What is the solution for Ry in Sin 0=Ry/Rx when given values for Rx and theta?
  • Thread starter Thread starter niknak98
    Sin
The discussion revolves around a trigonometric equation involving sine, specifically the relationship Sin(0) = Ry/Rx. Participants are trying to clarify the problem context and the correct interpretation of the variables involved.
  • Participants are questioning whether the equation should indeed be Sin(0) or if it was meant to be Sin(θ). There are discussions about the implications of both interpretations, particularly regarding the values of Ry and Rx. Some suggest using inverse functions to explore the relationships further.
There is an ongoing exploration of the problem, with some participants providing guidance on how to manipulate the equation based on their interpretations. The clarification that the original equation likely contains θ instead of 0 has been acknowledged, which may help direct the discussion towards a more accurate understanding of the problem.
Participants note the potential confusion stemming from the original equation and the importance of correctly identifying the variable represented by 0. There is an indication that the teacher has confirmed this correction.
niknak98
Teacher assigned this on first day due tomorrow and i have no clue on some like this one:
Sin 0=Ry/Rx a.) solve for Ry
b.) solve for Rx
c.) solve for 0
Is there anymore information you can provide? Is that actually Sin(0)? Did you attempt to solve it on your own? Have you tried the inverse function?
Anyway, if it really is 0 then it should be obvious. Ry would have to be zero. Rx is then any real which is not equal to zero. Rewriting the equation as arcsin(Ry/Rx) = 0 will demonstrate this as well. I'm saying this because part of me doesn't believe that is really supposed to be sin(0), instead it's probably theta.
I can make absolutely no sense out of "solve for 0"! That would be like saying "solve for 2".
I strongly suspect that was supposed to be [itex]sin(\theta)= R_y/R_x[/itex] and your teacher (or you!) missed the horizontal line on the [itex]\theta[/itex].
To "solve for y", multiply both sides by [itex]R_x[/itex]. To "solve for x" one method is to first invert both sides, getting [itex]1/sin(\theta)= R_x/R_y[/itex] and then multiply both sides by [itex]R_y[/itex]. To "solve for [itex]\theta[/itex]" take the inverse sin (arcos or [itex]sin^{-1}[/itex]) of both sides.
Thanks this really helped and he did correct it that the 0 was theta
  • · Replies 46 ·
