What is the size of a point? Or, what is a particle?
  • Level: Graduate
  • Thread starter Thread starter seerongo
    Particle Point
50 replies · 12K views
apeiron said:
So the answer is that the infinity is a property of the model, not necessarily a property of the reality.
How do you know this?
Zz.
As the OP, I just wanted to briefly say that I'm glad to see this thread get back on the track that I had hoped it would go from the start. I'm sorry if my intuitive leanings got in the way there for a while, but I must say that I have learned a lot from this discussion. Even though my profession is in a different field, it is almost scary how much I actually understand from you experts, complementing my own readings.
That said, I leave the discussion to you.
PS. I will admit to Zz and all that my favorite color is: 33CCFF...(Please don't reply to this, though, unless you see it as a new thread in General Discussion which I see is a bit more relaxed).
Thanks to all.
Ron
Zz.
What? How do I know it is a property of a model? Or how do I know it is not necessarily a property of reality?
The answer generally would be that I believe the human mind to be in a modelling relationship with reality and these are the consequences of this view.
Do you take some different position here? Naive realism? Platonism?
None. I'm an experimentalist, and I accept things as valid when there are valid empirical evidence to support them.
So you accept as a fact that there is a difference between our description of the world, and the world itself? That's why I asked how you would know this. As far as I can tell, your argument so far as been based on nothing but a matter of tastes.
Zz.
This is naive and unrigorous.
What are the "things" that are validated by experiments if not models?
Take a concept like temperature for example. In what way is this not a model? Or even a family of models (from caloric fluids to Boltzmann ensembles)? And where is the "reality" in our sensations of hot and cold?
Empiricism means you test your ideas against observation. But you have to have crisp and formal ideas (models, theories, hypotheses) to know what kind of observations would count as a valid test.
seerongo said:
Interesting replies. The above quote exactly summarizes what has always been difficult for me. I think I just have a conceptual problem with the idea of a continuum of space and time). For some reason, the idea of a quantum space/time actually makes more intuitive sense to me than a continuum. I don't know why because both are hard to imagine, but it has to be one or the other in the absence of alternatives (are there any?). A continuum seems to lead inevitably to physical reality or existence of infinite and infinitesimal objects, space, time, ad infinitum (no pun intended) and that is what I can't get past. Naty1's reference to T dualities is another example of this problem. No infinities for me, please.
Ron
Its not just your intuition.
Non-finitist mathematics is strictly speaking, not logical. It is riddeled with internal contradictions, and thus on the most elementary logical grounds, should have to be rejected.
Perhaps you are aware of Gallileo's paradox, the answer to the question 'are there less squares of natural numbers than there are natural numbers', being both yes and no. A contradiction, plain and simple.
Contemporary mathematicians 'resolve' this contradiction by saying that an infinite set is one that can be put into one-to-one correspondance with a subset of itself. Its a negation of identity, of course, but if you state it without flinching your eyes, most mathematicians will buy it and consider the issue resolved.
Infinite divisibility isn't any better. If you are feeling bored, show some mathematicians how to put the real numbers in one to one correspondence with the natural numbers (the proof is not particularly hard to find). Its even better than arguing with creationists. Mathematicians would rather bite off their tongues than admit to internal contradictions in their trade.
Whether or not reality is logical is a metaphysical belief that I can't really argue one way or another, but I have yet to see the first instance of reality contradicting itself, and I think the infinite divisibility of space will go the same way as the infinite extent of the earth, the infinite extent of the universe, and the infinite divisibility of matter.
Choosing between non-contradiction and lorentz invariance seems like an easy choice to me.
ZapperZ said:
That isn't quite right. First order phase transition, by definition, has a discontinuity in a state variable. This clearly implies that the rate of change at such a phase transition is infinite.
The van Hove singularity is very common in your semiconductor.
The density of states of a superconductor right at the energy gap edge is infinite.
The spectral function of a quasiparticle in an ordinary metal, which is the imaginary part of the single-particle Green's function, is essentially a delta function. This gets you the ordinary metallic behavior that gives you all the Drude model that we know and love.
Etc... etc.
These are all approximate models of reality. There are no first order phases transitions, there are no semiconductors of infinite extent, there are no quasiparticles.
These infinities arise for no other reason than you (implicitly) demanding they be in your model.
We have no issues with dealing with an infinite value. A whole branch of mathematics is built around dealing with poles like this.
Mathematics deserves some qualification. If you meant logically inconsistent mathematics, ok.
These so-called "models" work, and you depend your life into it.
And who demanded a semiconductor of infinite extent?
I could also say that your assertion is also an "approximate model of reality", assuming we all know what "reality" really is.
Let's put it this way, anytime someone tells me that there is a difference between our physical description of the world we live in and "reality", I would appreciate an evidence to show me this difference. Till you can show that, save your breath and your effort.
Zz.
But this is exactly what I'm asking. How are you to know that what you are saying here is valid. You make it seem as if there is a CLEAR difference between what we describe, and what "reality" is. For all I know, your assertion that these are "models" and not "reality" is in itself, A MODEL! Not only that, it is a model of the worst kind - it has no empirical basis.
Zz.
Ehm, don't take my word for it, but the way i understand it, the atomic hypothesis has a fair amount of credibility these days. A continuum of state variables is recognized as an approximation. Inviscid compressible flow equations develop infinite gradients. What of it?
The relevant question is whether our most reductionistic theories of space, time and matter require a notion of infinity. It is not at all obvious that they do.
I'm not sure the relevance of what you just wrote here. And as far as "reductionistic theories of space, time, and matter" is concerned, if you do a search of "emergent phenomena" on here. You'll find many of my posts that try to go against such reductionist approach. So I'm not the one you should be arguing against.
Zz.
The relevance is that I personally do expect fundamental physics to be logically consistent.
First order phase transitions are not fundamental physics. It is an approximate model to what we do believe to be closer to the truth, at least. Invoking the mathematical needs of such approximate models is in my opinion not at all an argument in favor of infinity.
I too think a lot of reductionism is misguided, but I am all for reductionism, insofar as this means trying to find a minimum set of principles which explain all physics. No clue what you are referring to here, so perhaps you are doubly the one i should be arguing against.
I don't invoke the needs. I described the current understanding of not only the classical phase transition, but also quantum phase transition.
Again, this "truth" and this "reality" needs to established. You again are arguing there such a thing exist without any justification.
Zz.
Zz.
Reality is an assumption I hold on to, yes. If you dont, good for you, but then this discussion is over.
It would be nice if you know when you actually have found this "reality".
This was the point I was trying to make, which no one could point to. So essentially this discussion was over a long time ago.
Zz.
I define it as 'that which I can see'. That makes it easy, as you don't have to bother to expend any energy going looking for it.
Models should fit the data, and they should not contradict themselves. Within those constraints, anything goes as far as I am concerned.
Then you need to argue with apeiron, who said:
So your observation is based on at least a theoretical description/model, whether you are aware of it or not.
Zz.
Zz.
What kind of sophomoric epistemological point are you trying to make here? That we must doubt, and then doubt even our doubts?
Of course I am talking about the model of the model. The meta-model. And being on different epistemic levels, doubt does not apply in exactly the same way. Though of course doubt still must apply.
And of course the meta-model has an empirical basis - a general one appropriate to its level rather than a particular one that would be appropriate to some particular model (or theory).
So, to recapitulate the approach we have been taking since the Enlightenment, we realize that the human mind does not know the world directly. Ideas shape our impressions (and it being a modelling relationship, impressions in turn are shaping our ideas).
I note you ducked the question about temperature. But of course you knew that this was one of the most ancient sources of doubt, the way that if you stick one hand in hot water, the other in cold, then put both hands into lukewarm water and get conflicting "empirical" reports.
So given that our ideas and impressions need to be developed in some more rigorous fashion, we invented the scientific method. We created formal models (equations, that kind of stuff) which made predictions that we could test via measurements, experiments, and then changed the equations in the light of what we observed or learnt.
And we also gave away the idea that the equations needed to be representations of "how things really are".
Remember Newton and his famous struggles to believe in action at a distance. Hypotheses non fingo and all that. This part of his theory of gravitation seemed unreal to everyone and it most probably is. But as a model, the stripped down and unreal view is usually what works.
Of course, some fools then believe that the model IS then the real. No. What we have done is accept we are modellers and so therefore all our views of reality are to some extent compromised, unreal, fictional - but in a useful way.
Newton's gravity was supported by certain lines of empirical evidence. And his general approach to modelling - where the unreality of the equations ceases to be an issue, just part of the game being played - has been supported empirically by a lot of successful science since.
The meta-modelling is empirically supported by the success of the modelling!
So nothing I say here is a matter of taste. It is simply a modern 21st Century way of more precisely stating the direction we have been going since at least the Enlightenment.
Believe it or not, the epistemology of science (and understanding generally) is still a work in progress. There are new details to add. There are more rigorous meta-models being developed.
So unless you have studied the recent literature - and all your reponses seem strictly personal, off the top of your head impressions, lacking any grounding in citations - you are going to struggle to make a telling point here.
So then what makes your model any more "real" than mine?
To address your "temperature" model, first of all this has nothing to do with what we consider as "hot or cold". This is a subjective sensation and has nothing to do with physics. Secondly, there's a difference between (i) a valid model that later on gets enclosed into a more general description versus (ii) a flawed model. Newton's laws are examples of (i) and the caloric/Bohr atom are the 2nd. It does mean that I consider Newton's laws as a valid description of "reality" within the realm of their applicability.
But again, how do you know this? "does not know the world directly" is a loaded statement. It says nothing about what it means as "knowing" and it says nothing about what it means to know something "directly", as if there is such a thing. Did you directly read all these things that I wrote?
No, I still say it is a matter of tastes. I can easily point to the "shut-up-and-calculate" philosophy in which even demanding that there is a difference between what we perceive and what reality is is a meaningless dichotomy, because you have no empirical evidence that there is such a difference. Even extreme solipsism would argue alongside with that. I only need to point to only one different point of view here to show other possible point of view to show that adopting one IS a matter of preference.
Zz.
Sorry, you'll have to come out of the closet here and tell us what it is you actually do believe.
Are you saying we DO directly know the world in unmediated fashion?
Are you saying ALL epistemologies are a matter of taste?
What are the empirical grounds that support your chosen epistemology?
Please then provide citations to support your point.
Your own arguments presented here are simply naive and incoherent.
You are begging the question again. What do you mean by valid? Do you mean "true" or do you mean "seems to work".
Or when you say flawed? Does this mean "false", or "does not seem to work so great".
If you are a pragmatist, philosophically speaking (like CS Peirce), then you are taking a modelling approach even if you don't seem to understand that.
Even if you say I believe it to be true at the moment now, but better evidence may change my mind later, you still doubt and thus you still model.
But if you actually think some models are true, some models are false...
Again, define your terms. Cite your literature.
True and false are absolutes. Valid and flawed are clearly pragmatic terms that invoke "fitness for purpose". We can then ask whose purposes? By what measures?
A meta-level of epistemology is being acknowledged that can then be discussed. Rather than your attempts to close down discussion as soon as the issues get too gnarly for you.
