What Medium Does Light Travel Through in Space?
  • Level: High School
  • Thread starter Thread starter rekha1804
    Light Medium Travel
165 replies · 14K views
GRQFT said:
Yes, a wise choice given how controversial that subject is (and the fact that Aharonov himself has changed his interpretation of the effect [which he discusses in this video]).
Nice, I didn't know he changed his views on this. My views are now closer to his.
Astronomy news on Phys.org
GRQFT said:
I'm at a level where I I know enough to ask about stuff like the Hodge dual, but not really understand it.
Consider the inhomogeneous Maxwell equations in (3+1) notation (Gaussian CGS units) with electric charge-density and electric 3-current-density on the RHS.
##\nabla \cdot \mathbf{E} = 4\pi\rho_{el}##
##\nabla \times \mathbf{B} - \frac{\partial \mathbf{E}}{\partial {(ct)}}= \frac{4\pi}{c}\mathbf{J_{el}} ##
Take these equations and substitute ##B \mapsto E##, ##E \mapsto -B##.
Then you will get the homogeneous Maxwell equations in (3+1) notation (Gaussian CGS units) with magnetic charge-density and magnetic 3-current-density on the RHS.
##\nabla \cdot \mathbf{B} = 4\pi\rho_m =0##
##\nabla \times \mathbf{E} +\frac{\partial \mathbf{B}}{\partial {(ct)}}= \frac{4\pi}{c}\mathbf{J_m} = 0##
Now consider the EM field tensor, Gaussian CGS units with (+++-) convention.
##F^{\mu\nu} = \begin{pmatrix} 0 & B_z & -B_y & -E_x \\ -B_z & 0 & B_x & -E_y \\ B_y & -B_x & 0 & -E_z \\ E_x & E_y & E_z & 0 \end{pmatrix}##
Do the same substitution ##B \mapsto E##, ##E \mapsto -B##. Then you get the Hodge dual.
\tilde F^{\mu\nu}
\begin{pmatrix}
0 & E_z & -E_y & B_x\\
-E_z & 0 & E_x & B_y\\
E_y & -E_x & 0 & B_z\\
-B_x & -B_y & -B_z & 0
\end{pmatrix}
Therefore, you can convert Maxwells inhomogeneous equation
##\partial_\nu F^{\mu\nu} = \frac{4\pi}{c} {J_{el}}^\mu##
into Maxwells homogeneous equation
##\partial_\nu \tilde{F}^{\mu\nu} = \frac{4\pi}{c} {J_m}^\mu = 0##
by substituting the EM field tensor by it's Hodge dual.
Dale said:
No. If ##c## is a dimensionless 1 then you could equally say that it was absorbed into the space coordinate. Or that its cube was absorbed into the time coordinate and its fourth root was absorbed into the space coordinate. Far easier to just say it just doesn’t exist in those units. There is no reason for it to be absorbed anywhere and inherent ambiguity if you try to assert that it is absorbed somewhere.
Indeed. Just find the reason why it does exist in the other. The absence of that reason is the reason that it doesn’t exist in the one.
For instance, ##\epsilon_0## exists in SI units to make Coulomb’s law dimensionally consistent. That is why it does exist in SI. In Gaussian units Coulomb’s law is naturally dimensionally consistent. That is why it doesn’t exist in Gaussian units.
You can do a similar exercise with every dimensionful constant that is present in one system of units and not in another.
What I meant was that the process of making ##c## dimensionless is to absorb it into another quantity. The reason is that the dimensions/units of that other quantity had to change to accommodate the fact that ##c## became dimensionless.
Dale said:
As an exercise for you, trace why the constant ##k## in Newton’s 2nd law, ##\vec F_{net}=km \vec a##, doesn’t exist in SI units.
Also, if you want to assert that ##k## does exist in SI, but is absorbed somewhere, then where is it absorbed and how do you know it was absorbed there and not somewhere else?
So ##k## is dimensionless. It does not affect the units.
renormalize said:
I would say instead that ##c## simply disappears by choosing uniform units, as I tried to explain in post #118.
Please indulge me by pondering an exactly analogous situation in 3D that persists to this day in US sea navigation. American maritime vessels measure distance traveled in nautical miles (NM), but the depth below them is given in fathoms (ftm). The relation between these quantities is ##1\,\text{NM}=\mathfrak{c}\,\text{ftm}## where the "mysterious" conversion factor ##\mathfrak{c}## is ##1012.69##. But the rest of the world, not being wedded to imperial tradition, more rationally measures height, width and depth all in the same uniform units, namely meters. The rest of the world thinks that the "conversion" between transverse-distance and longitudinal-depth is simply unity (if they think about it all). So what happened to the "dimensionful" constant ##\mathfrak{c}##? You can say it was absorbed into the depth coordinate, whereas I claim it disappeared by making the natural choice of uniform units for height, width, and depth. But in either view, the result is consistent with saying ##\mathfrak{c}=1\,##, and is dimensionless, in uniform units.
And that same reasoning applies to ##c## in the unified theory of Minkowski spacetime.
Interesting example. I agree that the two ways to see the conversion is effectively equivalent. However, I still prefer to think of it as being absorbed, because it explains the change in the units of the quantity into which it is absorbed.
\tilde F^{\mu\nu}
\begin{pmatrix}
\end{pmatrix}
Interesting. Applying the Hodge dual in this way seems specific to EM given that it comprises two different yet equally important fields (E & B).
Then again, I wonder if this can also be done for gravitational radiation (in the weak-field limit) to get 'homogeneous' and 'inhomogeneous' gravitational wave equations corresponding to zero and non-zero stress-energy tensor, respectively.
The Hodge dual is quite a beautiful operator defined on the exterior algebra of an orientable manifold with a metric. For such a manifold of dimension ##n##, it defines an isomorphism between ##k##-forms (or ##k##-vectors) and ##(n-k)##-forms (or ##(n-k)##-vectors).
The stress energy tensor is a proper tensor, it can't both be zero and non-zero at a given point in spacetime. I assume that's what you meant by your correspondence, for both the homogeneous and inhomogeneous Maxwell equations are valid at a given point in spacetime.
There is a formal analogy that could be made in a weak field approximation of GR to EM theory, but it doesn't quite work as you are saying here. You can see Wald's General Relativity section 4.4a for a discussion.
Applying the Hedge dual in this way switches the interior derivative of the field between electric and magnetic sources (zero, because magnetic monopoles do not exist).
In 4D-spacetime, there is a common electromagnetic bivector field with 6 components. They split into two sets (E & B) of three components which transform as 3-vectors under rotations.
To come closer back to the thread-topic: I found the following Wikipedia article about QED vacuum.
Wikipedia said:
As a result of quantization, the quantum electrodynamic vacuum can be considered a material medium.[20] It is capable of vacuum polarization.[21][22] In particular, the force law between charged particles is affected.[23][24] The electrical permittivity of the quantum electrodynamic vacuum can be calculated, and it differs slightly from the simple ε0 of the classical vacuum. (Likewise, its permeability can also be calculated and differs slightly from μ0.) This medium is a dielectric with relative dielectric constant greater than 1, and is diamagnetic, with relative magnetic permeability less than 1.[25][26]
Source:
https://en.wikipedia.org/wiki/QED_vacuum#Electromagnetic_properties
They say that the QED vacuum can be considered a material medium with ##\epsilon_r >1## and ##\mu_r <1##.
Is this misleading or false?
They refer to:
  • [25] Book "Dynamics of the Standard Model" (Donoghue, John F.; Golowich, Eugene; Holstein, Barry R., 1994), Cambridge University Press. p. 47
  • [26] Book "Nuclear Physics in a Nutshell" (Bertulani, Carlos A., 2007), Princeton University Press. p. 26
Note that QED is the theory of the electromagnetic interaction. In other words, it is the theory of EM fields + electron (charged) fields + interactions. The "vacuum" referred to in the article appears to me to be referring to the interaction theory ground state. This is different than the free theory vacuum.
Yes, it is dimensionless in SI units, but not in imperial units. In imperial units it is ##0.031 \mathrm{\ lbf \ s^2 \ lbm^{-1} \ ft^{-1}}##. So where did ##k## get absorbed in SI?
So, in the process of making ##k## dimensionless in SI units, which quantity had to change to accommodate the fact that ##k## became dimensionless in SI?
Perhaps the quantity that is a compound unit. So in Newton’s 2nd law you would say that in SI ##k## was absorbed into the unit of force so that ##1 \mathrm{\ N}=1 \mathrm{\ kg \ m \ s^{-2}}##. I cannot see a better rule, but that one has its own problems.
That is a possible alternative. Just make it a personal preference. Then you can use it when and where you find it convenient, and not use it where you don’t.
I think in the free theory vacuum, the refraction index ##n = \sqrt{\varepsilon_r \mu_r}## must be ##1##.
If this were not the case, then light would move with ##c/n## relative to a certain reference frame. But the free theory vacuum does not have a certain state of motion like a medium.
If the refraction index ##n = \sqrt{\varepsilon_r \mu_r} >1## in the interaction theory ground state, then there must be something, which defines a reference frame for the speed ##c/n##.
Dale said:
Yes, it is dimensionless in SI units, but not in imperial units. In imperial units it is 0.031 lbf s2 lbm−1 ft−1. So where did k get absorbed in SI?
Oh my goodness! What a mess! :-) I guess all quantities had to change to accommodate the ##k##. Yes, such scenarios are also possible. In effect ##k## had to be "broken apart" to produce different dimensional parameter that could be absorbed into the other quantities.
Yes, but would you perhaps agree that it provides a clearer understanding of what is going on than to just say ##c=1##? In the latter case, it is not obvious that there are no units or whether people just avoided writing them down because they are not defined.
I don't have deep insights into the QED vacuum. This is not a topic I have studied in detail.
This statement seems legit to me. A lot of the statements of the article seems to rely on the presence of either loop correction diagrams or a background field. It's hard for me to disentangle which statement is due to which.
See these statements in the article:
"In extreme conditions in which the field exceeds the Schwinger limit (e.g., in the exterior regions of pulsars[27]), the quantum electrodynamic vacuum is thought to exhibit nonlinearity in the fields.[28] Calculations also indicate birefringence and dichroism in the presence of strong fields.[29]"
I think still calling this a "vacuum" seems tenuous. If you are near a pulsar, you are seeing extremely strong magnetic fields. That background field has a direction.
The problem with that section of Wikipedia for me is I can't tell which statement is predicated on which effect (loop corrections or background field or maybe something else). I would guess it is written by some expert for whom the distinctions are clear, but to me they are not.
If the rule is personal preference then my personal preference is simply to acknowledge that the quantities have different dimensions in different systems of units. I personally prefer to have one simple rule.
To me personally that is far clearer than trying to guess which unit the constant is hiding under, as though it were some cosmic shell game. Worse, I would have to guess which unit system contains the constants that need to be hidden, and then guess which units the constants are hidden in. No, personally I do not consider that activity to bring any clear understanding.
However, if the rule is personal preference then your personal preference can differ from mine. You may say the constant is hidden wherever you like, for any reason or no reason at all. And you are free to do so without my agreement or despite my objections. That is the convenient thing about personal preference.
  • Agree
