What is Var(X) for my defined X?
  • Level: Graduate
  • Thread starter Thread starter Pzi
8 replies · 3K views
Pzi
This applies to natural numbers [itex]n[/itex] and [itex]N[/itex] where [itex]n<N[/itex].
We have [itex]N[/itex] balls representing numbers [itex]1,2,...,N[/itex].
We randomly choose [itex]n[/itex] of those balls which happen to represent numbers [itex]{k_1},{k_2},...,{k_n}[/itex].
We then define a random variable [itex]X = {k_1} + {k_2} + ... + {k_n}[/itex].
What is the mean and variation of [itex]X[/itex]?
Well there are [itex]\left( {\begin{array}{*{20}{c}}N\\n\end{array}} \right)[/itex] equally likely combinations and every one of them brings [itex]n[/itex] summands. So we get [itex]\left( {\begin{array}{*{20}{c}}<br /> N\\<br /> n<br /> \end{array}} \right) \cdot n[/itex] summands overall. Since there is no bias towards any particular number it means that every number is added [itex]\left( {\begin{array}{*{20}{c}}<br /> N\\<br /> n<br /> \end{array}} \right) \cdot \frac{n}{N}[/itex] times hence our mean:
[itex]E\left( X \right) = \frac{{\left( {\begin{array}{*{20}{c}}<br /> N\\<br /> n<br /> \end{array}} \right) \cdot \frac{n}{N} \cdot \left( {1 + 2 + ... + N} \right)}}{{\left( {\begin{array}{*{20}{c}}<br /> N\\<br /> n<br /> \end{array}} \right)}} = \frac{n}{N} \cdot \frac{{N\left( {N + 1} \right)}}{2} = \frac{{n\left( {N + 1} \right)}}{2}[/itex].
Unfortunately variance seems to be an entirely different animal since I cannot just rip sums apart and add numbers in a different order. Any ideas?
It is a straightforward, but messy, calculation.
Let X = ∑ ki. mean = E(X), var = E(X2) - (E(X))2
To compute E(X) all you need is E(ki) = N/2.
To compute E(X2), some work is required.
You need (a) E(kikj) for i ≠ j, and (b) E(ki2).
For (a) I got N(N+1)/4 - (2N+1)/6, for (b) I got (N+1)(2N+1)/6.
To get the final answers you need to multiply the mean by n.
For the second moment {E(X2)}, there are n(n-1) (a) terms and n (b) terms.
Good luck!
In case you weren't able to work it out, I got the following:
E(X) = n(N+1)/2
Var(X) = n(N+1)(N-n)/12
See if you get same.
E(X) = n(N+1)/2
I appreciate your dedication very much. Sorry for not getting back to this topic in a reasonable amount of time.
So for i≠j you apparently got E(kikj) = N(N+1)/4 - (2N+1)/6.
Meanwhile I got
[tex]E({k_i}{k_j}) = \frac{1}{{\left( {\begin{array}{*{20}{c}}<br /> N\\<br /> 2<br /> \end{array}} \right)}}\sum\limits_{i = 1}^{N - 1} {i \cdot \sum\limits_{j = i + 1}^N j } = \frac{2}{{N(N - 1)}}\sum\limits_{i = 1}^{N - 1} {i \cdot \frac{{(N + i + 1)(N - i)}}{2}} = \frac{{N(N + 1)}}{2} + \frac{{1 - 2N}}{6} + \frac{{N(1 - N)}}{4}[/tex]
Is my logic flawed here? Also I checked the literature for answers and can confirm that your conclusion about mean and variation is correct.
Meanwhile I got
You made at least one arithmetic error. The summand in the second summation should be
i(N-i+1)(N-i)/2. I'll let you finish from there.
In any case I got E(X2) = n(n-1)(N+1)(3N+2)/12 + n(N+1)(2N+1)/6,
where the first term is the contribution of all products of different numbers and the second term is the contribution of all the squares.
Why do you say so?
(i+1)+(i+2)+(i+3)...+(N-2)+(N-1)+N = (N+i+1)(N-i)/2
Well the first term is E(kikj) added n(n-1) times isn't it? Hence E(kikj)=(N+1)(3N+2)/12 (for i≠j) which is not the same as previously stated by yourself E(kikj)=N(N+1)/4-(2N+1)/6.
Sorry if I missed something.
P.S. http://www.wolframalpha.com/input/?i=2/(N*(N-1))*sum(i*sum(j,+j=i+1,N),+i=1,N-1)
it gives the same result as mine so I'm confused now, is it the wrong way to calculate E(kikj) ?
Sorry - I sometimes get sloppy in my arithmetic (Jan. 11 - my error was in dividing by N(N+1) when I should have
divided by (N-1)N), including my comment saying you had an error. However the calculation on Jan. 14 was done very carefully (where I divided by N(N-1)). This included the result I mentioned yesterday.
I can't figure out why yours comes out differently.
My calculation - E(XiXj) = {(∑i)2 - ∑i2}/N(N-1), where the sums are i = (1,N).
One quick check, for N = 2, the product of different x's ≡ 2, so the expectation is obviously 2.
In any case, your result is the same as mine.
Thanks for all the help.
To sum things up I'd just like to say that I almost got it right after your first post. Unfortunately I made a very silly mistake at the very end. Which in turn led to a whole phase of contemplation and doubts.
I attach that almost-correct handwritten solution just for fun.
Differences in notation: E(X)=M(X), Var(X)=D(X), X=W.
