What is the wavelength of a pulse on a hanging rope with changing tension?
The discussion focuses on the behavior of a transverse pulse on a hanging rope with varying tension. A uniform rope of length 12 cm and mass 6 kg, with a 2 kg block attached, experiences a change in wavelength as the pulse travels upward. The tension at the upper segment is 8g, while at the lower segment it is 2g. The frequency remains constant throughout the rope, which leads to a change in wavelength as the wave velocity varies with tension.
  • Understanding of wave mechanics, specifically wave velocity and frequency relationships.
  • Knowledge of tension in strings and its effect on wave propagation.
  • Familiarity with the wave equation and its application in varying mediums.
  • Basic principles of harmonic motion and pulse behavior in physical systems.
  • Study the wave equation in detail, focusing on the relationship between tension and wave speed.
  • Explore the concept of standing waves and their formation in strings under tension.
  • Learn about the effects of mass per unit length on wave propagation in different mediums.
  • Investigate the principles of harmonic motion and how they apply to transverse waves in ropes.
Students studying physics, particularly those focusing on wave mechanics and tension in strings, as well as educators looking for practical examples of wave behavior in real-world applications.
harambe
A uniform rope of length 12cm and mass 6kg hangs vertically from a rigid support.A block of mass 2kg is attached to the free end of the rope.A transverse pulse of wavelength 0.06m is produced at the lower end of the rope.What is the wavelength of the rope ,when it reaches the top of the rope
So It is given that the wavelength changes and the tension also changes through out the rope
T(upper segment)= 8g,T(Lower segment)-=2g
The wave equation
v1/v2=(T1/T2)^1/2 {the mass perunit length cancels for this case}
Now velocity of a wave= wavelength X frequency
The wavelength is changing through out the rope and I don't know about frequency so How should I proceed after this...Does the derivation consider the fact that the wave changes velocity at every point on the rope
If 100 complete waves are sent up will they all take the same time to reach the top? What does that tell you about how the frequency at the bottom compares to the frequency at the top?
They will take same time so frequency should remain constant
Right, so can you now determine the wavelength change?
The frequency remains same so use the relationship between wavelength and velocity to solve this
yeah and I got my answer now
The elements in the upper part might vibrate less that the elements at the lower part leading to decrease in the frequency.
I still can't understand how your example leads to the explanation that frequency is constant all over the rope.
The waves might change amplitude, but they will not disappear completely, nor will extra waves appear out of nowhere. If the frequency at the bottom is persistently greater, say, than the frequency at the top then then the number of waves in between must be increasing, without limit.
Thank you very much sir.
That is quite vague, so I am not sure what your reasoning is.
What do you mean by vibrating less? Less amplitude, yes, but less often, no.
Start with one pulse sent from the bottom. It takes some time t to reach the top.
Now send the next pulse. Doesn't that also take time t to reach the top?
I agree that all the pulses will take same time to reach the top but how it relates to constant frequency?
Now consider pulses emitted at times ##t_0, t_0+T, t_0+2T, ...##. They arrive at the top at times ##t_0+t, t_0+t+T, t_0+t+2T, ...##.
So vibration is in vertical direction (up-down) , I thought it was in horizontal axis (left-right).
Makes no difference to the argument.
I see that time period of all the pulses will be same so all the pulses will have same frequency(up-down vibrations) so it is about vertical vibrations and not horizontal with which I confused .
It does not matter whether they are vertical or horizontal. The pulses must arrive at the same rate at which they start, so the frequency is the same.
  • · Replies 39 ·
9K
