What is the Template Algorithm for Minimum Spanning Trees?
  • Context:
  • Thread starter Thread starter evinda
    Algorithm
13 replies · 4K views
evinda
MHB
Hello! (Wave)
According to my notes:
Template algorithm
The algorithm keeps the invariant :
"before each iteration,the set $A$ of vertices is a subset of some minimum spanning trees" at each step,where $A$ is an initial set of vertices.
Code:
Template algorithm(G)
   A<-∅
   while A isn't a connected component
           we define an edge (u,v),that is secure for A
           A<-A U {(u,v)}
   return A
Definition:
The edge $(u,v)$ is called secure for the set $A$,if it can be added to it,without the violation of the invariant.Could you explain me the following sentence? (Thinking)
"before each iteration,the set A of vertices is a subset of some minimum spanning trees" at each step,where $A$ is an initial set of vertices.
evinda said:
Definition:
Hey evinda! (Wink)
An invariant is a statement (or property, or proposition) that holds true at each iteration of a loop.
In this case the statement is that A is a subset of a minimum spanning tree.
Initially A is an empty set, which satisfies the statement.
When we add an edge that belong to a minimum spanning tree, the statement will still be satisfied. So that edge was what they call secure.
I like Serena said:
Hey evinda! (Wink)
I understand...Thanks a lot! (Smile)
Could you also give me an example,at which I can apply the template algorithm? (Thinking)
The algorithm,that is in my notes,is the following:
Code:
   A<-∅
   while A isn't a connected tree
           A<-A U {(u,v)}
   return A
I wrote component,instead of tree,in the first post.. (Blush) (Wasntme)
Sure!
How about the following graph. (Blush)
Ooooh! (Speechless)
I like Serena said:
Sure!
Do we always choose the edge,with the minimum weight? (Thinking)
So..is this a minimum spanning tree? (Thinking)
That is one of the ways to build a minimum spanning tree. (Happy)
https://www.physicsforums.com/attachments/3115
Yep! (Nod)
Is it unique?
If not, how many alternatives are there? (Wondering)Anyway, how would you apply the Template algorithm? (Wondering)
Nice! (Yes)
I like Serena said:
Is it unique?
No,it isn't unique.. (Shake) There are two alternatives..The other one is this:
Or am I wrong? (Thinking)
Α={}
Α={(Α,Β)}
Α={(Α,Β),(Β,Ε)}
Α={(Α,Β),(Β,Ε),(E,C)}
A={(Α,Β),(Β,Ε),(E,C),(C,F)}
A={(Α,Β),(Β,Ε),(E,C),(C,F),(A,D)}
So,a minimum spanning tree is the tree with the edges:
(Α,Β),(Β,Ε),(E,C),(C,F),(A,D)Am I right? (Thinking)
Yes. That is also a minimum spanning tree!
... but I think there is also a third one. (Wondering)
Α={}
Α={(Α,Β)}
Α={(Α,Β),(Β,Ε)}
Yup!
That is one way to execute the Template algorithm.
Could you also do it in another way? (Thinking)
(Other than making a different choice for the 4-edge.)
I didn't find an other spanning tree with weight $16$.. (Sweating)
For which edge could I make a different choice? (Thinking)
Well... node (d) has 3 edge that each have weight 4.
I think you can pick either one (but only one) of them...
All of them.
For executing the Template algorithm, you can pick any order you like.
Just as long as you only add edges that actually belong to specific minimum spanning tree. Those are secure.
However, to find secure edge without knowing the tree already, you need a more specific algorithm.
Like Prim's algorithm, or Kruskal's algorithm. (Thinking)
A ok.. (Nod) So,this is an other spanning tree,right?
In this case, we execute the Template algorithm,like that:
A={}
A={(A,B)}
A={(A,B),(B,D)}
A={(A,B),(B,D),(B,E)}
A={(A,B),(B,D),(B,E),(E,C)}
A={(A,B),(B,D),(B,E),(E,C),(C,F)}
Right? (Thinking)
I like Serena said:
All of them.
I understand! (Sun)
I like Serena said:
Yep, yep, and good! (Mmm)
Great! Thanks a lot! (Cool)
