What is the Zero Vector in a Vector Space with Unconventional Operations?
The discussion revolves around determining whether a given set forms a vector space under unconventional operations defined as multiplication and a modified addition. Participants are exploring the implications of these operations on the definition of the zero vector and the axioms of vector spaces.
  • Conceptual clarification, Assumption checking, Problem interpretation
  • Participants are attempting to apply axioms of vector spaces to the defined operations but express uncertainty about how to define the zero vector. Some are questioning the nature of the set, particularly whether it includes only positive reals or all real numbers. Others are considering the implications of the operations on the properties of the zero vector and additive inverses.
The discussion is active, with participants sharing their interpretations of the axioms and the operations involved. Some guidance has been offered regarding the properties of the zero vector and the need to consider the implications of the defined operations. Multiple interpretations of the zero vector are being explored, particularly the suggestion that it may be represented by the number 1 under the given operations.
There is a lack of clarity regarding the specific axioms being referenced, as different sources may define them differently. Additionally, the nature of the set being discussed—whether it includes all real numbers or only positive reals—remains uncertain and is a point of contention in the discussion.
B18
Determine if they given set is a vector space using the indicated operations.
Set {x: x E R} with operations x(+)y=xy and c(.)x=xc
The (.) is the circle dot multiplication sign, and the (+) is the circle plus addition sign.
I tried to use axioms 1,2,3,6,7,8,9,10 to prove it isn't a vector space and have not found anything yet. I am not entirely sure how I can define the 0 vector which is why i haven't tried axioms 4, and 5.
Anyone able to steer me down the right path on this one?
Nobody can say, because we do not know what book you are using and do not know exactly what is the content of Axioms 1,2,3, etc. Different books sometimes have slightly different axioms and will often number them differently.
Here is the list of axioms I'm using. I never thought of that. Thanks Ray.
You say you did axiom 6? ##(-1)## is in ##R##. What is ##\frac{1}{2} \odot (-1)##? Are you sure you don't mean ##R## to be the positive reals? And why don't you think about trying 1 as a '0 vector'.
The "0" vector has the property that v+ 0= v for any vector v. Here, that must be that v times "0" is equal to v. So what number has that property? Of course, every vector must have an "additive inverse" which, since "addition of vectors" is here defined as their product, means there is likely to be a problem with the number 0. That is one reason Dick asked about whether the vectors were not the positive reals rather than all real numbers.
Wow, that one flew right past me. Apparently I wasn't thinking about exponent rules enough. The set is all real numbers though, nothing indicating that it is only positives.
Can you post a photo of the problem? If the set involved is all real numbers, you're going to have problems with things like ##.5 \odot (-1)##, which is ##(-1)^.5##. Also not stated in this thread is the field that the scalars come from.
Sure thing!
In this case the zero vector would have to be equal to 1?
Yes, the "zero vector", with this definition of vector addition, must be the number "1".
So (B18), keeping in mind that 1 in this space acts like 0, what do you have to "add" to a number x so that ##x \oplus ? = 1##? IOW, what do you have to "add" to a number x to get "zero"? Hope that doesn't boggle your mind too much!
  • · Replies 17 ·
  • · Replies 43 ·
