What is the voltage across the resistor?
  • Thread starter Thread starter JayLewis
    Resistor Voltage
The discussion revolves around calculating the voltage across a resistor in a series circuit with a total voltage of 17 V, an inductor voltage of 30 V, and a capacitor voltage of 22 V. Participants are using complex numbers to analyze the circuit but express confusion regarding the instructions and the calculations. The calculations involve complex impedance, but the reasoning behind the steps taken is not clearly articulated. Suggestions are made to consider the circuit driven by a fixed AC current source to better understand the complex voltages across the components. Clarity in the instructions and methodology is emphasized as essential for solving the problem accurately.
JayLewis
The amplitude of the voltage across an entire series circuit is 17 V. The inductor alone has an amplitude of 30 V and across the capacitor it is 22 V. To the nearest tenth, what is the voltage across the resistor?
(17+8i)(17-8i)
289+64
square root of 353
18.8
(17+8i)(17-8i)
289+64
square root of 353
18.8
Hello JayLewis, Welcome to Physics Forums.
Can you explain the reasoning behind your attempt?
I was trying to follow steps from handout
I was trying to follow steps from handout..this is the first time we have worked onthis and I don't understand it.
Okay. I see that you're making use of complex numbers, so I assume that you're familiar with (or at least learning about) the concept of complex impedance and voltage and current. Is that right?
we are learning about it now
but the instructions aren't very clear
here is the rest of my work:
374-510i
_________
484+900
374-510i
_________
1384
.27-.37i
.07+.14
.21
374-510i
_________
484+900
374-510i
_________
1384
.27-.37i
.07+.14
.21
It's difficult to comment on your work since it's not annotated. What is it you're doing here?
If I may make a suggestion, suppose you consider the series RLC circuit being driven by a fixed AC current source. What would be the complex values of the potentials across the capacitor and inductor?
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
