What is the true nature of time?
  • Thread starter Thread starter Parbat
    Mean Time
The discussion centers on the nature of time, exploring its definition, its status as a dimension, and its relationship to space and events. Participants engage with conceptual, theoretical, and philosophical aspects of time, including its implications in physics and relativity.
  • Some participants question the meaning of "time" and express uncertainty about its definition.
  • One participant cites Richard Feynman's perspective that time is what happens when nothing else is happening, suggesting a subjective understanding of time.
  • There is a discussion about whether time can be considered a dimension, with some participants arguing that dimensions are necessary to explain objects, while others challenge this notion.
  • Participants explore the relationship between dimensions, coordinates, and vectors, noting that dimensions are static while vectors are dynamic.
  • One participant raises the idea that time is a one-dimensional quantity used to sequence events, but questions how this aligns with the qualitative attributes of directionality and orthogonality.
  • Another participant suggests that time dilation's relationship with gravity could imply that time might be thought of as a force or energy, although they acknowledge the terminology may not be precise.
  • There is a discussion about the implications of coordinate systems in analyzing events, with some participants asserting that the choice of coordinate system should not affect the analysis.
Participants do not reach a consensus on the nature of time or its classification as a dimension. Multiple competing views remain, with ongoing debate about the definitions and implications of time in physics.
Participants express various assumptions about the definitions of dimensions, coordinates, and how they relate to time. There are unresolved questions about the implications of time dilation and the consistency required in scientific terminology.
  • #61
MMX was the inspiration for Lorentz to explain the null result by saying that the physical dimension of the apparatus was contracted along the direction of the aether wind. Michelson, on the other hand, believed that he could not measure the aether wind because he thought the Earth was dragging the aether along with it.
  • #62
I don't think even the best physicst can explain exactly why time is a dimension. The best explanation I have read in any book written by one is that if they where to point out on a map the exact coordinates where you will meet them you would never be able to meet them there without knowing when they will be there. Then the time coordinate allows your meeting.
  • #63
Seems like even amateur physicists can explain exactly why time is a dimension.
  • #64
ghwellsjr said:
That's why I put "distance" in quotes, so that you would not take exception to my terminology because I can't tell what terminology you prefer.
Spacetime does not create the issue, nature does, and spacetime interval is a solution.
But you said you could solve the same problem that "spacetime interval" solves except by another method. Now are you telling me that you don't believe there is any solution?
Let's take, for example, the first half of the twin paradox. The twins (or two identical clocks) start out at the same age (or set to the same time) at the same location. One of them accelerates away and travels at a high speed for awhile and then decelerates and comes to rest with respect to the first twin (or clock) some distance away. This defines two events: the first is when the traveler starts out and the second is when the traveler stops. When this situation is analyzed from different frames of reference,different answers will be determined for the actual physical distance the traveler traversed and for the actual physical time that it took the traveler to make the trip. Do you agree? If yes, then how do you reconcile the different measurements of distance and time? If no, then please explain why.
No. I believe there's a fundamental error in the relativist's notion of distance. What's actually being measured as "distance" is actually "distance traveled". hence why "distance" is defined in terms of c. Relativity alludes to the qualitative static distance (between two objects or "events") but explains the theory with respect to dynamic distance traveled. Case in point is the phenomenon of "length contraction".
If I'm standing 20 yards away from a tree (where there's a measuring device) and a muon zips past me at near the speed of light, relativity theory says that the distance between the muon an the tree contracts. Now did the static distance between me and the tree shrink or was it the distance between the muon and the tree? And if the answer is the later, then say there's a rock between me and the tree, did the distance between the rock and tree also shrink?
cshum00 said:
You can as long as it is mathematically useful. Physical "spacial dimension" only has 3 dimensions x,y,z. Time is a dimension but not a spatial dimension. Because Special Relativity uses both spatial dimension and time dimension then we combine them so that it is mathematically useful and we call it "space-time dimension".
I am just saying that you were not defining dimension abstractly enough but you are rather defining spatial dimension in specific instead.
As far as I'm concerned, time is not a dimension. it's simply a number line. it's then endowed with orthogonality and combined with the 3 "spatial" dimensions. as such mathematicians have simply just created, lie u said, a useful framework for modeling the physics of objects in space.
Phrak said:
As in space alone, there is no preferred direction in spacetime that you can call the time direction. In this regard they are inseparable, unlike space+temperature, say. A Lorentz symmetry is more of a rotational symmetry, similar to rotating spatial vector.
So what's the preferred direction of temperature?
ghwellsjr said:
I hope you realize that the issue we are talking about isn't confined to distances between objects in empty space, the same issue exists between the shape of a single physical solid object on the surface of good old earth. The Michelson-Morley experiment is what started this whole thing. It was a single very large, very solid, very massive object that seemed to be changing its dimensions simply by being rotated. How do you understand Lorentz contraction when applied to MMX?
I understand it as an indirect inference from a null-experiment.
  • #65
In flat spacetime distance can be defined as coordinate separation in a consistent way. What is a ruler but a stick with coordinates marked off ? In SR each inertial observer has a set of coordinates and a definition of distance. The Lorentz transformation allows us to transform the coordinates between frames.
Which is what happens when a distance in one frame is expressed in the coordinates of another frame.
It is completely consistent and your assertion
is incorrect.
  • #66
SR says that in your rest frame, the muon itself is contracted but the distance the muon has to travel is not contracted. In the rest frame of the muon, the distance between you and the tree is contracted but not the muon itself. That's why it can survive long enough to make the trip.
There are two answers depending on whether you are using your rest frame or the rest frame of the muon. In your rest frame the distance between the rock and the tree does not shrink. In the rest frame of the muon, the distance between the rock and the tree is shrunk.
You can use either rest frame (or any other frame) to analyze the situation and they will all get the same answer, which is even though the half-life of the muon is too small for it to survive traveling "long" distances", from your rest frame, it survives because it's clocks are running slow and from its rest frame, it survives because it doesn't have very far to travel.
  • #67
Yes, that is very true. I'm glad you agree with me and everyone else on this point.
  • #68
Wow, what a question. Well, we all know that time is the duration it takes actions to happen. Time is the fourth dimension, as Einstein viewed it. People before Einstein, like Newton, viewed time as a definite quantity. They viewed it as a definite measurement that is the same for everybody. Then came Einstein, and said that time is in fact relative, it is not an equivalent quantity for everyone. First, he said that the ultimate speed of the universe is the speed of light (you can't go faster than the speed of light). He also said that time is a relative measurement, it depends on your speed; the closer you travel to the speed of light, the slower time beats. Also, time beats faster if you are away from gravitational pull (that's why our GPS works the way it does. It has to take General Theory of Relativity into consideration).That is our basic understanding of time.Time travel to the future is very possible, you just have to go on fast speeds and you age less than your twin, you are in some sense a traveler to the future, However, we don't really know for time travel to the past, because you can't change your past. There are also some new theories on time such as wormholes, and string theory's tiny curled up extra dimensions... The subject of time is really a huge subject, and physicists are still investigating on time.
  • #69
You are getting it all wrong. Time IS a dimension. The problem is that you are mixing between "spacial dimension" and dimension in general!
In math, dimension can be ANYTHING! as long as you can represent it on a number line and have it to be useful for mathematical representations and calculations.
In science, dimension takes a further step and says that it is anything that is a FUNDAMENTAL QUANTITY that that is why we assign a symbol for it's dimension.
http://en.wikipedia.org/wiki/Physical_quantity#Base_quantities.2C_derived_quantities_and_dimensions"
TIME is a FUNDAMENTAL QUANTITY! You don't have to trust the wiki link that i sent you but search and look around books and you will find that TIME IS INDEED A DIMENSION!
Stop being stubborn and saying that when a scientist say dimension they must mean spacial dimension; which IS NOT! Spacial dimension is a subset of dimension!
As for the word space part, mathematicians do use the word space when they could actually mean just dimension. Meaning when mathematicians say space, they don't mean spatial dimension but dimension in general and it occurs! And for scientists who have deep math background do so as well! That is why some people misunderstand that when some scientist say space referring to spatial dimension of space which might not be the case depending on the content of the speech!
  • #70
In Galilean spacetime time is surely a dimension, but is that the case in relativity?
I think in relativity time is the length of a path between two events in four dimensions. You think I am wrong?
  • #71
I think you are right. In the contents of your speech, you are clearly referring that the "length of a path" of the "four dimensions" that you are working on. Your thinking actually resembles to a filmstrip where each strip of the film is a point of the time path and inside each strip instead of a 2-D space dimension picture, you have a 3-D dimension picture.
Edit:I think that "path" is good enough. "Length of a path" would be more like the total amount of time specific time-frame.
  • #72
So it appears that you agree.
If that is so then time cannot be something else as well right? Thus do you agree that time is not a dimension?
  • #73
I am confused. How does agreeing that time is one of the 4 dimensions you mentioned leads to that time is not a dimension?
  • #74
Where did I write that "time is one of the 4 dimensions"?
  • #75
Ok, then what are those 4 dimensions then? If time is not one of those 4-dimensions then i would disagree. I guess that i did not get the right picture for your statement.
  • #76
Ok, so let's assume that one of the 4 dimensions is time then what is the length of a path between two events in those 4 dimensions?
  • #77
Ok, it would be like i mentioned before on my edit:
In other words, it would be the total amount of time that it takes from one event to the second event.
  • #78
Yes and that is not time?
  • #79
Passionflower, are you aware of the difference between coordinate time, which is one of the 4 dimensions of spacetime (for a given choice of coordinates), and proper time which is the "length" of a 4-dimensional curve or line (and is independent of any choice of coordinates)?
  • #80
@Passionflower
Ok, i think i got the root of our problem and the solution.
Let's start with your original statement:
"I think in relativity time is the length of a path between two events in four dimensions."
-First, i will modify your statement to: "Time is a path between two events in four dimensions."
-I remove the word relativity because i am not sure in which relativity you are referring to; the general or special. Also, specifying special relativity will make one of the four dimensions to time which in our case we don't want to.
-It is not length because they are two different things. For example, length would be like: it took five minutes for me to write my essay. While for time i would be saying, according to Easter Time clock, i finished my essay at 10:42AM.
-This will require us to look at dimension not as the scientific meaning of dimension but the mathematical one. When i say this, i mean anything CAN be a dimension.
-Saying that, we will look at event as a dimension. For example, e1 (event1), e2 (event2) and so on.
-So, according to the modified statement we are looking at time as t(e, x, y, z) where e=event, x=spacial-dimension1, y=spacial-dimension1, z=spacial-dimension3.
-In other words, time is a function of event, and 3 spatial dimensions. And length of the path of 2 points of time would be how much time lapsed between two events.
-This support the filmstrip idea where each event would be each snapshot on the film, and the difference in length between two film strips is the total time it took for those two events to happen.
Now, the next problem is when i said that time is one of the four dimensions.
-In the case of viewing time as part of the dimension, i would actually be defining event as a function of time and the 3 spatial dimensions or e(t, x, y, z).
-So, if we see time as a function of event, we would intuitively make event as a dimension.
-And if we make time as a dimension, we intuitively create an event function instead.
-Next, is what is the length of the path between two events? It is NOT the total amount of time between two events. I was wrong. Yes, sorry and i apologize. I don't know what it means unless we give a meaningful value to each point of event.
  • #81
Coordinate time is a dimension on a chart of spacetime. But mapping an observer's proper time onto the coordinate time axis of a chart is not the same as claiming that one single spacetime dimension represents time. It does not, time is represented by a path between two events inside this spacetime. For a Galilean spacetime you would be correct but not for a Minkowski spacetime.
While proper time always describes what a physical clock measures, coordinate time may or may not do that. Clearly coordinate time cannot be a dimension of time because if we have a simple spacetime with two observers taking a different path with a different length between two events then clearly coordinate time cannot represent time for both observers, time for each observer is the path length between the events not the coordinate time. Yes we can use different coordinates for each observer but then we are not talking about dimensions of spacetime but observer dependent charts where the proper time is modeled by using the time dimension of the coordinate chart for that particular observer.
Don't mix up a coordinate chart of spacetime with spacetime itself.
  • #82
Passionflower said:
I am but what is the point?
While proper time always describes what a physical clock measures, coordinate time may or may not do that. Clearly coordinate time cannot be a dimension of time because if we have a simple spacetime with two observers taking a different path with a different length between two events then clearly coordinate time cannot represent time for both observers, time for each observer is the path length between the events not the coordinate time. Yes we can use different coordinates for each observer but then we are not talking about dimensions of spacetime but simply observer dependent maps where the proper time is modeled by using the time axis of the coordinate chart for that particular observer. But then we mix up the chart with spacetime itself.
I am confused. Unless you mean something else by coordinate, isn't time as a coordinate the same as time being a dimension?
About the problem of two observers not being represented in a single graph is because each observer's coordinate system is shifted with respect to each other. For example, if my origin is not your origin but shifted on a certain way, then when i say this point of space, it won't be the same point of space in your coordinate system. That is why we need to do transformations.
Edit: BTW, did my previous post clear our misunderstandings.
Just because we are defining time as a function of other coordinates, it doesn't mean that time is not a dimension. For example, i would define a function to be z(x,y); but it doesn't mean that z is not a dimension. And most importantly, time is a fundamental quantity which adds the requirement of being a dimension for science.
  • #83
Think about the different between a coordinate system of spacetime and spacetime itself. Two different things.
So clearly you must realize you are dealing with charts of spacetime not spacetime itself.
Time is a path in spacetime not a dimension of spacetime. If time would be a dimension of spacetime all observers would agree on such time as is the case in Galilean spacetime.
  • #84
Then to clear things up, i have been using them as the same thing. I don't get what you mean by coordinate. Can you explain further?
I am confused here. How can you see time dilation if you are on the Galilean spacetime? The reason why Galilean relativity could not do gave discrepancy errors was is because it did not have transformation of coordinates (which is what Special Relativity did). I think your problem lies that you don't understand that each observer is in their own coordinate system which needs to be transformed to that they could agree on what they are observing.
  • #85
I don't understand that each observer is in their own coordinate system?
So let me try to follow you, each observer is in their own coordinate system and all these unique coordinate systems relate how to spacetime and in particular the specific dimension you claim is time?
  • #86
Not only time, but also for the 3-spacial dimensions too. There is also length contraction. I don't want to be rude but i am guessing that you didn't actually go through the mathematics of it but only read the conclusions instead. .Although the conclusions might be counter-intuitive, if you actually follow through the mathematics and the reason for such transformations; you should be able to have a better understanding of it
  • #87
As I said before I think that time is a path in spacetime not a dimension of spacetime. Feel free to introduce mathematics to show how wrong I am.
  • #88
The word space-time refes to 3-spacial dimensions and one time dimension!
Let's modify your statement so that you see what are you saying mathematically.
x is a path in x-y dimension not a dimension of x-y.
Or mathematically, x = x(x, y)!
I think you missed my last post on page 5. You got mixed with my other earlier comments. Read my last post on page 5 which clarifies our earlier arguments then come back and explain to me what you mean by coordinates and how come time is not a dimension since I am unable to picture your problem.
  • #89
Do you seriously think that such an argument would convince me?
Or mathematically, x = x(x, y)!t
Surely you must be joking!
  • #90
No, i am not trying to convince you. It is the truth. Research the word spacetime. It is just like i said. It means 3-spacial dimensions and one time dimension.
http://en.wikipedia.org/wiki/Spacetime
No, i am not joking. Ask a mathematician to translate that statement to math for you and see what you get. I might be wrong but your statement is just as outrageous as it is.
  • · Replies 16 ·
  • · Replies 71 ·
  • · Replies 20 ·
  • · Replies 54 ·
  • · Replies 16 ·
