What is the tension in the string?
  • Thread starter Thread starter I_LuV_FiZiX
    String Tension
I_LuV_FiZiX
A string from an Andrew Kirk violin is 30.0 cm long, with a linear density of 0.645 g/m. The violin is placed near a loudspeaker that is fed by an audio oscillator of variable frequency. It is found that the string is set into oscillation only at the frequencies 1312 Hz and 1749 Hz, as the frequency of the oscillator is varied over the range 1093 Hz to 1968 Hz. What is the tension in the string?
v=sqrt(T/linear density) v=lambda x frequency
I made these 2 equations equal to each other. However, I am unsure as to what proportion of L lambda is, and what to use for frequency. Once I know what to do here I can then isolate for tension and solve.
Thanks in advance, any help would be GREATLY appreciated.
can you give me a further hint as to how to find what to use for frequency? I've got less than an hour :S
The frequencies given will be integer multiples of a fundamental frequency. So 1312Hz will be [itex]nf_1[/itex] for example and 1749Hz will be the next integer multple from that, so it'll be [itex](n+1)f_1[/itex].
oh okay...so is a final answer of correct? 2.77N I have one try left :S:S:S:S
Since length of the string remains the same, for different frequencies the number of loops must be different.
Hence 1312*(n+1) = 1749*n. Solve for n and then find tension.
