What is the vacuum wavelength of the incident light in nm?
  • Thread starter Thread starter NeedsHelp1212
    Interference
The vacuum wavelength of light incident on a soap film with a refractive index of 1.33 and a thickness of 296 nm is calculated to be 395 nm in the medium. To find the vacuum wavelength, the medium wavelength must be multiplied by the refractive index. Thus, the vacuum wavelength is determined to be 395 nm multiplied by 1.33, resulting in approximately 526.35 nm. The discussion clarifies the relationship between the wavelength in the medium and the vacuum wavelength using the equation for destructive interference.
  • Understanding of wave optics, specifically destructive interference.
  • Familiarity with the concept of refractive index.
  • Knowledge of the relationship between wavelength in a medium and vacuum wavelength.
  • Proficiency in algebra for solving equations.
  • Study the principles of wave optics, focusing on interference patterns.
  • Learn about the calculation of wavelengths in different media using Snell's Law.
  • Explore the applications of refractive index in optical devices.
  • Investigate the effects of film thickness on interference in thin films.
Students studying physics, particularly those focusing on optics, as well as educators teaching wave interference concepts and anyone interested in the practical applications of refractive indices in optical phenomena.
NeedsHelp1212
When monochromatic light shines perpendicularly on a soap film (n = 1.33) with air on each side, the second smallest nonzero film thickness for which destructive interference of reflected light is observed is 296 nm. What is the vacuum wavelength of the light in nm?
My teacher gave me this equation for destructive interference, it seems to differ from others but I am going to go with it: 2t + 1/2 lambda = (m) (lambda)
2 (296) + 1/2 lambda = 2 lambda
592 + 1/2 lambda = 2 lambda
592= 1.5 lambda
lambda= 395 nm
The question asks what is the wavelength in the vacuum. I am confused? Did i just solve for the wavelength in the vacuum or for the wavelength in the medium? Because if its for the medium i know i would do n = lambda vac/ lambda med. So lambda vac = lambda med times n = 395 * 1.333
Im not sure what to do... please help
Here's the logic: For destructive interference, there are n+1/2 wavelengths along the path in the medium, where n is an integer. The path is twice the thickness, so the equation is:
2t = (n+1/2) lambda.
Your prof's equation is the same except that his m is one bigger than my n.
The thinnest film has n=0. The one you want has n=1.
That lambda is the one in the medium, so indeed, you have to convert to the free space wavelength by multiplying by the refractive index.
He went over it all, thank you for the help as well! I get it now
