What Was the Initial Energy of a Positron Entering a Plastic Slab?
A positron with an energy of 1.62 MeV exits a 4-mm thick plastic slab, and the goal is to determine its initial energy upon entering. The calculations involve using the range equations for beta particles, which relate energy to distance traveled in the material. Initial results suggest an entry energy of 2.5 MeV, but the expected value is 2.2 MeV, raising questions about the calculations. Participants discuss the relevance of density and thickness in determining energy loss, emphasizing that the positron is a mono-energetic particle. The consensus leans towards verifying the calculations by testing the 2.2 MeV assumption to see if it aligns with the observed exit energy.
Binder12345
Q- a positron emerges normally from a 4-mm thick slab of plastic (density= 1.14g/cm^3) with an energy of 1.62 MeV. What is the energy of the particle when it entered the slab?
Range when 0< T <= 2.5 MeV: R= .412+T^[1.27-.0954*ln(T)] where T is kinetic energy of beta particle
also ln(T)= 6.63-3.24[3.29-ln(R)]^.5
Ok I know initial slab is 4mm or .4 cm and has a density of 1.14 g/cm^3. thus it has a range of .456 g/cm^2
now the range of the beta particle after it left the slab with E= 1.62 MeV is:
R= .412*1.62^[1.27 - .0954*ln(1.62)]= .744
now range total is just: R_total = .456 + .744 = 1.2
now we can solve what the initial T was going into the slab via:
ln(T) = 6.63-3.24[3.29-ln(1.2)]^.5= .9183
thus T= e^(.9183) = 2.5 MeV
However I should be getting 2.2 MeV. Does anyone see where I am going wrong?
Hi,
for me it is not a problem of beta range in matter.
In the problem you have not a beta Spectrum and you must calculate the Energy lost in platic.
PSRB191921 said:
Hi,
This is a single mono-energetic particle. Shouldn't need a beta spectrum.
"This is a single mono-energetic particle. Shouldn't need a beta spectrum. "
it is a question or an affirmation ?
Affirmation. I know I am not suppose to use a beta spectrum here. I may be starting to convince myself 2.2 from the back of the book is actually wrong
but it is not a problem of beta range in matter.
you must calculate the Energy lost in platic of a mono-energetic positrion.
I'm trying to follow your calculations to check them but having a great deal of difficulty. Can you explain these equations a little more? For instance:
What is this equation? Range in what medium?
Here is an entirely different relationship between T and R. At a glance, they are not the same relationship. So why are you saying that both of these relationships between T and R are applicable? What is this one? Under what assumptions?
Thus, WHAT has a range of 0.456 g/cm^2? And how is "g/cm^2" a range? A range is a distance probably in meters. What formula did you use to calculate this quantity?
Oh wait. Is that the product of those two things? So that's the number of grams per cm^2 cross section of the slab? How is that relevant? The particle only goes through one point, cross-section area doesn't come into it in any way, shape or form.
You're trying to find out how much energy was lost in passing through the slab. I don't see any "relevant equation" you provided where the material properties are related to energy. So what exactly did go into your calculation and what equation did you use that took the density of the material into account?
This is the range of a beta particle in any medium that has an effective Z of <10
Also that second relationship is given to me. See image.
The assumption we are making in this problem is that the electron will travel in a straight line through the medium. I know this isn't true at all but for the purposes of this problem that is what they want us to do. Therefore with that assumption we can use the range of the beta particle to give us an approximation how far the particle will travel. I attached an example of a similar type of calculation from the book as well.
I suspect that you're right.
Why don't you try plugging 2.2 MeV as the starting energy and work the example you posted above in exactly the same way that they did (using your density and thickness of course) and see if you can arrive at a 1.62 MeV positron exiting the slab?
Likes Binder12345
Thank you!
OK, I find this terminology strange but I accept that this "length" terminology is used for the parameter R which is related to the number of encounters the particle experiences while passing through the material, and that this length (that reference calls it "interaction depth") is in units of mass/length^2.
http://cosmic.lbl.gov/SKliewer/Cosmic_Rays/Interaction.htm
There are other things I find strange about the terminology in your example, but I'll let it go. I agree with the suggestion to start with a 2.2 MeV particle and see what energy you end up with, using exactly the same calculations.
Your analysis given the additional information seems correct. Since R is proportional to path, it is additive.
Likes gneill and Binder12345
