What is the wave in the double slit experiment?
  • Level: Graduate
  • Thread starter Thread starter DParlevliet
    Photon Shape Wave
67 replies · 45K views
craigi said:
Then you still misunderstand the experiment. If the intensity at each slit is equal, from a single light source, then complete destructive interference occurs at all points where the difference in distance from each slit is one half wavelength.
I thought you told before that there is no complete destructive interference because there must be difference in r: one path l, second path l + half wavelength. And difference in wavelength is difference in 1/r2
But in case 2, the omni-directional light source is replaced by a source with a parrallel beam. What is the shape of the wave of one photon when it approaches the slits? I suppose a flat wave.
mfb said:
Right.
- How far to the left and right does this flat wave extend (compared to the position of the slits)?
- The photon was generated upwards in the parrallel beam, did it directly after emission also have this flat wave?
It extends across the width of the beam, which in turn depends on the size and construction of the apparatus that produces it.
Apologies. Now I see what you mean.
The visible spectrum has wavelengths of 380-750 nm. Half a wavelength is say, 300 nm, this does introduce a very small difference in amplitude from the components of the wave function from each slit, as we move from the central point of the interference pattern.
If the distance between the slits and the screen is about 1m, the intensities from each component at the first minimum on the interference pattern, have a ratio of about 1+6x10-7. This difference is less than 1 part in 1 million and is negligble, but strictly, you are correct this isn't complete destructive interference. In reality, you would never be able to get the light source equidistant from the 2 slits to this level of accuracy.
You should be aware that this is also true of a parallel light beam, as in your other example, since the slits diffract the light and you need to measure the distance from the slit to the point on the interference pattern.
So if (as thought experiment) the beam is a kilometer wide (still parrallel), the wave would extend for a kilometer with the same amplitude?
If beam were perfectly collimated and evenly distributed, then yes, the wave would have exactly the same amplitude everywhere.
... first I thought that I indeed did overlook that in my earlier post. But what is r with a parrallel beam? With an omni-directional light source this is the distance between source and position of absorption. When you move the light source further away, r becomes longer, r / (r + halve wavelength) closer to 1. When the source is infinite far away, the beam is parrallel... and waves equal
craigi said:
If it were perfectly collimated and evenly distributed, then yes, the wave would have exactly the same amplitude everywhere.
And just after emission of this photon (suppose it is electronicly triggered emission),
- are there waves in front of the emittor?
- do they have equal amplitude towards the slits?
- If so, how far (in the direction of the experiment) does the waves extend?
This isn't strictly true. You need to follow the path. In the case of a point source. It's the distance from the source to the slit plus the distance from the the slit to the point on the screen.
For a parallel coherent beam hitting the slits, you can just measure r from the slits.
The thing to remember here is that the slit spreads out the light through diffraction. The spread is not uniformly omni-directional, the idea that the intensity is proportional to 1/r2 from that point forward, is a crude approximation. When the wave from an omni-directional point source his the slits, the intensity at the slit, is actually proportional to 1/r2.
-yes, but the common terminology would be "a wave". Though waves can be made from a combination of other waves. Remember superposition? We'd tend to start off with the notion of one wave per particle, but can consider that going on to produce 2 new waves when it hits the slits for example, but they can equally, be considered all the same wave.
-yes
-it goes off to infinity until it hits something. It propogates forward at the speed of the particle (the speed of light, in the case of the photon).
Alright, now I see. It has two steps. First the r between source and slits, then a new r between slits and absorption. The slits are then new sources (which in fact they are).
So if the source is in the middle the somewhat less destructive interference will be the same for an omnidiractional source and parrallel beam.
craigi;4536701-it goes off to infinity until it hits something. It propogates forward at the speed of the particle (the speed of light said:
If the wave has traveled half way (calculated with emission time and light speed
- is there also a wave behind this (half-way) position?
- does it have the same (maximum) amplitude backwards?
- if so, does it extend backwards until the emittor?
- does it proporgate in the same direction as the above discussed "in front" wave?
Remember that the wave represents the probability of finding the particle and a photon always travels at the speed of light.
Yes, therefore I am interrested in the answers. With the wave in front I tought I got you in my trap, but now you become suspicious :)
Interference takes place between waves which are shifted 0.5, 1.5... in phase, so shifted in time, so there must about equal wavelengths before and after the absorbed photon. On the other hand the propability of the photon being before or after its average (light speed) calculated position becomes smaller. What shape will saftisfy both demands? I hope you will find an answer.
What was the trap and what should I be suspicious of?
craigi said:
-yes
-yes
Then just after emission of this photon the propability that this photon arrives at the slit (is able to be absorbed there) is the same as the photon is still near the emittor. That cannot be true, because as you mentioned later on a photon always travels at the speed of light, so needs some time to arrive at the slit.
But if there is no trap (it is still QM): what are the answers on my last questions of the backward wave part?
I think I see what you mean now.
What I meant was that the wave infront of the emitter got there by propagating at the speed of light from the source and that for an evenly distributed source, the amplitude is equal at each slit when it gets there.
What you're talking about is an equal amplitude across the length of a beam for a single photon. This doesn't happen, in the observer's rest frame. At risk of confusing this thread even further, a photon in a vacuum travels no distance in its own rest frame. The entire universe is contracted along its direction of travel.
Where did you get the idea of the backwards wave from? Why would there be a backwards wave? Did this originate from the idea that the wave for a single photon has the same amplitude across the entire length of the beam?
To be clear, QM waves must overlap in space and time for interference to occur.
I did not mean backwards, but at the back. I don't expect the same amplitude. I expect something like this: [PLAIN]http://upload.wikimedia.org/wikipedia/commons/b/b0/Wave_packet_%28dispersion%29.gif. So to come back to the start of this topic: what is the shape.
The animation that you have there is commonly used to decipt the shape of a photon.
Is there something about it that you're not happy with?
It is the shape of a particle with mass (solution of SV in Wikipedia). Probably a photon will look alike, but different in length. I suppose there is a formulea for the envelop of the peaks?
I started the topic with the assumption that at all "cancel" positions on the detector both waves cancel fully, and then the wave of a photon must be equal in size everywhere. If that is not the case, the wave (tops) decrease in time, and I like to know how fast.
The "wave tops" being the amplitude of the wave?
Yes, if amplitude in English is the maximum of the sinus.
You have been given the answer before. There is absolutely no intrinsic shape of a photon. It really depends only on geometry. This is completely equivalent to the classical electromagnetic field. You can get any shape that is possible for a classical field also for a single photon. In fact, the probability amplitudes on the single photon level and the classical fields will usually look exactly the same. You can even give a single photon arbitrary shaping by pulse shaping it like a classical light pulse (see Specht et al., "Phase shaping of single-photon wave packets", Nature Photonics 3, 469 - 472 (2009)http://www.nature.com/nphoton/journal/v3/n8/abs/nphoton.2009.115.html)
This is somewhat complicated for extended geometries as changes in the field travel at the speed of light and you need to be able to create quite some large uncertainty in the exact time of emission (long coherence) to be able to achieve that.
DParlevliet: a note of caution...I already posted this stuff is a bit 'crazy'...You cannot get a single all encompassing explanation of 'what particle looks like'...nor 'shape of a photon wave'. What the wave equation 'means' remains a debate.
A particle has no size at detection...it is a point particle. How do you describe such a thing in words. Nobody knows what a particle looks like between detections. The wave function and wave packets are our abstract attempts to quantify the evolution of a particle in time. Usually in abstract Hilbert space.
Be cautious about thinking the wave packet animation is 'what a particle looks like'; be cautious when thinking the wave is a means of physical interaction. As craigi already posted, the wave function is generally thought of as a probability of locating the 'particle'. One way to think about this crazy situation is that the center of a wave packet acts as a classical point particle.
But the wave is NOT classical, not observable: A wave function [like the Schrödinger one] (also more appropriately named as statefunction) in quantum mechanics describes the quantum state of a particle and how it behaves. Typically, its values are complex numbers. The probability is given by the product of the quantum state times it’s complex conjugate…because that WORKS...there are no first principles from which that crazy process can be developed. That is where our representation goes from deterministic to probabilistic.
In quantum field [wave] theory, modes with positive frequencies correspond [represent] real particles, those with negative frequencies correspond to antiparticles, and complex numbers correspond to virtual particles.
So all the prior posts should be taken in the limited context of how we model particle characteristics between detections rather than some exact physical picture.
Naty1 said:
... Nobody knows what a particle looks like between detections ...
I'd go even further than that. I'd say it doesn't look like anything. It can't, by definition, because to look at it would involve detection and we know it isn't the same as when it's detected.
I posted...
...be cautious when thinking the wave is a means of physical interaction.
I see I left out a corresponding thought:
the 'wave' can't be physical, limited to speed 'c' because as craigi posted it seems to extend to infinity...so entanglement [faster than 'c' effects] become problematic... The extension of the wave to the cosmological horizon during inflation [which causes particle production] would never have produced photons [CMBR] because that horizon was receding faster than 'c'...
so the 'wave' and wave packet remain enigmatic.
The double slit measures the wave, so there is only the wave, not the particle. So I don't ask what the particle is, I don't ask what the wave is, I just ask about its shape.
This
is good enough for me. It is an accurate image of the formulae (Schrödinger solution, Wiki). But what is the Schrödinger solution for a photon. The geometry is explained before.
So finally: the interference pattern shows that the shape of the wave of one photon is stable and predictable, when seen as an approximation. Does anyone know this shape?
You still don't get it, DParlevliet. You still don't get it. All right, suppose we tell you the shape is a Gaussian. :rolleyes:
Just for clarity, not to pick pick:
No. No one has posted such a thing. Any measurement is pointlike localized particle.
No. it depends on geometry...There is a graphical illustration of a different sort of what happens to be a matter wave here...at the top of the page on the right in yellow and blue:
Matter wave
http://en.wikipedia.org/wiki/De_broglie_wavelength
It illustrates the real and imaginary components of the location probability amplitude I mentioned earlier.
Note again this is a description of location probability NOT the 'shape' of the matter particle itself.
I hope I mentioned in my first post the necessity for rereading explanations such as these posts several times so you [anyone] can absorb it; You have to change the way you think when moving from classical to quantum realms.
Maybe try rereading slowly, reviewing carefully, from the beginning?...or try searching and reading some other discussions here...or Wikipedia explanations...
good luck...
This
The animation that you have have there is like an artistic representation of photon. Let's take a look at what you can take from it and what you shouldn't.
Firstly it's one dimensional. Real photons exist in three dimensions. The vertical dimension is what they're using to depict the quantities that it's carrying, like when you plot a value on a graph.
The envelope (the Gaussian), is a plausible depiction, for the probability of finding a photon at a particular positon. It's just an example. Not all photons can be found with that probability distribution.
The envelope is moving forward, indicating that it represents a freely moving particle, with a precise momentum. If the photon were to interact geometrically or there were uncertainty about its momentum, that envelope would be different. Though in this case, the depiction is one dimensional, so the momentum must be a constant, though there are arrangements that could split it.
The wave pattern in the middle of the envelope is an artisic representation of the wavelength of the electromagnetic radation transmitted by that photon. That wavelength is relevant when the photon interacts with other photons and charged particles.
Because the photon has zero rest mass and travels at the speed of light, there is no solution to the Schrödinger equation for a photon.
A photon is a particle of electromagnetic radation. The understanding of this predates quantum physics. It can tell you more about what photons actually carry, than you would typically learn from quantum mechanics http://en.wikipedia.org/wiki/Electromagnetic_radiation.
I know this doesn't answer the question in the manner which you'd like. Perhaps, it would be more meaningful to ask about the geometrical arrangements that do and don't give rise to single photon self-interference due to time separation.
Finally, I'd like to say: don't be demoralised, if you're struggling to get your head around it. Learning about QM is as much about unlearning as it is learning.
I came across this description...about how difficult it is to describe the wavefuntion...wave packet, etc...
Schrödinger was smart enough the develop his "Schrödinger wave equation" based on the particle/wave duality of de Broglie, to show his equation equivalent to the other major formulation of the day, , the matrix mechanics of Heisenberg, even formulate what became the Klein-Gorden equation, but could not apparently change his way of thinking enough to adapt to the new insights available! http://en.wikipedia.org/wiki/Schrödinger_equation#Historical_background_and_development
The Schrödinger equation details the behavior of ψ but says nothing of its nature. Schrödinger tried to interpret it as a charge density in his fourth paper, but he was unsuccessful.[18] In 1926, just a few days after Schrödinger's fourth and final paper was published, Max Born successfully interpreted ψ as the probability amplitude, whose absolute square is equal to probability density.[19] Schrödinger, though, always opposed a statistical or probabilistic approach, with its associated discontinuities—much like Einstein, who believed that quantum mechanics was a statistical approximation to an underlying deterministic theory— and never reconciled with the Copenhagen interpretation.[20]
Louis de Broglie in his later years has proposed a real valued wave function connected to the complex wave function by a proportionality constant and developed the De Broglie–Bohm theory.
