What Stops a Falling Rock at the Atomic Level?
  • Context: Graduate
  • Thread starter Thread starter jammiecg
    Falling Rock
The discussion centers on the mechanics of a falling rock and the forces at play when it impacts the ground. It is established that while gravitational potential energy converts to kinetic energy during the fall, upon impact, electrostatic repulsion between atoms in the rock and the ground halts further descent. This interaction generates heat due to energy conversion into vibrations and deformation, explaining why the ground warms upon the rock's arrival. The conversation highlights the balance of forces at the atomic level, emphasizing the role of electrostatic forces over gravitational pull in stopping the rock.
  • Understanding of gravitational potential energy and kinetic energy
  • Familiarity with electrostatic forces and atomic interactions
  • Basic knowledge of thermodynamics related to energy conversion
  • Concepts of momentum and mechanical energy changes
  • Research the principles of electrostatic repulsion in atomic structures
  • Explore thermodynamic processes related to energy conversion upon impact
  • Study the concepts of momentum and energy conservation in physics
  • Investigate the effects of vibrations and deformation on material properties
Physics students, material scientists, and anyone interested in the fundamental forces governing motion and energy transformation at the atomic level.
jammiecg
I don't understand this, potential gravitation says that if i drop a rock it's energy is converted into kinetic energy of motion as it falls, so that the higher up it is released the more energy it has kinetically when it hits the ground, both balance out the potential and kinetic energy so that no energy is created or destroyed just converted from one form to another, makes sense...
but my question is when the rock hits the ground and stops, gravity still pulls on every moving atom right? Does that mean it's still somehow falling on the atomic scale, creating heat? That can't be true what stops it from falling on the atomic level is it just electrostatic repulsion?
The electrostatic bonds in the ground and rock are strong enough to prevent the rock from falling further into the ground.
The ground under and around the where the rock came to rest will be warmer then it was before the rock arrived.
welcome to pf!
hi jammiecg! welcome to pf! :wink:
there's two questions …
why does it slow down at all? and why doesn't it bounce back to where it started from?
in other words: why does the momentum change? and why does the (mechanical) energy change?
the momentum changes because (as soothsayer :smile: said), when close-up, the electrostatic forces are stronger than gravity
the (mechanical) energy changes because (as Jobrag :smile: said) some of it is converted into heat (also vibration, noise, and deformation) :wink:
  • · Replies 21 ·
  • · Replies 26 ·
9K
11K
  • · Replies 35 ·
  • · Replies 17 ·
