What is the running time of this algorithm?
12 replies · 5K views · last reply
zeion
Suppose that you have k >= 1 sorted arrays, each one containing n >= 1 elements, and you wish to combine them into a single sorted array with kn elements.
Can I assume that each array has a size of n elements for a worst case scenario?
Then, if I were to merge them sequentially, ie merge first two, then the third with the first two, the running time would be O(kn), since, the first two will take n comparisons, making a merged list of 2n elements, then compare to the next list of n elements takes n comparisons, and latch on the rest of the 2n list.
Does that make sense?
okay
What if there is no "rest"? Maybe the n list has elements to be slotted throughout the 2n list?
NascentOxygen said:
okay
So you're saying, if the third list had more than 2n elements?
Then I would compare 2n times and latch on the left over from the third list?
I'm not sure how to set up the problem for a worst case since each array can have n >= 1 elements?
zeion said:
If I were to merge them sequentially, ie merge first two, then the third with the first two ... the first two will take n comparisons, making a merged list of 2n elements, then compare to the next list of n elements takes n comparisons
Are you sure it only takes n compares to merge two arrays of size n? Take a very simple case, how many compares does it take to merge 2 lists with 2 elements each, for example {1, 3} {2, 4}? What about 2 lists, 3 elements each, for example {1, 3, 5} {2, 4, 6}?
So for the second example, I would compare 1 and 2, then insert the smaller one, then insert the larger one: (1, 2)
Then compare the next two, 3 and 4 and insert in the same way: (1, 2, 3, 4)
Then compare 5 and 6 and get (1,2,3,4,5,6)
So I compared 3 sets of 2 numbers.
rcgldr said:
for example {1, 3} {2, 4}? ... What about 2 lists, 3 elements each, for example {1, 3, 5} {2, 4, 6}?
Using this same method how would you merge {1, 2, 5} and {3, 4, 6}? By "insert" do you mean to "insert" into the output array? If so that's not a merge, and if insertion was used, the insertion would take more compares.
Okay so, to "merge" two lists I will simply append either one after the other.
This will take k - 1 appends? Or do I have say that I append each element at a time, so that would take n(k - 1) ?
Then, I suppose I will use a merge sort algorithm to sort the whole list.. which takes worst-case O(nlogn) ?
zeion said:
Then, I suppose I will use a merge sort algorithm to sort the whole list.. which takes worst-case O(nlogn)?
That's the time it takes to sort a single unsorted array of n elements, and O(...) is a relative number, the (n log n) shows how the number of elements affects O(...), without separating moves and compares (there are fewer compares than moves).
In this case, you have k sorted arrays of n elements each. I'm not sure what your supposed to calculate at "running time", the number of compares and moves as separate counts or the relative overhead versus k and n.
Maybe one more example, merge {1, 2, 9, 10} , {4, 5, 8, 11}, {3, 6, 7, 12}. How many compares do you need? How many moves do you need? What if you merged all 3 arrays in one pass?
What is a "move"?
So for the example, I would "compare" the 1 with 4.
Then, I will "move" the 4 between the 1 and the 2?
Do I also need to "move" all of 2, 9, 10 forward to make space?
The questions says, "What is the worst-case running time of this algorithm, as a function of k and n?" The algorithm being to merge the first list with the second, then that one with the third.. etc.
zeion said:
What is a "move"?
OK, apparently merging wasn't explained to you properly in class. A merge of k arrays, each of of size n, ends up copying the data into a new single array of size k x n. So there's a total of k+1 arrays involved, the k input arrays of size n each, and the output array of size k x n.
Okay so,
I think, for comparing two arrays, I would always have to compare the size of the bigger array.
So for the first method of combining the first two, then with the third etc..
It would take n compares for the first two, then 2n compares for the third with the first two, then 3n, then 4n ...
Each time I finish comparing I would move the element to the kn array, so the moves would be 2n moves for the first two, n moves for all the other ones, so total of k moves.
How many compares would you have to do to merge {1, 2, 9} and {3, 4, 5, 6, 7, 8}?
zeion said:
Each time I finish comparing I would move the element to the kn array, so the moves would be 2n moves for the first two.
If you merged 2 arrays into an output array, you would need another array to merge that output array with the 3rd input array, alternating between the two output arrays. That would require (2 + 3 + ... + k) x n moves.
If you merged all k arrays in on pass, it would only take k x n moves. If you did merge k arrays in one pass, and assuming you haven't reached the end of any of the k arrays, how many compares would it take for each element moved to the single output array of size k x n?
