What is the relative velocity of the two reference frames?
The discussion focuses on calculating the relative velocity between two reference frames based on a particle's energy and momentum. The total energy of the particle is given as 5 GeV with a momentum of 3 GeV/c. Participants worked through the calculations for energy in a different frame, arriving at 5.66 GeV, and determined the rest mass to be approximately 4.3 amu. The relative velocity was calculated using the relativistic velocity addition formula, with a final result of about 0.185c. The conversation emphasizes the importance of correctly applying relativistic equations to solve for the desired quantities.
byerly100
c) What is the relative velocity of the two reference frames?
byerly100 said:
A particle as observed in a certain reference frame has a total energy of 5 GeV and a momentum of 3 GeV/c (i.e., cp, which has the dimension of energy, is equal to 3 GeV).
a) What is its energy in a frame in which its momentum is equal to 4 GeV/c^2?
b) What is its rest mass in amu?
I tried using E^2-(cp)^2=(E.)^2 but got 5.83 GeV. The answer to a is 5.66 GeV.
1 amu=931.49 MeV/c^2
The answer to b is 4.3 amu.
The answer to c is 0.187c.
Maybe just try part a) again, but make sure you account for the total energy and the momentum in both frames.
Not sure where you went wrong. I got 5.66
I probably didn't account for both frames. How did you use the 4 GeV/c?
E^2-(cp)^2 = (E.)^2 = (m.c^2)^2 is invariant
(I assume you are using the dot for the zero subscript)
From your orignal data,
(E.)^2 = 25GeV^2 - 9GeV^2 = 16GeV^2
4GeV/c is the p in the second frame. Substitute that into your energy equation and solve for E
Yes, I was using the dot for 0 subscript.
E^2-(16 GeV^2)=16 GeV^2
E= 5.66 GeV
I could also use help on the rest of the problem, b and c.
E= 5.66 GeV
right?
I could also use help on the rest of the problem.
If you look back at the equations used, you should get part b) quite easily. Give it a try.
byerly100 said:
I was trying b. I'm still working on it.
What is the 16Gev^2 on the right hand side of your earlier equation?
16Gev^2=E.^2
4 GeV= E.
931.49 MeV/c^2 = 1 amu
byerly100 said:
It is (m.c^2)^2.
4 Gev= (m.c^2)
So.. solve it for the rest mass and you've got it.
byerly100 said:
It is (m.c^2)^2.
4 GeV= (m.c^2)
4.44x10^-8 kg(?)=m.
1 amu = 1.66x10^-27 kg
Check your original post for conversion from MeV/c^2 to amu
Part c) is the hardest part. Do you know how to find the velocity of the particle in each frame from the known energy and momentum? Once you have that, you need to use the relitivistic velocity addition formula. I'll let you work on that a bit.
4 x 10^9 eV / 931.49 x 10^6 eV = 4.3 amu (should there not be a /c^2 in the conversion information?)
I'm trying c now.
v/c = cp/E
v=c^2p/E
v. = c^2(3 GeV/c) / 4 GeV = 2.25x10^8 m/sec
v=2.12x10^8 m/sec
I got u= 2.86x10^8 m/sec...
v= c^2p/E
ux=ux'+v/(1+vux'/c^2)
I got something for part c but it was off (wrong).
byerly100 said:
v= c^2p/E
You left out parentheses in your numerator, but I expect you used them. You just have a sign problem. You know the velocity of the object in two frames. You are looking for the relativistic difference between the two. Try replacing the + in your equation with -
ux'=(ux-v)/(1-vux/c^2)
I got 0.185c. I used 1.8x10^8 m/sec for one v and 2.12x10^8 m/sec for another v.
I see you just changed it.. I was trying to figure out where you got the first v :smile:
I also got the .185c. I think you got it.
  • · Replies 26 ·
  • · Replies 87 ·
