kolleamm
- 476
- 44
What sort of materials or elements heat up really fast but also cool down fast as well?
Thanks in advance
Thanks in advance
Materials that heat up and cool down rapidly typically possess low heat capacity and high thermal conductivity. Metals are prime examples due to their low specific heat, which allows them to absorb heat quickly. Additionally, thermal diffusivity, defined as thermal conductivity divided by the product of density and heat capacity, plays a crucial role in determining how fast a material can respond to temperature changes. Diamond, while having the highest thermal conductivity, also exhibits significant thermal diffusivity, making it an exceptional material in this context.
PREREQUISITESMaterials scientists, engineers, and anyone interested in thermal management and material properties will benefit from this discussion.
Great! I had no idea, thank a lot!bigfooted said:Materials with a low heat capacity per unit volume (specific heat):
https://en.wikipedia.org/wiki/Heat_capacity
so in general: metals.
here is a list that you can sort on specific heat, so the heat needed to increase the temperature of 1kg of material by 1K.
http://periodictable.com/Properties/A/SpecificHeat.v.html
What about the cooling down?bigfooted said:@Chestermiller is correct. I was incomplete in my answer.
Just to clarify: a low heat capacity means you only need a little heat to increase the temperature [say by 1 Kelvin], and a high thermal conductivity means that this heat is 'absorbed' by the material fast.
Same, of course.kolleamm said:What about the cooling down?
What about its thermal diffusivity? How does that compare?Helios said:Wiki says: Diamond is renowned for its superlative properties ... In particular, it has the highest hardness and thermal conductivity of any bulk material.
It depends on how you heat and how you cool the material. Is it by radiation, convection or thermal conduction?kolleamm said:What sort of materials or elements heat up really fast but also cool down fast as well?
