What is wrong with the standard model at 1 or 2 TeV?
The discussion revolves around the limitations and potential inconsistencies of the Standard Model (SM) of particle physics at energy scales around 1 to 2 TeV. Participants explore theoretical implications, particularly concerning the Higgs boson's mass and its effects on scattering processes, as well as the relationship between experimental observations and theoretical predictions.
  • Some participants note that the SM may not be valid at energies above 1 or 2 TeV due to potential inconsistencies, such as the W_L + W_L scattering amplitudes exceeding unity.
  • Others argue that the Higgs boson is a crucial component of the SM, and its mass being below 1 TeV could resolve certain issues, while a heavier Higgs might lead to complications.
  • There is a discussion about the relationship between the Higgs mass and unitarity bounds, with some suggesting that if the Higgs is heavier than 1 TeV, it could violate these bounds.
  • Participants express uncertainty about the exact conditions under which the SM remains valid, particularly regarding the Higgs mass and the energy scale at which the theory holds.
  • Some contributions highlight that while experimental data currently constrains the Higgs mass to be below approximately 250 GeV, there is debate about the implications of theoretical limits versus experimental bounds.
  • Concerns are raised about the reliability of certain calculations related to the Higgs mass and unitarity, with suggestions that some theoretical limits may not be robust.
Participants do not reach a consensus on the implications of the Higgs mass for the validity of the Standard Model at high energies. Multiple competing views remain regarding the nature of the problems associated with the SM and the interpretation of theoretical limits.
Limitations include the dependence on the Higgs mass and the energy scale for the validity of the theory, as well as unresolved mathematical steps in the calculations discussed. The discussion reflects a range of interpretations and assumptions about the implications of current theoretical frameworks.
JohnStanton
Every now and then one reads that the
standard model does not work for
energies above 1 or 2 TeV.
Can anybody explain where this statement
comes from?
As far as I understand, there are no
deviations of the standard model form
experiment. There is only the issue
of Higgs mass being sensitive to
higher order perturbative corrections.
But is that sufficient to derive the 2 TeV
number? Or is there another reason?
John
A theory can be wrong in two ways. It can either be inconsistent with experiment, or inconsistent with itself. The SM has this second problem.
The problem is that the process [tex]W_L + W_L \rightarrow W_L + W_L[/tex] has a predicted probability of interaction that exceeds 1 around 1 TeV. This is clearly nonsensical, so something new has to happen.
I think you want to say that [tex]W_L + W_L \rightarrow W_L + W_L[/tex] scattering amplitudes don't behave nicely for all energies unless Higgs is lighter than 1 TeV.
Higgs isn't "new". Higgs is an integral part of SM. Not having a Higgs would be new.
Yes, I meant that the Higgs is part of the standard model. Does you comment mean that
there is definitely no problem with the standard model, if the Higgs exists?
John
John
Define "problem"
JohnStanton said:
Yes, I meant that the Higgs is part of the standard model. Does you comment mean that there is definitely no problem with the standard model, if the Higgs exists?
There is no inconsistency in the SM if the Higgs exists. Whether or not it agrees with the higher energy data that will be available when the LHC turns on is an open question. There are also questions that the SM doesn't answer and we'd like to know - why fermion masses vary by 10-13 orders of magnitude is one of them.
I agree, but this leaves the John Stanton's original question unanswered. In other words, if the Higgs is lighter than 1 TeV, all is well in SM (but not pretty perhaps.) On the other hand, we must now answer what goes wrong if the Higgs exists but heavier than 1 TeV. Especially, if it is much heavier than 1 TeV. Only that would answer the original question properly, and I would like hear that explanation myself too. If the W+W scattering violate unitarity bounds at some large Higgs mass, that mass must be computable exactly. Is it not so?
"Simplest" SM with Higgs heavier than 1 TeV is incompatible with observations. Precision measurements of heavy quark and boson masses constrain SM Higgs to be lighter than approx. 250 GeV.
Not exactly. There are two unknowns. One is the Higgs mass, and the other is the energy scale where the W scattering remains sensible. The mass of the Higgs depends on how high a scale you want the theory to still work - the Planck scale? The GUT scale? 10 TeV? Given one value, someone (other than me) can calculate the other.
Yes, I know, but this is an experimental bound which comes from the best known values of various masses and mixing angles. As such, I think it is tighter than the so-called unitarity bound. I was also under the impression that the W+W elastic scattering would violate the unitarity at some Higgs mass above 1 TeV. (Vanadium50 mentioned the same thing earlier.) If true, this second restriction is not an experimental bound, but a fundamental theoretical limit. I would like to know how this latter limit is obtained, and if we may be able to accurately calculate the lowest Higgs mass which violates unitarity in the W+W elastic scattering. Do you know any papers or books where this computation is explicitly carried out?
"There is no inconsistency in the SM if the Higgs exists."
You could probably argue that the Landau pole is really the only last glaring theoretical inconsistency (though it exists only at ridiculously high energy scales), and maybe the absense of gravity too.
However i'd say the SM is already falsified experimentally, b/c it cannot accurately predict cosmological constraints (no dark matter, issues with baryogenesis and so forth), thus it must be viewed as an effective theory regardless.
Fermi, there are various bounds on the Higgs mass, at least as far as perturbation theory goes.
See this site for the traditional ones (there are others, but they tend to be more shaky)
http://www.hep.lu.se/atlas//thesis/egede/thesis-node20.html
Thank you, I checked the W+W elastic scattering in the references you provided. It includes the mass computation I hoped to see, and I was excited. Unfortunately, I don't think the partial wave analysis employed in the mass computation is correct. (The scattering amplitude computation by first order perturbation is fine; what follow this computation however, borders speculation.) Perhaps I don't fully appreciate it. Interestingly, the article itself concludes with the remark: "The limit can not be taken all too serious(ly) since it drives the pertubative approach of partial waves into the region of non-pertubative analysis where |a0| = $\cal$O (1) . "
Does this mean the so called TeV unitarity bound is a mirage?
Hi Fermi,
Yea the limit itself gets into mildly shaky mathematical territory, I wouldn't trust the number exactly, but then again its close modulo factors on the order 1. There is probably more detailed computations found in the literature/textbooks if you look for them, but indeed the systems do become strongly coupled and its a very hard problem to really get precise analytic control off.
You should however come away with the notion that whatever the theoretical upper bound is, its still squarely in the range of what the LHC can probe. Moreover modern electroweak precision tests tends to put the best fits somewhere between 115-175 GeV or so, so we should know one way or the other relatively soon and this whole discussion will become academic.
No, it means before the calculation becomes nonsense, it becomes what is called "non-pertrubative", which means difficult and quite sensitive to ordinarily irrelevant details of the calculation.
This kind of behavior is hardly new - calculating the Curie temperature of iron from first principles, just to pick a random example, is also difficult. Happens all the time.
Fine Tuning and the Higgs mass - not necessary?
The 4 page paper arXiv:0712.0402
by Pivovarov and Kim provides a different
opinion than most. It is quite new (Phys Rev D,
July 2008) and says in its summary:
Let us summarize our findings. Taking into account
higher order perturbative corrections does not change
the basic fact: radiative corrections to the electroweak
scale are growing fast with cutoff. At 1.2 TeV the correction
to the intermediate bosons mass squared is about
a half of the total mass squared. Is it new physics that
half of the observable mass scale is due to radiative corrections
is a matter of convention. We consider such a
situation as deserving the title of new physics. To say
the least, perturbation theory looks jeopardized in such
circumstances. Beyond perturbation theory, we still do
not know any mechanism that would provide for small
masses of the scalar particles.
On the other hand, if some unknown mechanism provides
for small mass of scalar particles, perturbation theory
is quite able to explain relative stability of the scalar
mass against small variations in fundamental parameters.
We demonstrated that there is no fine tuning problem in
the theory of quantum scalar field, and derived inequality
(16) in the Standard Model restricting the Higgs boson
mass. Phenomenological consequences of this restriction
will be studied elsewhere.
So they say that there is NO *fine tuning problem*
for the Higgs mass, in contrast to most other authors.
In the abstract, they write; "We conclude that higher
order perturbative corrections take care of the fine tuning
problem, and, in this respect, scalar field is a natural system."
So they even say that there is no *naturalness problem*.
They only have the problem that the mechanism that
keeps the Higgs mass small is unknown. (The *hierarchy
problem*.) Most other authors disagree, giving
all 3 problems for the Higgs. Who is right?
John
I found a post by Haelfix in 2004 where he says:
It's just hidden naively b/c of the assumptions in the scheme (1/epsilon divergences etc) gobbling up the physical quantities of interest. eg It's only in pure SDM valid at all scales where the above claim is true.. there really isn't a hierarchy problem per se unless you assume *something else*.
Does the Planck scale count as something else, or does the above statement mean that
if in nature there is only the standard model and the Planck scale, then there is no hierarchy problem?
Could one make the hierarchy problem go away?
John
Yea that post I wrote a long time ago, is perhaps worded a little strange, but had to do with the fact that the hierarchy problem is invisible in dimensional regularization.
In a way, if there is no Planck scale, or GUT scale or some other physical scale of note, you won't see the unnatural ratios. There will be a problem of principle of course (where is gravity, where does the Higgs field VeV come from, etc), but technicallly what I wrote is accurate if dubious on physical grounds.
  • · Replies 0 ·
  • · Replies 0 ·
  • · Replies 26 ·
  • · Replies 27 ·
9K
