What is the Taylor expansion for 1/(1-exp(-1))?
The Taylor expansion for the function \( f(x) = \frac{1}{1 - \exp(-1)} \) is derived by substituting \( x = \exp(-1) \) into the series expansion of \( \frac{1}{1 - x} \). The series is expressed as \( \sum_{i=0}^{\infty} x^i \), leading to the conclusion that the Taylor expansion for the constant \( \frac{1}{1 - \exp(-1)} \) contains only one term, which is the value itself. The discussion clarifies that while the function is constant, approximations can be made using Taylor series for \( \frac{1}{1 - \exp(-x)} \) for variable \( x \).
  • Understanding of Taylor series and McLaurin series
  • Familiarity with exponential functions and their properties
  • Basic knowledge of calculus, particularly derivatives
  • Experience with series convergence and approximation techniques
  • Study the derivation of Taylor series for various functions
  • Learn about the convergence criteria for Taylor series
  • Explore the application of Taylor series in numerical methods
  • Investigate the properties of exponential functions and their expansions
Mathematicians, students studying calculus, and anyone interested in series expansions and approximations in mathematical analysis.
Callisto
Hi
How do you expand
(1-exp(-1))^-1
as Taylor series
Callisto
Try long division to get a Taylor (or McClaurin) series for f(x) = 1/(1-x) for a start.
Then put x=exp(-1) into that series, and there you go!
Taylor series for
1/(1-x) = (1-x)^-1 = 1 + x^2 + x^3 + x^4 +...= SUMi x^i
Then sub in exp(-1) for x
That's it?
Yes. That's it.
Cheers James R!
a constant has a trivial Taylor expansion
The expression you submitted is a constant, it doesn't depend on x.
All derivatives of this function with respect to x (the assumed variable) are zero.
Therefore the Taylor expansion contains only one term (and is exact):
f(x) = 1/(1-exp(-1)) + 0 + 0 + 0 + 0 + 0 + 0 + ... = 1/(1-exp(-1))
(unless you did not formulate your problem correctly)
Technically, you're right of course, lalbatros, but your solution doesn't seem to fit the spirit of the question which was asked. Maybe the question was a little unclear, though...
You are probably right James.
The question probably was: "how can I get an approximate value for 1/(1-exp(-1)) using Taylor expansions".
Then, there are numerous ways to choose how to expand.
For example:
1/(1-exp(-x)) = 1 /(1-sumi((-x)^i / i!))
or explicitely:
1/(1-exp(-x)) = 1/(x-x^2/2+x^3/6-x^4/24+x^5/120 ...)
