What p(x) should be in shell method
  • Thread starter Thread starter en bloc
    Method Shell
7 replies · 6K views
en bloc
y=x^(1/2) x=4
find volume of revolution about the line x=4
this was a test problem and i chose x as p(x) [radius] but now i think that it should've been (x+4).
:confused:
en bloc said:
y=x^(1/2) x=4
:confused:
I'm confused too !
What question are you asking?
In calculus II, graphing a function and then revolving it around an axis. calculate that volume either by disk/washer method or shell method.
and the formula for the shell method is 2\pi \int_{a}^{b} (p(y)h(y))\,dy
o:)
o:)
Yes, of course! I get that, but what did you mean by
y=x^(1/2) x=4​
I'd rather not have to guess when I'm answering someones question.
it's the region bounded by y = [itex]\sqrt{}x[/itex] and x = 4
You need at least one more boundary; perhaps the x-axis ?
i thought the same thing, y = 0, but it wasn't given. part (a) of the problem was revolution around the x-axis. i just implicitly assumed it was. so what would p(x) be in this region.
en bloc said:
y=x^(1/2) x=4
:confused:
Assuming that the problem is:
Find the volume of revolution, using the shell method, if the region bounded by y=x1/2, x=4, and y=0 is revolved about the line x = 4.​
The radius is the distance that an arbitrary value of x is from x=4. That distance is |x-4|. Assuming that the integration is done
from x = 0 to x = 4, then, |x-4| = 4 - x .
