What was the value of the permeability constant in 1865?
The permeability constant (μ₀) in 1865, during the publication of Maxwell's theory, was not explicitly defined in modern SI units, as Maxwell utilized a different unit system (cgs). The relationship between the speed of electromagnetic radiation (v) and the permeability constant is expressed through the equation v = 1/√(μ₀ ε₀), which was a later interpretation of Maxwell's work. Historical documentation indicates that Maxwell observed the ratio of electromagnetic units, leading to the conclusion that this ratio approximated the speed of light (c) at 3 x 10^8 m/s. The original derivation of radiation speed is complex and requires further investigation into Maxwell's calculations and the cgs unit system.
  • Understanding of Maxwell's equations and electromagnetic theory
  • Familiarity with the cgs (centimeter-gram-second) unit system
  • Knowledge of the relationship between permeability (μ₀) and permittivity (ε₀)
  • Basic grasp of the historical context of physics in the 19th century
  • Research the historical context of Maxwell's equations and their original formulations
  • Study the cgs unit system, focusing on electromagnetic units (emu and esu)
  • Examine the derivation of the speed of light in modern electromagnetic theory
  • Explore the implications of permeability and permittivity in modern physics
Students of physics, historians of science, and anyone interested in the evolution of electromagnetic theory and its foundational constants.
avicenna
What is the value of the permeability constant in 1865, the time when Maxwell's theory was first published? What was the experimental method used to determine the constant. Who did the experiment.
anorlunda said:
I'm not sure. Try reading the papers linked in this article.
https://en.wikipedia.org/wiki/Oliver_Heaviside
Nothing there.
It is said Maxwell discovered that the speed of radiation v = 1/√(μ₀ ε₀) and v happened to be near the known speed of light then. So in 1865, there should be an accepted value of μ₀. But google gives no clue at all. Why so difficult to trace history of permeability constant?
Maxwell didn't actually use the equation ##v = \frac 1 {\sqrt {\mu_0 \epsilon_0}}##. That equation uses SI units which hadn't been codified in Maxwell's day. He used a different set of units, and indeed different names for many electromagnetic quantities. The equation we use nowadays should be considered a modern "translation" or "interpretation" of Maxwell's calculations. For what it's worth, you can see what Maxwell actually wrote when he calculated the theoretical speed of his electromagnetic waves:
https://en.wikisource.org/wiki/Page:Philosophical_magazine_23_series_4.djvu/38
OK. The original derivation of radiation speed is too difficult for me. I don't really know how our modern EM speed derivation may be related or compared to Maxwell's original.
In the cgs system in use at that time (and also when I was at school) there are two sets of units, emu and esu. The emu is current (charge x velocity) necessary to produce a force of 1 dyne between two conductors, and the esu is the charge necessary to produce a force of 1 dyne between two charges, all spaced 1cm. For a vacuum, permeability and permittivity were defined as 1. Maxwell noticed that the ratio of these two units was about equal to 3 x 10^8 m/s, which is c.
Great! Very helpful. Though I don't understand it now, this is the hint if I want to investigate further. I do know that the force between currents in conductors is related to the magnetic field and thus to permeability. The other is simply related to permittivity.
  • · Replies 16 ·
  • · Replies 42 ·
