What is the Work Required to Stretch a Spring?
8 replies · 4K views · last reply
blayman5
A spring with spring constant of 29 N/m is
stretched 0.21mfromits equilibrium position.
How much work must be done to stretch it
an additional 0.14 m? Answer in units of J.
W=-kx(x)/2
I solved it and got 0.4263 and it was wrong. does it need to be negative?
W=-kx(x)/2
How did you arrive at that number?
i did ((29)(0.21)(0.14))/2 =0.4263. does it need to be negative?
That's not quite right.
Additional work = Difference in work = 29*(.21+14)2/2 - 29*(.21)2/2
Ok so that means it would equal
29*(.21+14)2/2 - 29*(.21)2/2 =1.1368
Thanks
Thanks
That's what I got anyway. What you need to remember is that work is the area under the force and distance curve over the range of the curve.
Cheers
wait...
wait wait... why is it 14 instead of .14?
dleccord said:
wait...
He got the right answer and the 14 was apparently a typo. Calculate it out and you will see the inner sum needs to sum to .35.
