What is the speed of a mass in simple harmonic motion at 0.60m?
The problem involves a mass oscillating on a spring exhibiting simple harmonic motion, with given parameters including amplitude and maximum speed. The original poster seeks to determine the speed of the mass at a specific displacement of 0.60m, questioning the validity of the provided answer of 0.75m/s.
  • Participants discuss various methods to calculate the speed, including energy conservation principles and ratios of potential and kinetic energy. Some express confusion regarding the relationship between energy fractions and the speed at a given position.
The discussion includes multiple interpretations of the problem, with participants arriving at different answers (0.99m/s and 0.75m/s). Some suggest using energy ratios to simplify calculations, while others express skepticism about the correctness of the provided answer. There is no explicit consensus on the correct speed, but productive dialogue continues regarding the methods used.
Participants note discrepancies between their calculations and the textbook answer, leading to discussions about potential errors in reasoning or assumptions made in the problem setup. The original poster expresses concern about whether to trust their calculated answer or align with their classmates' results.
speedskater
A mass is oscillating on a spring with simple harmonic motion. Its amplitude is 0.80m and its maximum speed is 1.5m/s, at the point of equilibrium. What is the speed of the mass at 0.60m?
Is there enough information to answer this question? The answer given is 0.75m/s, but I can't figure out how to get there.
Ep = kx2/2
Ec = mv2/2
Em = Ep + Ec
I've made many attempts at this, all completely wrong. I always end up trying to factorize (my teacher told us that the answer involves factorizing) but it goes absolutely haywire.
Em = Em'
Epmax = Ecmax
kxmax2/2 = mvmax2/2 (the 1/2 cancels for each formula)
vmax/xmax = √k/m (which should be constant)
(1,5m/s)2/(0.80m)2 = √k/m
1.875(not sure what unit to put here) = √k/m ∴ k/m = 3.516
kx2 + mv2 = mvmax2 (again the 1/2 cancels)
mvmax2 - mv2 = kx2
m(vmax2 - v2) = kx2
vmax2 - v2 = kx2/m
k/m = (vmax2 - v2)/x2
If the k/m stays constant, which I believe it should, it should be an easy substitution to find the v I'm looking for.
After manipulating the formula I got, I'm left with
v = √-(k/m - vmax2/x2)(x2)
After substituting, I get 0.99m/s.
Instead of all that, think in terms of fractions or ratios. At the point in question, what fraction of the total energy is Ep and what fraction is KE?
Is it possible the system is hanging?I got the same answer of .99m/s using a horizontal system and energy conservation principals.
Me too.
v=VmaxSin(ArcCos(6/8))
V=1.5 X sin(41.41°)
v=0.99 m/s
http://img818.imageshack.us/img818/3757/shmw.jpg
I get the same answer.
Do you mean x2/xmax2? = .36/.64 = 0.5625? So 56% of the mechanical energy is potential energy? Which would mean that 44% is kinetic energy. Not sure if that's what you mean or not, or if I just did some completely useless calculations. If that's what you meant, I don't see how that will help me :/
Just an observation, but [itex]1.5\sqrt{\frac{.8 - .6}{.8}} =.75[/itex], maybe that can help lead to an answer.
Like (v1/v2)2 = d1/d2, where d is the distance from the maximum amplitude, but how to prove this?
That's exactly what I meant. It's just a quicker way of getting the (same) answer:
KEx=0.6 = .4375*KEmax
1/2mV2 = .4375(1/2mVmax2)
But if you do that (mass cancels, 1/2 cancels), you get 0.99m/s again!
Another formula
ω=Vmax/R
v=ω√(A2-x2)
v=(1.5/0.8)√(0.82-0.62)
v=0.99 m/s
Of course. I'd say that was the correct answer.
What book are you using? Are you sure you didn't just read the wrong answer?
It's the Alberta high school physics textbook. It says 0.75m/s for sure. If all of you, who are experts in physics, agree with me and say it should be 0.99m/s, should I risk it and go with that answer? Or make up a way to get to 0.75m/s (as the rest of my class did) and just get partial points?
Maybe you can show us your friend's work(rest of the class) that lead to the answer v=0.75 m/s
All they did was t=d/v, using 0.80m for d. Then they manipulated the formula d=((Vi + Vf)/2)t to find Vf, using 0.60 as d. They got the answer by fluke, because velocity and acceleration are always changing in a spring.
Well, that 'solution' is clearly bogus. I say stick with your correct solution and trust the instructor to realize that the given answer is incorrect.
It turns out that 0.99m/s is right! Thanks everyone for all your help!
