What Is the Standard Potential for Tl2S Reduction?
The discussion revolves around determining the standard potential for the reduction of Tl2S to Tl and S^2-. Participants explore the application of the Nernst equation and the solubility product constant (K_sp) in their calculations.
  • Homework-related
  • One participant presents a calculation using the Nernst equation to find the standard potential, questioning the logarithmic term's formulation.
  • Another participant suggests writing the K_sp formula for Tl2S and solving for [Tl^+], indicating a need for clarity in the approach.
  • Several participants express confusion regarding the correct interpretation of K_sp and the relationship between concentrations of reactants and products.
  • There is a discussion about the correct application of the Nernst equation, with differing opinions on the signs and terms used in the calculations.
  • One participant acknowledges confusion over the concept of K_sp and its application in the context of the problem.
  • Another participant attempts to clarify the algebra involved in solving for [Tl^+] and emphasizes the need to consider the activity of sulfide as 1.
  • Multiple iterations of calculations are presented, with participants correcting each other's work and questioning the accuracy of the results.
Participants do not reach a consensus on the correct approach to the problem, with multiple competing views on the application of the Nernst equation and the interpretation of K_sp. Confusion persists regarding the correct signs and logarithmic terms in the calculations.
Limitations include unresolved mathematical steps and differing interpretations of the Nernst equation. Participants express uncertainty about the definitions and relationships involved in the calculations.
ssb
From the standard potential Tl^+ + e^- -----> Tl (solid) E^o= -0.336 V
Determine the standard potential of
Tl_2S (solid) + 2e^- -----> 2Tl (solid) + S^2^-
Given that the K_sp for Tl_2S is 1.2x10^-22
***I cannot get latex to put the -22 in the exponent. The Ksp is 1.2 * 10 ^-22
Nernst Equation
E = E^o -(0.05916/n) log(concentration)
E = -0.336 -(0.05916/2) log (1.2x10^-22)
E = +0.312
Im wondering if the log (1.2x10^-22) should be log (1/1.2x10^-22)
because the concentration is the products over the reactants. Can someone point me in the right direction? Thanks
10^{-22} = 10^{-22}
Write Kso formula for Tl2S and solve for [Tl+].
Borek said:
10^{-22} = 10^{-22}
OK BOREK! You have given me some insight. Thank you! Products over reactants. and because the reactants are solid, they will be in the denominator as the number 1. Ok I was able to come up with the following calculation. I would be much appreciated if someone could confirm for me the accuracy. Thanks!
Calculate the standard potential (E_{total}) of
Tl_2S (solid) + 2 e^- = 2Tl (solid) + S^{2-}
given that the K_{sp} of Tl_2S is 1.2x10^{-22}
E_{total} = E_{Tl^+/Tl} + E_{ksp} = -0.336 + (0.05916/2) * log(1.2x10^{-22})
E_{total} = -0.336 + (-0.648) = -0.984
so my answer is -0.98 when using significant figures due to the Ksp being 2 sig figs...right?
Look good?
No. Do what I told you to do.
Borek said:
10^{-22} = 10^{-22}
Kso formula
Tl_2S = 2Tl^+ (aq) + S^- (aq)
1.2x10^{-22} = {[Tl^+]^2[S^-]}/[{Tl_2S}]
Tl_2S is a solid so we can remove it from the equation giving me
So this is where I get confused... is the correct way to do it this:
1.2x10^{-22} = {[x]^2[x]}
x = 4.9 x 10^{-8}
Solve for Tl+. Not for some x, you are not trying to find out concentration of saturated solution (which you did wrong BTW - concentrations are different, not identical), but concentration of Tl+ as a function of Kso and [S2-].
Borek thank you so much for your help on this problem and that other problem I posted. Borek I am going to level with you... I am very confused. I thought I knew what a Kso was (something to do with solubility) but I don't know much more than that. In post # 3 (my first reply) I did something similar to what a TA did on a similar problem and I was following his steps. I am guessing that the problem is where i am taking the log but I really am not positive.
Can you give me a little bit more of a bump in the right direction please? Thanks.
Looks like you have problems with simple algebra.
K_{so} = [Tl^+]^2[S^{2-}]
Solving for [Tl+]:
[Tl^+]=\sqrt \frac {K_{so}} {[S^{2-}]}
Now put [Tl+] concentration into the original equation. As the question asks about standard potential, sulfide activity is 1.
Solving for [Tl+]:
Ok ok ok...
<br /> E_{total} = E_{Tl^+/Tl} + E_{ksp} = -0.336 + (0.05916/2) * log(\sqrt {1.2x10^{-22}})<br /> ?
This would give
E_{total} = -0.66 ?
Electrode reaction is still Tl+ + e- -> Tl...
omg did i do that honestly
E_{total} = E_{Tl^+/Tl} + E_{ksp} = -0.336 + (0.05916) * log(\sqrt {1.2x10^{-22}})
= -0.984
Look good now?
Better, but still wrong. What sign in Nernst equation if it contains concentration of oxidized form?
It would make it negative wouldn't it?
E_{total} = E_{Tl^+/Tl} + E_{ksp} = -0.336 + (\frac {.05916}{-1}) * log(\sqrt {1.2x10^{-22}})
= 0.312 volts
with sig figs making the answer 0.31 volts
This has to be correct this time. (btw thanks you have been unknowingly teaching me latex as well!)
Oops, sorry. You have been juggling signs and log argument and at about 1 a.m. you've lost me. -0.984 was OK. Still, your original Nernst equation
is incorrect, as long as it doesn't state concentration of what.
E = E_0 + \frac {RT} {nF} ln {\frac {[Ox]} {[Red]}}
if reduced form is solid, it simplifies to
E = E_0 + \frac {RT} {nF} ln {[Ox]}
or
E = E_0 + \frac {0.05916} {n} log {[Ox]}
11K
10K
