What is the Savitzky-Golay 2nd derivative method?
  • Thread starter Thread starter Another
    Derivative Method
The Savitzky-Golay second derivative method differs from Savitzky-Golay smoothing primarily in its application of polynomial fitting. While Savitzky-Golay smoothing focuses on generating a smoothed output by evaluating a polynomial at each data point, the second derivative method evaluates the derivative of that polynomial, producing a new set of values. This technique is particularly useful when the order of the derivative is less than the polynomial order used in the fitting process, ensuring accurate differentiation from noisy data sets.
  • Understanding of polynomial fitting techniques
  • Familiarity with Savitzky-Golay smoothing
  • Knowledge of numerical differentiation methods
  • Basic statistics and data analysis skills
  • Research the implementation of Savitzky-Golay smoothing in Python using SciPy
  • Explore numerical differentiation techniques and their applications
  • Learn about the impact of polynomial order on Savitzky-Golay methods
  • Investigate the use of Savitzky-Golay filters in signal processing
Data analysts, signal processing engineers, and researchers working with noisy datasets who need to apply advanced smoothing and differentiation techniques.
Another
TL;DR
How are Savitzky–Golay second derivative different from Savitzky–Golay smoothing?
Assume we have a noisy data set with ##N## data points, ##x_i##, where ##i = 1, \ldots, N##.
Then Savitsky-Golay smoothing is equivalent to locally fitting a polynomial about each ##x_i## (using some number of neighboring data points), then evaluating that polynomial to produce a new ##y_i##.
Savitsky-Golay differentiation is equivalent to locally fitting a polynomial about each ##x_i## (using some number of neighboring data points), then evaluating a derivative of that polynomial to produce a new ##z_i##. This is of course only interesting to do if the order of the derivative is less than the order of the polynomial used in the fitting.
jason
