specifically that you had to sum the probability amplitudes and not the probabilities because of interference effects? Is there some distinction I don't understand?
You are treating the wavefunctions like complex numbers. They are functions. I'm on my phone so it's difficult to type too much.
##c_1\psi_1 + c_2\psi_2## is a function. It's magnitude is actually an integral. But the integral has the properties of an inner product, so you don't always have to write out an integral. And the functions have properties of vectors.
The magnitude of a function is defined by
##|\psi|^2 = \langle \psi |\psi \rangle = \int \psi^*(x)\psi(x)dx##
However, when you have an orthonormal basis of wavefunctions, then this is the same as you have for ordinary vectors. The magnitude of a function/vector is simply the square root of the sum of the squares (modulus squared for complex coefficients) of the components. Which is just a generalisation of Pythagoras.
This is not right. Orthogonal means:
##\langle \psi_1 |\psi_2 \rangle = 0##
I was using ##\psi^*## to be ##\langle \psi \vert##, but that's probably not good notation.
So ## P = (c_1^* \langle \psi_1 \vert + c_2^* \langle \psi_2 \vert) (c_1 \vert \psi_1\rangle + c_2 \vert \psi_2\rangle) = c_1^* c_1 \langle \psi_1 \vert \psi_1\rangle + c_2^* c_2 \langle \psi_2 \vert \psi_2\rangle + c_1^* c_2 \langle \psi_1 \vert \psi_2\rangle+ c_2^* c_1 \langle \psi_2 \vert \psi_1\rangle = \vert c_1 \vert^2 \vert \psi_1 \vert^2 + \vert c_2 \vert^2 \vert \psi_2 \vert^2 + c_1^* c_2 \langle \psi_1 \vert \psi_2\rangle + c_2^* c_1 \langle \psi_2 \vert \psi_1\rangle ##.
So if they are normalised/orthogonal, ##\vert \psi_1 \vert^2 = \vert \psi_2 \vert^2 = 1## and ## \langle \psi_1 \vert \psi_2 \rangle = \langle \psi_2 \vert \psi_1 \rangle = 0 ##, so I would be left with ##\vert c_1 \vert^2 + \vert c_2 \vert^2 ##?
Generally ##*## denotes the complex conjugate.
Note that because we are dealing with probability amplitudes we have ##|c_1|^2 + |c_2|^2 = 1##.
If we were dealing with classical probabilities we would have ##p_1 + p_2 = 1##. And in this case it's not ##c_1 + c_2## we are interested in.
And, although for an orthonormal basis the cross-terms cancel, they do not in general. What we have done here is not valid for all wavefunctions ##\psi_1, \psi_2##.
Makes sense - thanks!
