What is the true nature of time?
  • Thread starter Thread starter Parbat
    Mean Time
The discussion centers on the nature of time, exploring its definition, its status as a dimension, and its relationship to space and events. Participants engage with conceptual, theoretical, and philosophical aspects of time, including its implications in physics and relativity.
  • Some participants question the meaning of "time" and express uncertainty about its definition.
  • One participant cites Richard Feynman's perspective that time is what happens when nothing else is happening, suggesting a subjective understanding of time.
  • There is a discussion about whether time can be considered a dimension, with some participants arguing that dimensions are necessary to explain objects, while others challenge this notion.
  • Participants explore the relationship between dimensions, coordinates, and vectors, noting that dimensions are static while vectors are dynamic.
  • One participant raises the idea that time is a one-dimensional quantity used to sequence events, but questions how this aligns with the qualitative attributes of directionality and orthogonality.
  • Another participant suggests that time dilation's relationship with gravity could imply that time might be thought of as a force or energy, although they acknowledge the terminology may not be precise.
  • There is a discussion about the implications of coordinate systems in analyzing events, with some participants asserting that the choice of coordinate system should not affect the analysis.
Participants do not reach a consensus on the nature of time or its classification as a dimension. Multiple competing views remain, with ongoing debate about the definitions and implications of time in physics.
Participants express various assumptions about the definitions of dimensions, coordinates, and how they relate to time. There are unresolved questions about the implications of time dilation and the consistency required in scientific terminology.
  • #151
Passionflower said:
A spacetime interval is the distance between two events in spacetime this is not necessarily the same as the length of an observer's path between two events. In some cases however they could be identical namely in the case the observer takes the largest possible travel time between these events.
This is not a post telling people how to use various terms but just a post to explain the difficulties I find. Perhaps it will help others.
I find that the mathematical definition of the spacetime interval describes umambiguously, as of course a mathematical definition should do, what the interval means. As has been said, and something of which I am also guilty, using imprecise words or words which can have varied meanings does not help. The problem I find with using words to describe the interval is finding ones that convey the idea of a straight line in spacetime. The value of the interval is usually not the same as that of the path, although if the object is traveling inertially it is, and so the interval is often loosely defined as a the legth of a straight line path between events.
I seem to remember in an early section of Eddington's classic Mathematics of General Relativity that he describes the interval and proper time as measures rather than lengths or times.
Matheinste.
  • #152
Passionflower said:
All observers in our universe observe proper time all the other times are really 'make believe times'.
Nonetheless, it is one of the common meanings for the word "time" and when you want to refer to this meaning you should clarify by using the term "coordinate time". The fact that you dislike "coordinate time" does not make the concept go away, and people who seek to communicate their ideas should be aware of it and be clear about it.
Your whole approach on this thread is to be sloppy and unclear about your terminology. You have presented a bunch of correct arguments about why coordinate time is coordinate dependent and therefore not a dimension in a coordinate-independent sense. If you had simply used the phrase "coordinate time" you could have saved yourself a lot of writing and a lot of disagreement.
Passionflower said:
Could you please point out in the above referenced spacetime diagram where you think the time dimension is?
Sure. As soon as you point out on the surface of a piece of paper where the x and y dimensions are.
  • #153
Passionflower said:
ghwellsjr said:
Passionflower, are you ever going to answer my question, are you talking about the "spacetime interval"?
In any and all those cases where they are identical, do you have any problem, issue, complaint, concern or question with the spacetime interval?
  • #154
Dalespam I am trying to understand your position, you accuse me of being sloppy so I take it you have no objection to give your exact position about time being a dimension of spacetime. Since you seem to agree that time as measured by a clock is the length of a path in spacetime it appears that you find that our universe has two measures of time.
Earlier in this thread you wrote:
DaleSpam said:
Seems like even amateur physicists can explain exactly why time is a dimension.
Are you still supporting this statement? And do you think this statement is exact (e.g. not sloppy)?
So please explain exactly why time is a dimension.
So what are you implying that time is a dimension of spacetime but only in a coordinate dependent way?
With regards to being sloppy, I find it sloppy to state that "time is a dimension of spacetime". Time is what a clock measures, the time between two events for a clock is the path the clock travels between these two events in spacetime. A path is clearly not a dimension.
  • #155
cshum00 said:
You are getting it all wrong. Time IS a dimension. The problem is that you are mixing between "spacial dimension" and dimension in general!
In math, dimension can be ANYTHING! as long as you can represent it on a number line and have it to be useful for mathematical representations and calculations.
In science, dimension takes a further step and says that it is anything that is a FUNDAMENTAL QUANTITY that that is why we assign a symbol for it's dimension.
http://en.wikipedia.org/wiki/Physical_quantity#Base_quantities.2C_derived_quantities_and_dimensions"
TIME is a FUNDAMENTAL QUANTITY! You don't have to trust the wiki link that i sent you but search and look around books and you will find that TIME IS INDEED A DIMENSION!
Stop being stubborn and saying that when a scientist say dimension they must mean spacial dimension; which IS NOT! Spacial dimension is a subset of dimension!
As for the word space part, mathematicians do use the word space when they could actually mean just dimension. Meaning when mathematicians say space, they don't mean spatial dimension but dimension in general and it occurs! And for scientists who have deep math background do so as well! That is why some people misunderstand that when some scientist say space referring to spatial dimension of space which might not be the case depending on the content of the speech!
No. I'm not the one mixing dimensions here. Define a term within a given context and stick to it. I have no issue with that. What i have issue with is when terms are used inconsistently within the same dissertation. x,y,z as dimensions are used to ascribe structure and shape to physical objects. u now add an extra dimension (time) to this framework that has nothing to do with shape or structure. but it's treated geometrically, the same as x,y,z...dilated, warped, distorted, etc. So if time is a fundamental QUANTITY of matter, what is the time of a brick? I can tell u the length, width and height by simply measuring it.
  • #156
I can tell you the duration of a brick simply by measuring it also.
  • #157
:confused: the duration of a brick? please explain.
  • #158
Can you measure the distance from one corner of a brick to the opposite corner? For example, can you measure how far it is from the front, lower left corner to the rear, upper right corner?
  • #159
cshum00 said:
I love philosophy myself but there are reasons things have a solid definitions in science so that they don't get tossed around with multiple meanings.
funny u say this because i stated this in one of my first posts but when a dimension can be literally anything that kind of sets the stage for lots of confusion doesn't it?
  • #160
yes. with a brick it's going to be tricky, but with a wooden block, a saw and some measuring tape. Why?
  • #161
Sure. The length, width, and height are the distances from where it begins to where it ends in three orthogonal directions. Similarly there is a duration from when it begins to when it ends. It is exactly analogous to length, width, and height.
If your qualification for something being a dimension is that it be related to the extent of a brick then time is clearly a dimension.
  • #162
My personal position is that the three different usages of the word "time" I mentioned earlier are all legitimate (https://www.physicsforums.com/showpost.php?p=3003323&postcount=114) and you are confusing the issue by using different definitions interchangeably.
Spacetime is a 4D pseudo-Riemannian manifold with three dimensions of space and one dimension of time. Do you understand what this means both mathematically and physically? Do you understand that the dimensionality and the signature of a manifold are coordinate-independent invariants? This is the first meaning that I described.
Time is also the label given to the timelike vector of an orthonormal basis at any point in the manifold. Since there are an infinite number of basis sets this vector is not unique. Also, since usually an orthonormal basis is constructed from the coordinates this basis usually depends on the coordinates. This is the second meaning that I described and is usually identified by the clarifying phrase "coordinate time".
Passionflower said:
Proper Time is what a clock measures, the time between two events for a clock is the "length" of the path the clock travels between these two events in spacetime. A length of a path is clearly not a dimension.
I have clarified your statement, which was essentially correct. This is the third meaning that I described and is usually identified by the phrase "proper time".
The problem with this thread is that you have your preferred definition for the word time (proper time) and refuse to admit that it is common for words to have multiple meanings. You are not the supreme leader of science, and it is not up to you to unilaterally change definitions. There are multiple meanings to many words and if you would like to contribute usefully then you should be familiar with them all. You are correct that proper time is not a dimension, you are incorrect to conclude that there is therefore no sense in which time is a dimension.
"There's a sign on the wall
But she wants to be sure
'Cause you know sometimes words have
Two meanings"
-Led Zeppelin, Stairway to Heaven
  • #163
Do you agree that whatever tricky means you are considering is not measuring the diagonal distance of the brick but an indirect method that you assume will give you the same answer?
And do you agree that you could also have measured the height, length, and width of the brick and calculated the diagonal distance by taking the square root of the sum of the squares of the three measurements and you would get exactly the same answer?
  • #164
Ok, to clear the problems with whether time is a dimension or not i guess we would have to re-state the definition of various terms and how each term relate to each other.
Vetors
a) Vector is a quantity that has both a magnitude and direction.
b) When representating a vector on a coordinate system, the tail of the vector can be positioned on top of any point of the coordinate system; which makes the vector independent from a specific location or independent of any point of reference.
c) There are vector operations that allow us to re-shape, shift, rotate and transform vectors.
Dimensions
-Mathematical definition of dimensions:
a) Dimensions are special vectors where these vectors will become part of number lines for a new coordinate system.
b) The relation of each vectorial space may and may not be of an orthogonal basis.
-Scientific definition of dimensions:
a) For the purpose of calculations, it has the same as the mathematical meaning except;
b) a dimension (in science) must be a fundamental quantity and because of its importance it is given a fundamental unit for the purpose of dimensional analysis.
Fundamental Unit and Quantity
Is an important quantity which can be measured and which other units will be based on. For example, force is made of the fundamental quantities of mass, time and length.
Dimensional Analysis
Is a way to make sure that a calculation is done correctly and that the computation done does not mix different units improperly.
Time
a) Time is a measuring system used to sequence events, to compare the durations of events and the intervals between them.
b) Time is a fundamental quantity and bears the fundamental units of seconds.
Proper Time thanks to DaleSpam for clarifying
Is the time elapsed by a moving or accelerating observer.
The way proper time is measured is the follows:
-From the relation between proper time and time of the outside observer in spacetime:
[tex]\Delta t = \frac{\Delta t_p}{\sqrt {1 - \frac {(\Delta x)^2 + (\Delta y)^2 + (\Delta z)^2 }{c}}}[/tex]
-Solve for proper time and in a continuous curve, [tex]\Delta[/tex] is replaced with [tex]d[/tex].
[tex]dt_p = \sqrt {{1 - \frac {(dx)^2 + (dy)^2 + (dz)^2}{c}} dt[/tex]
-Integrate both sides:
[tex]t_p = \int_D \sqrt {1 - \frac{(dx)^2 + (dy)^2 + (dz)^2}{c}} dt[/tex]
Which is the line integral of a path or curve D.
@Passionflower
-First, proper time only defines the time of a moving or accelerating observer.
-To define the time for a an observer that it not accelerating, you would still have to transform the proper time so that you get the time for the non-accelerating observer.
-Proper time is the total amount of time elapsed by someone who is accelerating. Meaning it is scalar and not the measuring system as i defined time.
-What are the units of the proper time? It is still seconds. And applying dimensional analysis i still get that the proper time is just a point or group of points or value of the dimensional system of time.
-Proper time does not say anything about time not being a dimension; it is just saying that an accelerating observer is experiencing a different rate of time flow.
@TheAlkemist
Fundamental quantity does not refer to matter but to the real world in general. The real world is not only composed of matter but also space which in our case we use length. It is also composed of matter which is why we use mass. It is also composed of sequence of events which is why we use time.
Let's say this, if fundamental quantity only refers to matter then length can't be a fundamental quantity. Just because you are specifying what is the volume you don't necessarily specify its mass because it could have variable density.
Please TheAlkemist, read about fundamental quantities and dimensional analysis.
  • #165
Proper time is what a clock measures, all observer's measure proper time on their clock regardless of their state of motion.
By the way an observer has only two states, inertial and accelerating. Whether an observer is moving is obviously a relative concept since there is no such thing as absolute motion and absolute time in relativity. (thing to think about in this context: if there is no absolute time and space are time and space really dimensions in Minkowski spacetime?)
The time for a non-accelerating observers is the time on his clock and this is his proper time.
Accelerating or not, an observer's clock measures proper time, always.
You could take any unit you want.
Time flows at one second per second for all observers.
  • #166
that's not my definition. I suggest we stick to my actually definition of dimension: a concept used to specify the structure/orientation or shape/geometry of a physical object. These are qualitative attributes. Duration is a quantitative attribute.
my first post in this thread: https://www.physicsforums.com/showpost.php?p=2961415&postcount=4
Time is a quantifier of the duration or intervals between events.
I point to an object and ask u what shape is it. If it has a defined shape u name it (square, octogon, tetrahedron, etc). If it doesn't u qualify it with it's dimensions. I might ask you how long, wide or high is it. You go measure it with a calibrated device. I point to the same object again and i ask u, what time is it. Please tell me how u go about answering this. Thanks.
  • #167
I agree with this. A word can have a meaning within a specific context that different from it's meaning in another. This is how language is. My problem, what confuses me, is when a word's meaning in one context is applied in another different context. Don't u see how this can be an issue?
  • #168
Yes, in the first case you're right! I just realized that. And you're also right in the second case. The only way i can measure the internal dimension of a continuous solid object is by inference--if this is what u mean by "indirect method". Now I'm assuming you're about to tell me how this is related to or analogous with the measurement of the time of this object?
  • #169
Did you read my entire post or only my direct dialog for you? If you read the entire post you should have seen how things piece together.
Yes, that is correct.
Yes, i agree that there is no such thing as absolute motion or absolute time.
Yes, even if there is no absolute time and space they are still dimensions in Minkowski spacetime. I know you have an idea of Minkowski spacetime, but read about it again. I bet you will see that Minkowski treat space and time as dimensions.
Yes, that is right but it still doesn't say anything about it not being a dimension.
You mean i should say it can be kilograms when it is seconds? Just kidding. I know you mean take any measurable unit that is used for time.
Yes and no. Proper time of an observer or of observers that are on the same rate of motion have the same rate of second per second time flow. However, for observers whose rate of motion is not the same, a second being elapsed in my proper time can be a day on the elapsed proper time of another observer.
Here is the problem of treating time in general as proper time. Because everyone has their own proper time, i know how much time has passed between two events in my time but i don't know how much it has lapsed in your proper time.
In order to calculate how much time has lapsed in your proper time, we have to treat time in general as a dimension and then do vector transformations so that my proper time dimension looks the same as yours. Then i can say what time your proper time measured.
  • #170
This is absolutely not true. SR is all about picking one single frame of reference at a time. In that frame, all times and positions, and therefore, all states of motion are absolute. A frame is a coordinate system of three dimensions of space and one of time. The locations and motions of all objects, observers, clocks, rulers, and anything else you want to consider are defined and discussed in terms of that one reference frame. Then, if you want, you can transform everything into a new reference frame that is relative to the first one and calculate the new times and positions of all the same objects, observers, clock, rulers, etc.
It is a mistake, a misunderstanding and an abuse of SR to think that every object, observer, clock, ruler, etc. is in its own frame relative to all the other objects, observers, clocks, rulers, etc. in their own frames all at the same time.
  • #171
No, I wasn't going to introduce time into the discussion, at least, not yet.
What I wanted to point out is that if you have two different ways to determine a distance between two points (diagonally opposite corners of a brick), one where you actually made a measurement, which is what I thought you were suggesting, something along the lines of placing the brick between two objects and then measuring the distance between the objects and the other where you measure some other components, the three dimensions of the brick and then calculate the distance, they both should yield the same result. In other words, any meaningful determination of a parameter that we want to discuss, like the "distance" between two points, should always get the same answer, don't you agree?
  • #172
Passionflower--
Are you ever going to answer my question?
  • #173
"Time is what happens when nothing else is happening"
Surely if NOTHING else is happening, time stands still. If nothing is happening, everything is frozen, nothing moves and that includes clocks. If clocks do not move there is no time. ie. NOTHING moving equals no time passing.
  • #174
I guess you didn't notice the tongue in Richard Feynman's cheek.
  • #175
There is a difference between a measurement problem and a fundamental one. For space as we experience it to exist, time is involved as a fourth dimension... and if that were to "go away", the universe would be VERY different. It's not a lack of activity that stops time, that just makes it meaningless from a large perspective (like eventual universal heat death).
  • #176
"I guess you didn't notice the tongue in Richard Feynman's cheek"
No, only replying to second post in this thread, so what did Richard Feynman mean?
"For space as we experience it to exist, time is involved as a fourth dimension and if that were go away..."
Obviously the universe is never going to stand still, this is hypothetical, but I do not see how time can pass/exist IF there is no movement. If nothing moves, nothing changes and time is all about change.
  • #177
This thread is on its 11th page, well past the initial clarifying of the question and into the nuts and bolts. Asking about what a throw-away quote from post 2 at this point is tantamount to a derailment of the thread.
  • #178
Is there anything fundamentally wrong with defining a dimension as: any metric required to specify the location of an event?
I believe Brian Greene used this definition to great success. Certainly, it leaves out the details of coordinate stretching, but as far as specifying what could qualify as a dimension, surely this is a reasonable start?
In physical theories including additional spacetime dimensions, the only reason that these dimensions are necessary is because they are used to explain the location of an event which does not adequately "fit" in traditional 4D spacetime.
I happen to like the "office building" analogy. In order to specify the location of a meeting, you need the floor number, the 2D location on that floor, and the correct time. Four dimensions o specify the location of an event.
  • #179
"...tantamount to a derailment of the thread"
Point was, with regard to recent discussion over time being another dimension, if its' existence is dependent on relative movement/change then surely it is not a dimension in its' own right.
  • #180
That is certainly an interesting point. If the entire word were to be at halt in motion then each proper time will lead to zero since the line integral of a zero path is zero.
What about your point of view? Do you think that time is dependent or independent? Special Relativity says it is dependent but with your example i think it should be dependent. So i am in a state of confusion at the moment.
  • · Replies 16 ·
  • · Replies 71 ·
  • · Replies 20 ·
  • · Replies 54 ·
  • · Replies 16 ·
