What Is the Total Capacitance of an Infinite Series of Capacitors?
The problem involves calculating the total capacitance of an infinite series of capacitors, each with a capacitance of 1μF, between two points labeled a and b. The configuration suggests a repeating structure that raises questions about the effective capacitance due to the infinite nature of the series.
  • Participants discuss the implications of the infinite series and consider whether the arrangement can be simplified by treating the entire chain as a single capacitor. There is exploration of how adding additional capacitors affects the total capacitance and whether the series and parallel rules apply in this context.
Some participants have proposed relationships between the total capacitance D and the equivalent capacitance E of a modified configuration. There is ongoing exploration of the mathematical relationships involved, with some participants expressing confusion about the setup and calculations leading to a quadratic equation. The discussion reflects a mix of interpretations and attempts to clarify the relationships without reaching a consensus.
Participants are navigating the complexities of infinite series and the definitions of series and parallel capacitance. There is mention of potential confusion regarding the arrangement of capacitors and how they interact in the infinite series context.
jumpman11372
The capacitance of each capacitor of the infinite series shown in the picture is C = 1[tex]\mu[/tex]F. Find the total capacitance between points a and b. IMAGE: http://img61.imageshack.us/img61/3674/pic002311.jpg" (continues to infinity)
In series, (1/Ceq) = (1/C1)+...(1/Cn)
In parallel, Ceq = C1+...Cn
Well, since the series extends to infinity, it seems that it is just a repeat of the first branch/loop (A--B, 3 capacitors only), and I thought that the Capacitance between A&B would be infinity. After thinking this over, I doubt this would be the case, seeing as that is TOO easy.
After, I thought that it could be possible for the capacitors in the top and bottom rows to be in parallel with each other, but then I saw there is a break in between by the 3rd capacitor in between.
I'm totally lost on how to handle this :/
Cute problem.
Let D be the capacitance between points a and b. Think of the whole infinite chain as a single capacitor with capacitance D.
Now consider adding another link of the chain in front of it; that is, connect a and b with a new capacitor with capacitance C, and then create new endpoints a' and b' by adding a capacitor between a and a' and another one between b and b' (each with capacitance C). Now, the whole thing will have a capacitance E between a' and b'; you should be able to calculate E in terms of C and D.
But, since the chain was infinite to begin with, adding another link should not change its total capacitance; that is, we should have E=D.
This is enough info to compute D.
Thanks for the quick reply!
Well, I've made this quick picture of what you've typed out:
http://img158.imageshack.us/img158/3674/pic002311.jpg"
So adding this link in this infinite chain will not affect the total capacitance D, where E=D.
Correct me if I am wrong, but the capacitance between a' & b' is the equivalent capacitance of the 3 capacitors, which are in series, so (1/Ceq) = (1/C + 1/C + 1/C), where C = 1 microFarad
So the equivalent capacitance of this is equal to C/3, which, is equal to E, which is also equal to D?
So the capacitance of this infinite series of capacitors (D), is equal to C/3, or 1/3 microFarad?
sorry for this...
bump perhaps? :(
No. D is parallel with one of the C's and the result of that is in series with two more C's
The result of that is equal to D again.
Ok, so we have one Capacitor with Ceq = C+D (since one capacitor and D are in parallel)
Then, there are 3 capacitors which are in series with each other. Then here is where confusion steps in...
(1/C) + (1/C) + (1/C+D) = 1/D
or
(1/C) + (1/C) + (1/C+D) = D
I see that this will yield a quadratic equation.
you mean 1/((1/C) + (1/C) + (1/(C+D))) = D?
You indeed get a quadratic. The final answer for D is quite simple.
I got an answer of 1 microFarad, or 1 x 10^-6 Farads.
It seems that this is a quite simple answer, but WHY is this the answer? What leads the capacitance of this whole series to be 1 microF?
bump please :]
