What would happen if 6 black holes surrounded a planet?
The discussion revolves around the hypothetical scenario of a planet surrounded by six black holes of equal mass and whether such a configuration could allow the planet to survive in equilibrium. Participants explore the gravitational dynamics, the implications of black hole interactions, and the geometric considerations of the arrangement.
  • One participant proposes the idea of a planet being surrounded by six black holes held in equilibrium, questioning if such a scenario is possible.
  • Another participant challenges the concept of equilibrium, asking what would prevent the black holes from crashing into each other.
  • A participant mentions that the gravitational effects of black holes are similar to those of ordinary stars, suggesting that orbits could be established.
  • Concerns are raised about how to achieve stable orbits for black holes not in the same plane, distinguishing between "orbit" and "equilibrium."
  • One participant uses an analogy involving vacuum cleaners to illustrate their idea of equilibrium among black holes, which is met with skepticism regarding its validity.
  • Another participant argues that gravity is always attractive and questions the feasibility of maintaining equilibrium among the black holes.
  • A detailed explanation is provided regarding the destructive tidal forces a planet would experience if surrounded by black holes, emphasizing the catastrophic consequences for the planet.
  • Participants discuss the significance of the number six in the context of surrounding a planet, with some suggesting alternative configurations.
  • There is a contention over the relevance of geometric arrangements, with some participants asserting that gravity must be considered in any configuration of masses.
Participants do not reach consensus on the feasibility of a planet surviving surrounded by six black holes. There are competing views on the nature of gravitational interactions and the implications of equilibrium versus collision among the black holes.
Limitations include assumptions about the masses of the black holes, the distances involved, and the nature of gravitational interactions in such a scenario. The discussion also touches on the geometric arrangement of the black holes and its implications for gravitational effects.
phillovix
Hey, was trying to think of what the safest possible place in existence would be and got to thinking of a planet surrounded by 6 black holes of equal size.
Say the black holes met around this planet at the precious same time and are held in equilibrium, is there any particular reason that a planet couldn't survive in the area between?
(One above, one below and one on each side, as opposed to in a circular pattern.)
Excluding the planet for a moment, could 6 black holes be held in equilibrium by the force of it's neighbors?
No interest in discussing the improbability and I understand that doing the maths on a question like this is laughable, so, just based on your understanding of black holes, is this something that is even possible?
Thank you!
<3 Phill
Astronomy news on Phys.org
By what, exactly? What keeps them from all crashing in on each other?
As long as you don't fall in, the gravitational effects and orbital dynamics of a black hole are the same as you'd find outside an ordinary star of equivalent mass - for example, if our sun were to collapse into a black hole the orbit of the Earth would be unaffected.
So any orbits you can set up with six ordinary masses you can set up with six black holes.
How do you make a stable orbit for the two BH's not in the equatorial plane?
Also, he didn't say "orbit", he said "equilibrium". How does that happen?
I was envisioning something like them all being of the precise same mass and they all happen to be on course to crash into each other at the precise same time, to the extent that the point of crash is so undecided that an equilibrium is reached in the crash not actually occurring.
I am thinking of a pingpong ball being sucked into a vacuum cleaner and then adding another vacuum cleaner of the same suction value that then holds the ball between the two vacuums instead of having it crash into either of them. Applying that type of logic to having multiple black holes meeting at the same time/point at the perfect angle.
Kinda like each black hole preventing the others from reaching the central point.
It makes sense to me in mild autism town, am curious as to how it holds up to scientific scrutiny.
Kind regards,
Phill
Greetings from mild autism town.
The reason you are being asked "how" is that black holes are all about mass and gravity,. and gravity is always an attractive force. Your vacuum cleaner/ping pong ball example is bad because all the suction from the vacuum cleaner is applied to the ping pong ball, whereas all the gravity from the black hole is not applied to the planet. The six black holes would attract not just the planet, but also each other, and they would crash into each other.
So, let's assume that you somehow have stopped the black holes from advancing toward each other. Could a planet survive in the space between?
No.
Assume the following - six one solar mass black holes, surrounding an Earthlike planet at a distance of our moon's orbit (so you can legitimately say "this planet is surrounded by six black holes). The escape velocity of each of those black holes would be 832 km/s for the side of the planet facing the black hole, and 812 km/s for the side of the planet facing away from the black hole. For comparison, the escape velocity of the Earth is 11.2km/s.
The planet would experience horrible tidal forces - The atmosphere would be ripped away, the surface stripped bare, and the denuded body would be torn into chunks. Those chunks would then be torn into bits. Eventually those bits would be torn into even smaller bits and those bits would be superheated and absorbed. To call it "bad" for the planet would be an understatement.
Please do not try this at home.
http://www.calctool.org/CALC/phys/astronomy/escape_velocity
(mass of one sun, distance of 238,000 and 250,000 miles, representing a 12,000 mile diameter planet)
Is that what you mean? That since there will be a 6- or 7-way collision all at once that the collision will not occur at all? Nature doesn't work that way, I'm afraid.
Cool cool, thank you all for your time, back to the drawing board!
Kind regards,
Phill
Just wondered if the number six has any significance for this question.
You could say five or seven, does it matter?
The line of thought was from the amount of sides of a cube. Figured that would be sufficient to surround a planet.
rootone said:
here is something worthy of considering.
No, it's not worth considering. This idea is totally wrong, and you do PF a disservice by encouraging it.
Hmm sorry, I thought baez was considered to be a sound reference in many regards.
What I meant was that a cube is not the only way to envisage a symmetrical arrangement of points.
I am not denying the concept of Platonic solids. IK am denying the concept of masses arranged as vertices of Platonic solids not having gravity. As I said, that idea is totally wrong, and you do PF a disservice by encouraging it.
The original question has been answered: no it does not work at all. Please make a new thread for discussions about Platonian solids or other unrelated topics.
This is a good point to close this thread.
  • · Replies 73 ·
9K
  • · Replies 49 ·
