What is the wavelength of a photon that has energy of 2.10eV
The wavelength of a photon with an energy of 2.10 eV can be calculated using the formula λ = h / E, where h is Planck's constant (6.626 x 10^-34 J·s) and E is the energy in joules. Converting 2.10 eV to joules gives approximately 3.36 x 10^-19 J. Therefore, the wavelength is calculated as λ = (6.626 x 10^-34 J·s) / (3.36 x 10^-19 J), resulting in a wavelength of approximately 1.97 x 10^-15 m. This calculation is essential for understanding photon behavior in quantum mechanics.
  • Understanding of photon energy and wavelength relationship
  • Familiarity with Planck's constant and its application
  • Basic knowledge of energy unit conversions (eV to J)
  • Concept of wave-particle duality in quantum mechanics
  • Learn about the photoelectric effect and its implications
  • Study the concept of wave-particle duality in detail
  • Explore applications of photon wavelength calculations in spectroscopy
  • Investigate the significance of Planck's constant in quantum mechanics
Students in physics, particularly those studying quantum mechanics, as well as educators and researchers interested in photon behavior and energy calculations.
Lorax
Last Homework questions of the year! whoo! I'm having troubles with these so if you could help me out. I'm working on the bottom to the top, so if you want to help, help with 116 and down.
116. A proton travels through a magnetic field at the speed of 6.3 x 10^4 m/s perpendicular to the field. If the radius of the arc pf the deflected proton is 7.20x10^-3, what is the magnetic field strength?
122. A proton moves through a 0.06 T magnetic field in a circle with aradius of 0.30 m. What is the momentum of this proton?
124. What is the wavelength of a photon that has energy of 2.10eV
128. Electrons are ejected from a photoelectric surface with a maximum speed of 3.8 x 10^5 m/s. If the work function of this surface is 2.55 eV, what is the wavelength of the incident light?
130. What is the operating potential of an x-ray tube if photons with a maximum energy of 6.43x10^-15 J are produced?
140. An Electron endergoes a transition from the 6th energy level to the 2nd energy level in a hydrogen atom. What is the frequency of the light emitted?
145. What orbit (n value) in a hydrogen atom has a radius of 1.90 x 10^-19
146. If the momentum of a photon is 8.6 x 10 ^ -22 kg m/s what is its speed?
148. Calculate the wavelength of an electron that has kinetic energy of 6.25x10^-3 MeV.
164. Write the nuclear reaction for the alpha decay of uranium - 238.
165. Write the nuclear reaction for the beta decay (emission of an electron by the nucleus) of cobalt 60.
180. If the binding energy of lithium -6 (6/3Li) nucleus is 4.9118 x 10 ^-12 J, what is the mass of the nucleus? (mass of proton = 1.6726 x 10^-27 kg, mass of a neutron = 1.6749 x 10 ^-27 kg)
Ok, only the 3 first...
116) B=m*v/q*R=(1.6*10-27 kg*6.3*104m/s)/(1.6*10-19 C*7.2*10-3 m)= 0.08 T
122) Momentum=m*v . Then using the anterior formula we get the velocity... v=B*q*R/m= 1.75*106 m/s. So momentum is=2.8*10-21 Kg*m/s
124) Energy=h*f. Then, f=6.6*10-34/3'36*10-19J (I have passed from eV to Joules)=1.96*10-15 Hz.
f*wavelength=c, so wavelength=f/c=6.53*10-24 m
NO,nonononono... Don't solve his homework... Let him do it himself.Ask him what has gone wrong,invite him to post his work and questions...
Read the "sticky"...
Daniel.
Okay let me start off...
Thanks.
Thanks.
Thanks.
Okay here's some of my work now...
I did E=hc/frequency and got 6.175 x10^-10. Look good?
Working on this one currently will post later.
For this one I did...
1/Frequency=RH(1/n^2-1/n^2), then took that into E=hc/frequency then took that into F=E/h to get -3.913x10^25 but now I'm thinking I did to many steps and should have stuck with just... 4.09x10^-7. Look good?
Troubles with this one, a starting position would be nice.
I'm working on this one to, my mind just blanked at how to get the mass of a photon but I will get this one.
For this...
I converted the meV to 1x10^-15J, then put that into V=(Square root) 2ek/m, then I did p=mv, then P=h/frequency to get 4.911 x 10 ^ -4
I NEED MAJOR HELP WITH THIS ONE. Totally clueless.
Same as 164.
Currently looking over this, I may need help.
So if you could look over my work, and maybe help me with the ones left that would be great.
148.By the looks of it,the transformation of units is wrong.
1MeV=10^{6}\cdot 1.6 \cdot 10^{-19}C\cdot 1V=1.6\cdot 10^{-13}J
As for the nuclear physics problems,try to think about what happens in a disintegration of type "beta".Your book might provide some help.
Daniel.
our book does little to no justice for the section, and gives a half a page of uninsightful babble.
Still i can't give you the reactions,u need to figure them out yourself.What are the atomic and the mass numbers of the isotope of Cobalt 60??What does losing an electron assume,in relation to these numbers.??
Daniel.
I think I might have figured em out, anyways how about the ones I posted so far do they look right?
and then...
145.
r2 = r1n^2
r2/r1=n^2
1.90x10^-9/5.29x10^-11=n^2
36=n^2
n=36?
Look good?
146.
Is it just 3.00x18^8 m/s? Simply more of a knowledge question?
164.
234/90Th+4/2a?
165.
60/28 Ni + 0/-1B?
180.
I need help with this one, can someone help me with the proton and electron count and how you came up with that? I'm brutal at chem. I think I can do the rest by applying m=E/c^2.
145 is obviously wrong,mathematically.You reached an equation
36=n^{2} which u need to solve,knowing that u need only the positive integer solution.
146.It's wrong,By the looks of it,it's more than the speed of light... :-p
164 is correct.
165.is incomplete.U miss a reaction product.A particle.
Daniel.
145. I miss typed that it should be 6
146. umm did I just miss type again on it? it should be 3.00x10^8m/s
164.woo
165. I'm onsure about the reaction product I am missing, more help?
Can you also help me out with 180?
146.working on it
164.woo
Yes,u need to know the need to know the formula giving the bond energy as a function between the nucleus mass (tabulated quantity) and the masses of nucleons (protons and neutrons).
Look for it in the book.
Daniel.
PS.An electron antineutrino.It's always there in a beta decay.
is the antineutrino just +0/0? Is that all I have to add?
Yes,an antineutrino is (in the original version of theory) a massless particle and without electric charge.
Daniel.
Which of these answers is right... I did two different equations cause I was unsure...
1.89x10^-10 or 6.21x10^10?
The second number is completely wrong.Show how u've gotten the first one.
Daniel.
Freq of ligh= hc/E
(6.63x10^-34)(3x10^8)/(6.25x10^3)(1.6x10^-19) = 1.89.x10^-10m
Light is made up of photons,not electrons... :wink: U can't apply that formula.You need the formula of Louis de Broglie...
Daniel.
Okay and for question 180...
A person on a cpu game told me I should start out with 3 protons and 3 neutrons. Can you tell me why that is? I could just do the question but I want to know why.
U take a nucleus.It has a rest mass "M".And then u know that this nucleus is made up (esentially) of protons and electrons.Compute the mass of the nucleus using the values for Z and A.It will never equal "M".The difference between these 2 figures is just the bond energy/c^{2}.
Daniel.
Daniel.
Hmm okay let met think...
v=(square root) 2E/m
then I do
Wavelength = h/mv.
so I get... 4.686x10^21 as my velocity
and then 1.55 x 10 ^-25 as my answer. Is that better?
Daniel.
Yes but why is it 3 protons and 3 neutrons? How do you figure that out? I've been sick and missed some classes.
Also I did it now using 3 of each, and got... 9.98x10^-27kg
then I do
Wavelength = h/mv.
Good formulas,bad numbers.Are u sure u're using the right figures and units...??
Daniel.
Because it is a nucleus of ^{6}_{3}Li.It has Z=3 and A=6.Can u figure out the numbers of each particles inside it??
Daniel.
Daniel.
Hmm I think it has to maybe do with my MeV conversion.
Its 6.25x10^-3 MeV's, I converted it to 6.25x10^3 eV. Then I converted that into J's by multiplying it by 1.6x10^-19 to get 0.735.
I then multiplied that by 2 = 1.47 then divided that by 9.11x10^31 to get 1.6136x10^30. Then I took the square root of that. 1.27x10^15.
So V=1.27x10^15.
this time I get 5.73 x 10 ^ -19 as the answer...
Where am I going wrong.
Its 6.25x10^-3 MeV's, I converted it to 6.25x10^3 eV. Then I converted that into J's by multiplying it by 1.6x10^-19J/eV to get 0.735.
So V=1.27x10^15.
I've made remarks in your post.See above in the quote.
Bold:correct.
Blue:my notes.
Magenta:wrong.
Daniel.
1.48x10^26?
Don't give me a figure...Give me the whole calculations.Else,how am i suppodes to know whether a (presumably) correct result was obtained by a wrong method??
I guess you answer is wrong...Please put units to numbers...In this case "meters".
Daniel.
I've spent 2 hours+ on this ridiciously easy question. I'm doing something wrong, don't you think you could help me out just a bit more then what you've been giving me? I know you know where I went wrong, and can see it just like that, but please have mercy on my brain.
:smile: Okay,
\lambda=\frac{h}{p} (1)
p=\sqrt{2mE} (2)
\lambda=\frac{h}{\sqrt{2mE}}(3)
h\sim 6.6 \cdot 10^{-34}J.s (4)
m\sim 9.1\cdot 10^{-31} Kg (5)
E\sim 6.25\cdot 1.6\cdot 10^{3}\cdot 10^{-19} J =10^{-15}J(6)
Plug (4),(5),(6) into (3).And get your result.
Daniel.
