What order should we take when calculating QFT amplitudes?
  • Context: Undergrad
  • Thread starter Thread starter davidge
    Amplitudes Qft
The discussion revolves around the calculation of quantum field theory (QFT) amplitudes, specifically focusing on the order of perturbative expansions and the relevance of Feynman diagrams in physical processes. Participants explore the implications of using different orders in Dyson's expansion and the nature of contributions from various diagrams.
  • One participant suggests that nature uses various orders of Feynman diagrams randomly for interactions, questioning which diagrams occur most frequently.
  • Another participant counters that all diagrams are used simultaneously in a perturbative expansion, implying that contributions from higher-order diagrams may diminish.
  • There is a query about whether one should always use expansions in all orders, leading to a discussion on the practicality of truncating infinite series.
  • Some participants mention that many perturbation expansions do not converge and are instead asymptotic series, which improve up to a certain point before diverging.
  • Discussion includes the computational aspects of QFT calculations, with references to high-loop calculations and their theoretical nature.
  • Clarifications arise regarding the nature of asymptotic series and their behavior in the context of Dyson series, with some participants challenging each other's interpretations.
Participants express differing views on the nature of Feynman diagrams and the use of perturbative expansions. There is no consensus on whether all orders should be considered or the implications of asymptotic series behavior.
Some participants note limitations in the ability to calculate high-loop orders, emphasizing that while theoretical discussions may mention many loops, practical calculations are often limited to lower orders like NLO or NNLO.
davidge
I have been reading about QFT amplitudes. It seems that difficulty increases as we consider more and more terms in the Dyson's expansion for the Scattering operator, and we need to normalize each of them if we want to get a sensible result.
My question is, nature usually uses what order? I mean, what type of Feynman diagrams "is most used by nature"? I imagine that she randomly uses any order for a same type of interaction, at each time. So my question would be better posed as, what type of Feynman diagram occurs with more frequency?
Nature does not throw a dice and then chouses a diagram to follow. Feynman diagrams are terms in a perturbative expansion, meaning that for every interaction, all diagrams are used by nature simultaneously.
If you're lucky, each additional vertex factor makes the contribution of that diagram smaller, so that the series converges and you can take some cutoff and neglect the most exotic diagrams.
So should we use expansion in all orders in any and every case we are eventually considering?
Thanks, sandy.
I didn't want to post a message in that thread, because they are masters and I'm a noob.
From what I read, it seems that those calculations are computer-made. The calculation goes for, say, 430 loops. Is it correct?
I doubt I know any more about the subject than you do. I just thought you might find the info you were looking for in that thread.
Ah, ok
No, because there are an infinite number of orders, and in most cases you can't find a closed-form formula that sums up all of the infinite number of contributions. The best you can do is, as @thephystudent said in post #2, to hope that the terms get smaller as you go to higher and higher orders, so you can cut off the sum at some finite (and reasonably small) order and still get an answer that's a good approximation to the true one. Computer calculations help you to be able to extend this out to more orders before the computation becomes intractable.
This answer my question.
Thanks
Many (most?) perturbation expansions in physics do not converge. They are asymptotic series, meaning that taking finitely many terms gives you an increasingly better answer, but then the series begins to diverge. This is true for most Feynman diagram expansions in QFT as well. This can sometimes be handled using resumption methods.
The 430 discussed there was a purely theoretical exercise, we have no way of calculating things like that.
5 loops have been done, but only for one particular process where extreme precision is necessary.
Typically calculations are NLO (next to leading order) or NNLO. A few processes have been calculated with NNNLO precision, while some Monte Carlo generators might still work with LO.
As rule of thumb for measurements done at the LHC: LO gives you a rough idea how frequent the process is, NLO gives you a good estimate, and NNLO adds a good estimate about the uncertainty of the calculation.
That's not what an asymptotic series is, nor is it the typical behavior in a Dyson series.
Perhaps you are misinterpreting my post? I meant that an asymptotic series gives a good estimate after truncating a particular number of terms, and begins to become a worse approximation after that. Both QED and phi^4 theory have this property (as well as perturbing the quantum 1D simple harmonic oscillator with an x^4 term in QM). What I am saying is not anything different than the first sentence in Wikipedia's definition of an asymptotic series, or what Urs Schreiber says here: https://www.physicsforums.com/threa...rimental-relevance.924921/page-2#post-5840472
  • · Replies 89 ·
