B What would happen if the speed of light were different?
Hrithik mudaliar
if speed of light were not 3*10 ^8 m/s and something else would it affect the reality ?
No
Likes Dale
This topic has come up several times. You'll often get a faster answer with a forum search.
You can't just change the speed of light, because the physical constants are linked. So you also have to specify what else you are changing and what you are not - and at least one other thing must change.
Generally, if you work through the consequences of such a change there is no effect. It turns out to be a Byzantine way of changing your units. Obviously we can halve the value of the speed of light by defining the metre to be twice what it is, and obviously this makes no difference to anything.
The exception turns out to be if you change the fine structure constant, which is a dimensionless number which relates the speed of light to the strength of the electromagnetic interaction. Since you (and everything else) are held together by electromagnetic interactions between your atoms, this changes the relationship between your size and the speed of light. In other words, this actually changes the relationship between monkey arm lengths (~1m), monkey heart beats (~1s), and the speed of light (a natural scale factor between distance and time units).
I don't think mucking around with the fine structure constant has any effect classically beyond changing the speed of light (or, at least, being interpretable as a change in the speed of light). My quantum (what I ever knew of it) is way too rusty to know if there are effects there - others may know.
but if doesn't change anything how would we know that the speed of light was constant over the time ? and it was changing over the time as the universe was expanding
We can just define the speed of light to be constant over time.
What physicists are actually interested in is whether the fine structure constant is constant over time. That is a matter of real physics, not just unit choices.
Likes Sorcerer
In case you didn't know...
That's the speed of light in a vacuum. It's different in other media like water (about 25% slower).
As others have mentioned, experimental tests to see of the speed of light changes with time usually revolve around looking for changes in the fine structure constant.
The fine structure constant is something that one can measure that doesn't depend on one's units system. If you believe that plank's constant, the charge on the electron and the permittivity of free space are all constant, then detecting a change in the fine structure constant would be equivalent to saying the speed of light varies. Such experimental tests as have been done for changes in c really measure the fine structure constant (as far as I know), so if you want to look at the experimental literature, that's a good place to start.
Talking about changes in the fine structure constant eliminates trivial "changes" in the speed of light that amount to changes in units. For instance, the speed of light is about 9.8e8 feet/second. If one called a meter a foot, one might claim that the change of nomenclature "changed" the speed of light, but it was really just a changing in words, not a change in physics.
Considering only dimensionless quantities such as the fine structure constant eliminates this sort of confusion, because the units all cancel out and it's a pure number that's independent of one's choice of units.
Hi @Dale:
I think you (and others) misunderstood what the OP was asking. Suppose I rephrase the OP question as follow:
Suppose the fine structure constant, α = 2π e2 / h c, actually had a different value some time in the past, t, than it does now, t0, and the values of e and h are unchanged. This would imply that the speed of light in vacuum would also have had a different value at time t. Under this assumption, what astronomical measurements could be detected now that would confirm this had happen?​
Obliviously the answer would depend on how large a change there was, so the most useful answer would assume the smallest changes, both + and -, that would result in some detectable measurements now.
Regards,
Buzz
This is a meaningful question, yes.
But this is not. If the fine structure constant changes, it is entirely up to your choice of units which of c, e, and h you want to change; you could choose for anyone of them to change, or any two, or all three. So there is no physical meaning to asking which one of c, e, and h "actually" changed. The only physically meaningful question is whether the fine structure constant changed.
Likes Sorcerer
Hi Peter:
I confess I find your post to be quite fascinating. I would much appreciate your explanation about how the energy E of a photon is measured, and why this measurement depends on knowing the speed of light. I am assuming that it is not a problem to measure the frequency f of a photon without knowing the speed of light. If both h and f can be measured without knowing c, then since E = h f, h could then be determined without knowing the value of c.
I may also be misunderstanding the description of the Millikan’s experiment
https://users.wfu.edu/~bonin/Intermediate_Lab_Phys_265/Millikan_Oil_Drop_Charge_electron.pdf​
which seems to be measuring e without requiring knowledge of c. I understand that measuring e requires measuring voltage, and I was not able to find on the Internet what the method is for establishing the standard for the volt unit. So, I may be mistaken, and the establishment of the volt unit might require knowing the speed of light.
Regards,
Buzz
Who said it did?
How would you measure the frequency of a photon?
The usual way of "measuring" the frequency of a photon is to measure its energy and divide by Planck's constant.
Yes. So what?
Did you try Google? I did and found the Wikipedia page on "Volt" pretty easily.
PeterDonis said:
Who said it did?
Hi Peter:
Obviously I misunderstood the meaning of:
My interpretation was that given α = 2π e2 / h c, if α changes, and e does not change and h does not change, then the change is α must be due a change in c. If e can be measured without specifying a value for c, and e can be measured without specifying a value for c, then the changed value of c can be calculated: c = 2π e2 / h α.
That is, under the assumptions of h and e being measured and found to not change in value, then c changes inversely to α. If that is correct, what is the meaning of: "So there is no physical meaning to asking which one of c, e, and h 'actually' changed,"?
Regards,
Buzz
Please go back and read my post again, carefully. This is not what I said.
Buzz Bloom said:
If that is correct
It isn't. Go back and read my post again, carefully.
You are confusing yourself by thinking that you measure h, e, and c. You don't. You measure ##\alpha##. (More precisely, you observe and record physical events whose relationships depend on ##\alpha##.) The formula ##\alpha = 2 \pi e^2 / h c## does not tell you how to calculate ##\alpha## once you've measured h, e, and c. It tells you how your measurement of ##\alpha## is related to other measurements. Summarizing the results of lots of different measurements in constants like h, e, and c, which have units, is a matter of convenience (and historical practice), not physics; all of the actual physics is in dimensionless numbers like ##\alpha##.
Hi Peter:
I get from this that the "usual" way of measuring frequency depends on knowing h, so using that method would not allow for the determination of h from E and f. Are you saying that all methods of determining frequency depend on the prior knowing h?
Regards,
Buzz
Hi Peter:
I did not say that this
is what you said. I said it was my interpretation of what you said, and I also indicated that I realized my interpretation was incorrect.
I confess that I am having difficulty understanding the meaning of you posts, and reading them again will not help me. You last paragraph did provide some help.
PeterDonis said:
You are confusing yourself by thinking that you measure h, e, and c. You don't. You measure α\alpha. (More precisely, you observe and record physical events whose relationships depend on α\alpha.) The formula α=2πe2/hc\alpha = 2 \pi e^2 / h c does not tell you how to calculate α\alpha once you've measured h, e, and c. It tells you how your measurement of α\alpha is related to other measurements. Summarizing the results of lots of different measurements in constants like h, e, and c, which have units, is a matter of convenience (and historical practice), not physics; all of the actual physics is in dimensionless numbers like α\alpha.
What is still a mystery to me is that I do not understand the reason that,
"The formula α=2π e2/ h c does not tell you how to calculate α once you've measured h, e, and c."
If h, e, and c, can be measured independently of knowing the value of α, what prevents the value of α from being calculated in this manner? I understand that this is not the "usual" way α is measured, but if this calculated determination of α is significantly different than the "usual" determination of α, wouldn't this result be of interest to physicists?
Regards,
Buzz
Hi Peter:
Thank you for the reference. I did previously look at this Wikipedia article but skipped over the discussion about the Josephson junction since it was way over my head. After your citing the reference I found some more detailed references with somewhat understandable discussions. I was able to satisfy myself that a voltage value could be determined without any knowledge of values for α, e, h, and c. From this I concluded that the value of e could be determined using the Michelson method without any knowledge of values for the other 3 constants.
Regards,
Buzz
They can't. Or, more precisely, there's a hidden assumption somewhere in any experiment that purports to measure them. For example, if you try to measure the speed of light you'll need a meter rule somewhere and its length depends on the strength of the interaction between atoms, which depends on e. I seem to recall @Dale worked this out in more detail recently, but I can't find the post at the moment.
Likes Buzz Bloom
How?
The fact that you can make a particular measurement without knowing the value of ##\alpha## does not mean that the process you are measuring does not depend on the value of ##\alpha##. This confusion seems to be a crucial one for you in this discussion.
PeterDonis said:
How?
Hi Peter:
Here is the URLs for the articles I was using for a reference.
Figure 1 in the 2nd reference has the following caption.
Fig. 1.One-volt NIST Josephson Junction array standard having 3020 junctions. The chip was designed and built by staff of the Electromagnetic Technology Division in Boulder in the cryoelectronic fabrication laboratory. It operates at liquid-helium temperatures; microwave energy is fed to four chains of junctions through the finguide structure at the left. The thin tapered structures at the end of each chain are terminations to prevent reflection of energy back up the chain.​
My understanding from what I perused (as best I could) is that NIST has produced (1991) a stable 1 volt standard apparatus.
In 1991 NIST conducted the first JVS laboratory comparison experiment using transportable 10 V Zener standards, in which five other U.S.industrial and military laboratories participated [22]. Such comparisons are now carried out regularly under the auspices of the National Conference of Standards Laboratories, an industry trade association, with support from NIST as necessary.​
I conclude (perhaps erroneously) that this apparatus could be used to establish a Michelson setup with a controlled voltage to determine the value of e.
Regards,
Buzz
Ok, but does the behavior of this apparatus depend on the value of ##\alpha##? (Hint: the answer is yes.)
Likes Dale
PeterDonis said:
The fact that you can make a particular measurement without knowing the value of α\alpha does not mean that the process you are measuring does not depend on the value of α\alpha. This confusion seems to be a crucial one for you in this discussion.
Hi Peter:
Thanks for the post. I need to digest this quote for a while before I can determine if I can correctly understand its implications.
Regards,
Buzz
PeterDonis said:
Ok, but does the behavior of this apparatus depend on the value of α\alpha? (Hint: the answer is yes.)
Hi Peter:
I accept that your quote is correct, and that this means that the thought experiments I have been considering are flawed since it must be the case that efforts to measure a value for any of the four constants have hidden dependencies of the value of one or more other constants. I accept that for the present I am not able to understand the nature of these hidden dependencies. Thank you for making this clear to me.
Regards,
Buzz
Buzz Bloom said:
it must be the case that efforts to measure a value for any of the four constants has hidden dependencies of the value of one or more other constants
It's not that: it's that there is really only one constant here, ##\alpha##. That is the only value with physical meaning in the set you give. The others are just choices of units.
Thinking about concrete examples might help. Consider the following collection of devices:
A standard 1 Volt Josephson junction array as described in your links.
A cesium clock such as those used in the SI definition of the second.
An oil drop experiment.
A photoelectric effect experiment.
(We could add more, but this should be enough for the point I'm going to make.)
You can think of these devices as devices for "measuring" physical constants like e or c or h. And you can think of then combining the results using the formula given earlier in this thread to "calculate" a value for ##\alpha##. But that gets things backwards. Actually, all of these experiments are experiments for measuring the value of ##\alpha##: more precisely, the value of ##\alpha## (and the values of other dimensionless constants--for example, the effect of gravity of the oil drop affects the result of the oil drop experiment, and ##\alpha## doesn't describe anything about gravity) governs the relationship between what is observed in all of these different devices. Different choices of units are just different ways of expressing that relationship, depending on which device we want to focus on.
Now let's go back to the original question in this thread: how would we tell if the values of any of these constants have changed over time? The point is that any such change won't just change one of these devices; it will change all of them. More precisely, if you just look at one of these devices, there is no way to tell if its behavior has "changed" over time. Suppose I told you that the value of a Volt was different a billion years ago. You interpret that as saying that the behavior of a standard Josephson junction array was different a billion years ago. But how would you tell? If all you look at is standard Josephson junction arrays, there is no way to tell. Those arrays define what you mean by a Volt. You have to look at multiple devices and the relationship between them to tell if anything has "changed"; and changes in those relationships are changes in ##\alpha## (and other dimensionless constants involved with whatever other interactions are present). There is no way to isolate the changes to just e, c, or h, because there is no way to tell that something changed by just looking at one device.
This one is very easy in SI units. In SI units the energy of a photon is measured in joules. 1 J is a derived unit which is equal to 1 kg m^2/s^2. So the meter is part of any measurement of energy in SI units. In SI units the meter is defined in terms of c. So to measure the energy of a photon in SI units does require knowing c in SI units also.
Note: this argument is specific to SI units and may not apply in other unit systems. That is the point, the dimensionful constants give you information about your unit system, not about physics.
Buzz Bloom said:
Millikan’s experiment ... which seems to be measuring e without requiring knowledge of c.
It is not an issue of the experiment, it is an issue of the units.
Hi Peter and Dale:
I think I may have come to an understanding of these above quotes, particularly with respect to c.
https://en.wikipedia.org/wiki/International_System_of_Units#Base_units
Second (Current as of 1967): The duration of 9192631770 periods of the radiation corresponding to the transition between the two hyperfine levels of the ground state of the caesium-133 atom.
Meter (Current as of 1983): The distance traveled by light in vacuum in 1/299792458 second.​
https://en.wikipedia.org/wiki/Speed_of_light
The speed of light in vacuum, commonly denoted c, is a universal physical constant important in many areas of physics. Its exact value is 299,792,458 meters per second.​
This means that by definition the value of c (using any units) cannot change. In effect c is defined as 1 light-second per second. If it should (hypothetically) happen that the number of seconds (or picoseconds) it takes light to travel (in vacuum) over an actual specific physical distance is measured to have changed, c would not change. What would then change is the actually physical distance corresponding to a meter. What I would guess would likely happen then is that the International Bureau of Weights and Measures (BIPM, Bureau International des Poids et Mesures) and the International Committee for Weights and/or Measures (CIPM, Comité International des Poids et Mesures) would redefine the meter independently of the speed of light, since (by the hypothetical assumption of its change) the current definition would no longer be stable.
It the above a correct interpretation of the top two quotes?
ADDED
Another possible interpretation would be that the speed of light cannot change because if it did, the actual lengths of physical things would also change so that the the number of seconds for light to travel the physical distance would remain unchanged. I find this interpretation too difficult conceptually for me to absorb.
ANOTHER ADDITION
I found the following quote from Dale at
https://www.physicsforums.com/threa...-meters-per-second.279798/page-3#post-2011753 .
I wanted to work out what would be the experimental result if the speed of light doubled but the fine structure constant was unchanged.​
Assuming α changes due to the change in c, but no other "constants" change (e and h), would this change in α change the time measured by the cesium clock which would make the measured time for light to travel the physical distance to be unchanged?
Regards,
Buzz
No, it just means the value of ##c## in SI units cannot change, because it's not measured any more, it's defined to be a specific number.
No, it isn't, because in those units, the numerical value of ##c## is ##1##, not ##299,792,458##. The only thing such units have in common with SI units is that the value of ##c## is defined, not measured.
How would you measure this?
You still don't appear to grasp the fundamental point: the fine structure constant is the one with physical meaning. If the fine structure constant is unchanged, all experimental results are unchanged. The only way for experimental results to change is if the fine structure constant changes.
But you just said the fine structure constant was unchanged. That's inconsistent with this sentence.
Also, again, you are missing the point that has already been made several times: if the fine structure constant changes, it is not "due to" a change in c, e, or h. Which of c, e, and h change if the fine structure constant changes is a matter of choice of units, not physics. The physics is all in the fine structure constant.
I think you are confusing yourself more and more instead of improving your understanding. I strongly suggest taking a step back and thinking carefully about the two sentences in italics above. Any time you find yourself saying or thinking something that is not consistent with those two sentences, you are doing it wrong and need to stop.
  • #31
Hi Peter:
I would very much like to understand the meaning of this quote. I do not want to introduce philosophy, so I will just mention briefly what I perceive to be the problem with my mental ability to understand this quote. It seems to have logical implications that contradict my philosophical view of reality.
PeterDonis said:
No, it just means the value of c in SI units cannot change, because it's not measured any more, it's defined to be a specific number.
I was assuming that any alternate system of defining units would relate to SI units by constants. For example, in cgs units, 1 centimeter = 1/100 of a meter, and 1 gram = 1/1000 of a kilogram. Also in British Imperial units, 1 foot = 0.3048 meters, and 1 pound = 0.45359237 kilograms. If this is a generally correct assumption, then using any unit from a system of units with this kind of definition relative to SI units would leave the value of c unchanged.
I assume a suitable device which measures the time difference in picoseconds (ps) between two signals, where these ps units are carefully controlled to be in terms of the cesium definition of a second. I assume a straight underground tunnel which contains as close to a vacuum as practically possible. The length of the tunnel is assumed to be unchanging over time. There is an apparatus at one end which emits a laser pulse when a button is pushed by an experimenter outside of the tunnel. The button push also starts the counting of picoseconds by a suitable digital counter. The apparatus also includes a radar pulse detector which stops the counter when it detects a pulse. At the other end of the tunnel is a mirror that reflects the radar pulse from the emitter back to the detector. The use of this apparatus is repeated from time to time to measure the time (in picoseconds) it takes for a pulse to move from the emitter to the mirror to the detector. There may also be auxiliary devices to detect possible disturbances that would effect the time measurement, for example, a device for detecting seismological disturbances due to earthquakes.
The quote I posted in #29 was an answer by Dale to a similar but different question (in which α did not change) posted in a different thread which I cited. I quoted it because @Dale's answer suggested to me that he was likely to be able to answer the different question (where α did change) which I asked in that context.
Regards,
Buzz
  • #32
You assume incorrectly. SI units define a meter as the distance light travels in 9192631770/299792458 periods of the radiation corresponding to the transition between the two hyperfine levels of the ground state of the caesium-133 atom. Other systems of units do not define their unit of distance this way, so their relationship to SI units might not be constant. For example, the original definition of the meter was, IIRC, 1/40,000,000 of the polar circumference of the Earth. But the Earth's polar circumference changes over time by small amounts for various reasons; as it does, the relationship of a meter defined this way to the current SI meter changes. The same would be true for other distance units defined in terms of some physical object, or by some other method that did not involve the propagation of light.
No, it wouldn't, because 299,792,458 is a different number from 1. So 299,792,458 meters per second is not the same, numerically, as 1 light-second per second. They both describe the same speed, but they're not numerically the same; they are different choices of units. Just as, for example, 100 kilometers per hour and 62.137 miles per hour both describe the same speed, but they're not numerically the same; they are different choices of units.
In other words, "the value of c" means "the number we use to describe the speed of light". So 299,792,458 is not the same value of c as 1. I don't see why that is difficult to grasp; it seems to me that you are making this much more difficult than it needs to be by overthinking and confusing yourself. The value of c is not the same as the general method by which c is defined.
Why would you assume that? It seems obvious that the length of the tunnel could change for all sorts of reasons. (Maybe the temperature was slightly different; maybe there was a small tectonic shift; etc., etc.) If this is the only measuring device you have, you have no way of telling whether changes in your readings are due to an actual change in a physical constant, or just to changes in the tunnel.
And how do you know you are detecting all possible disturbances? You can't.
This is why I said that physical constants like ##\alpha## tell you about the relationships between different measurements made in different ways. You can't tell if ##\alpha## changed just from a single kind of measurement, because you can't distinguish changes in the physical constant from changes in the measuring apparatus.
  • #33
I have no idea what this is supposed to mean. You said in one sentence that ##\alpha## was assumed to be unchanged, and in the very next sentence, with no signal of any change in context, that ##\alpha## was assumed to change. That doesn't make sense.
I wouldn't bother belaboring this if it were just an isolated instance, but it's not. It's the same pattern you have shown throughout this discussion: you make statements which are confused and don't make sense, which should make you stop and think about the possibility that it's because your thinking about this whole issue is confused and doesn't make sense. Which means, as I've said, that you really, really need to take a big step back and forget everything you think you know about this subject and listen really carefully to what we are telling you, in particular those two italicized statements I made. If those statements appear to contradict your "philosophical view of reality", then perhaps you should consider discarding your philosophical view of reality.
  • #34
Hi Peter:
I would be happy to do what you suggest if I could. The problem is doing so would leave me with no coherent view of reality since I am unable to grasp the reasons for the first quoted statement from my post #31 for which I have failed to grasp it meaning. In particular I do not grasp the meaning of "physics" in this context. What comes to mind from this is that α represents something that has meaning in the field of physics (i.e., physical reality) while c does not. I do not think this is what you intend that quite to mean.
The examples you have given in response to my posts suggest another possible interpretation to this quoted statement. It would help if I might understand the boundaries of the following premises.
1) No measurement involving units (e.g. c) can be made with "sufficient" accuracy because the measuring apparatus and/or the environment in which the measurements are made may always introduce unsatisfactory errors/uncertainties.
2) It is possible for measurements of unitless values (e.g. α) to avoid this limitation because many (most, all?) of the sources of error/uncertainties are related to units.​
Regards,
Buzz
  • #35
When we say the physics is all in the fine structure constant, we mean what I said in my first italicized statement:
So if you are thinking of experimental results changing with the fine structure constant remaining unchanged, you are doing it wrong and need to stop.
Uncertainties in measurement are a different issue and you should ignore them for this discussion. Trying to include them will only confuse you further.
  • #36
Please note that the first statement is made with the second statement in mind. We are assuming that experimental results are not changing due to mundane factors like the temperature of the apparatus changed or a tectonic shift changed the length of a tunnel, or anything like that. As I said, all those things are a different issue and you should ignore them for this discussion.
  • #37
And to further clarify, while you can assume, to simplify your thinking about the issue, that experimental results are not changing due to mundane factors, that doesn't mean you can ignore mundane factors when thinking about what counts as "experimental results changing" in the first place.
For example, consider the "light bouncing off a mirror inside a tunnel" experiment. Basically the "result" of this experiment is the number of periods of radiation corresponding to the transition between two hyperfine levels of the cesium atom that it takes for the light to return after bouncing off the mirror. But, as I said, if this number changes with repeated measurements over time, that by itself does not tell you that ##\alpha## changed; it's also possible that the tunnel could have changed due to some mundane factor. When thinking about how a change in ##\alpha## would affect this number, you can (and should) ignore the possibility of some other mundane factor affecting the number; but when thinking about how you would know if ##\alpha## changed in the real world, you can't ignore that possibility, because that possibility is what tells you that, to really know if ##\alpha## changed, you have to combine numbers obtained from multiple experiments, that involve different phenomena, so that any change in ##\alpha## will change the relationship between the numbers obtained from those multiple experiments (whereas changes in mundane factors would not).
  • #38
Hi Peter:
The reason I raised the "uncertainties" question was because of the response you gave regarding my effort to explain how to detect a change in the speed of liight in responses to your question about that.
PeterDonis said:
This is why I said that physical constants like α\alpha tell you about the relationships between different measurements made in different ways. You can't tell if α\alpha changed just from a single kind of measurement, because you can't distinguish changes in the physical constant from changes in the measuring apparatus.
This is not what I assume. I assume for the purpose of discussing the OP's question that that the speed of light changes, and also the fine structure constant changes correspondingly based on
α = 2π e2 / h c,​
that is, c and α vary reciprocally assuming no changes in e and h.
I understand that the influence of mundane factors will affect experimental results. I may be mistaken about the vocabulary, but I believe these factors are generally referred to as "experimental errors". This point reminds me of an incident my wife experienced when she was an undergraduate at MIT. She was thinking of majoring in physics, but the incident while performing a measurement of the speed of light in the physics lab changed her mind, and she instead majored in math. The incident was that after one effort of measurement she obtained a result that was not reasonably close enough to the known value, so she looked for a problem with the set uo and made some changes, and then repeated the measurement. After several iterations of this process, she obtained a result that was "satisfactory". Then she stopped looking for problems in the set up. She realized that if she had not known the "right" answer in advance, she would not know when to stop experimenting.
Suppose I made multiple measurements as I described for the speed of light, and over a period of time I found small changes which averaged close to zero, threby suggesting a small distribution range of "experimental errors" with the set up. After a while, on one occasion, an anomalous value was measured. Subsequently, all measurements were distributed by small amounts close to this anomalous value, with a distribution similar to the original "experimental errors" measured values were all close to this new value with a significant change only once, afterwards, the this new value was measured every subsequent time
  • #39
Hi Peter:
The following is not what I assume.
α = 2π e2 / h c,​
Suppose I made multiple measurements as I described for the speed of light, and over a period of time I found small changes which were distributed with an average close to the known value, and with a small standard deviation. variance. It seems reasonable that this would suggest that the range of values shows small "experimental errors" with the set up. After a while, on one occasion, an anomalous value was measured with a value significantly different from the previous mean (and known correct) value. Subsequently, all measurements were distributed by small amounts close to this anomalous value, with a standard deviation similar to the original "experimental errors" previously found before the anomaly. One would of course do a search for an explanation involving some failure in the measuring apparatus, but assume nothing of this kind was found.
Parallel with this activity, suppose measurements were "directly" made of the fine-structure constant with apparatus not depending in any way on the speed of light. Suppose that at the same time (more or less) the the speed of light anomaly was found, a similar anomaly is found with the measurement of α. Furthermore. the product of the new mean values for α and c was approximately (with a small error) equal to the former known value for
2π e2 / h.
What could one conclude from this? Would a reasonable interpretation be that the value of α had changed, and that this change was due specifically to a corresponding change in the speed of light, or vice versa.
Regards,
Buzz
  • #40
And these two assumptions embody, not only a change in physics, but a change in the choice of units. What we are trying to get you to do is separate these two choices. You cannot say that ##\alpha## changes and ##c## changes, but ##e## and ##h## do not, without making a particular choice of units, whether you realize it or not. But you can say that ##\alpha## changes without making any choice of units at all. See further comments below.
This happened in at least one significant case historically. Millikan's original oil drop experiment gave a result for ##e## that was different (though not by a lot) from the current value. Other experimenters that tried to replicate his results ended up looking for issues to fix until they got a result that was close enough to his, and then stopping. It took decades for physicists to realize that they should have continued looking for issues to fix because Millikan's value was not quite right.
Buzz Bloom said:
Suppose I made multiple measurements as I described for the speed of light, and over a period of time I found small changes which averaged close to zero, threby suggesting a small distribution range of "experimental errors" with the set up. After a while, on one occasion, an anomalous value was measured. tSubsequently, all measurements were distributed by small amounts close to this anomalous value, with a distribution similar to the original "expeimental errorhe measured values were all close to this new value with a significant change only once, afterwards, the this new value was measured every subsequent time
Then you would have some interesting data which you would need to investigate further. The way to investigate further would be look at other measurements of ##\alpha## using different phenomena that were made over the same time period, to see if they changed, and if so, how. Ultimately you would look for changes in the relationships between the different measurements that could not be explained by mundane factors.
However, there is another aspect of your proposed measurement method that I haven't yet mentioned. When you say that your scheme measures "the speed of light", that is not correct in terms of SI units. As I said before, what it actually measures--the raw number that comes out of the process, before any interpretation is applied to it--is the number of periods of the cesium hyperfine transition that it takes for the light to return after bouncing off the mirror. By the definition of SI units, this is not a measurement of the speed of light, because the speed of light is not measured, it is defined to be the number 299,792,458. So what you are actually measuring, in SI units, is the length of the tunnel in meters. So if the number that comes out of your measurement changes, according to SI units, your hypothesis should not be that the speed of light changed, but that the length of the tunnel changed.
Now suppose that you also have a very long rod that is attached at both ends of the tunnel when you start taking measurements. You attach a very sensitive strain gauge to the rod, so that you can measure very precisely the stress on it; at the start of measurements, the strain gauge reads zero, indicating that, at that instant of time, the rod's unstressed length is exactly equal to the length of the tunnel.
Now consider some possibilities when you find, later on, that the output of your light-mirror setup has changed. If the rod registers a change that corresponds to the change in light-mirror output (for example, the number of periods output by the light-mirror setup increases, and the rod registers tension, indicating that it is being stretched), then you would conclude that the change is due to a change in the tunnel (in the case just described, that the tunnel length is increased). But if the rod strain gauge output does not correspond to the change in light-mirror output (for example, zero stress, or compression, but the number of periods output by the light-mirror setup increases), then you would conclude that ##\alpha## might have changed.
But in the latter case, could you conclude, more specifically, that ##c## had changed, while ##e## and ##h## did not? No, you can't. The internal stresses in the rod depend on ##\alpha##, and they involve interactions between electrons and nuclei in the rod, and quantum energy levels in the rod's atoms, and there is no way, in general, to disentangle all that and say, of the change in ##\alpha##, this much was due to a change in ##e##, this much was due to a change in ##h##, this much was due to a change in ##c##. They are all tangled together, and how you separate them is a choice of units. As I've already said, in SI units ##c## is defined to be constant, so by definition it can't change; so in those units any change in the relationship between the rod strain gauge output and the light-mirror setup output must be due to a change in ##e## or ##h## or both. But if, for example, we took the rod as our standard of length--our unit of length is defined to be whatever the length of the rod is--then any change in the ratio of rod length (as determined by strain gauge output) to light-mirror number of periods would be by definition a change in ##c## (assuming we keep the SI second as our unit of time). And that change in choice of units would have to also change how much ##e## or ##h## changed given the change in rod strain gauge output and light-mirror setup output. But in all of this, the change in ##\alpha## would be the same--a given change in the relationship between rod strain gauge output and light-mirror setup output means a given change in ##\alpha##, regardless of our choice of units. That is what it means to say that the physics is all in ##\alpha##: the change in ##\alpha## is what tells you how much the stuff you actually observed changed.
  • #41
Hi Peter:
I was careful to say the speed of light changed, not that c changed. Using SI units, c cannot change, but why does this imply that the speed of light has not changed. I tried to explain an experimental sequence at the end of my post #39 (last 3 paragraphs) to clarify the meaning of these assumptions. The explanation assumes repeated experiments. In the context of these paragraphs, what could have changed other than the speed of light along with α.
Regards,
Buzz
  • #42
Um, these are the same thing. There is no such thing as "the speed of light" independent of your choice of units. If you think there is, go back and read my italicized statements again. And again.
Sigh. You are still not thinking clearly.
If you have not read and considered in detail the extended example I gave in post #40, go do that now. I'll wait.
Ok, ready? Here we go. Consider the case where you have the following combination of measurements: at the start of taking measurements, the light clock-mirror setup gave an output of ( 9192631770 / 299792458 ) * 100. I.e., the tunnel is 100 SI meters long. And the rod strain gauge reads zero.
After some time, the light clock-mirror setup output changes to ( 9192631770 / 299792458 ) * 100.001 (i.e., the tunnel is now 100.001 SI meters long, i.e., its SI length has increased by 1 millimeter). But the rod strain gauge still reads zero.
Now two physicists are arguing about what these results mean.
Physicist #1: Since ##c## is unchanged, the increase in the light clock-mirror output means the tunnel's length must have increased. Since the rod strain gauge still reads zero, that means ##e## and ##h## must have changed to make the physical properties of the rod different, such that its unstressed length is now 1 millimeter longer than it was before.
Physicist #2: Since the rod strain gauge still reads zero, the physical properties of the rod must be the same. That means ##e## and ##h## must be unchanged, and the rod's length, and hence the tunnel's length, must be unchanged. So the increase in light clock-mirror output means ##c## must have decreased.
Now, first of all, these two physicists are obviously using different units; #1 is using SI units, while #2 is using units in which the rod is the standard of length (or at least in which unstressed objects are assumed to have constant length no matter what else happens).
Second, note that you can substitute "speed of light" for ##c## in the above and it changes nothing. "Speed of light" and ##c## are the same thing.
Third: you are probably bursting to ask me, so, ok, which of these physicists is right? (And that might be the fundamental question you have been groping towards in this discussion.) The correct answer to that question is "mu". The question assumes that there is a "right" answer to the issue they are arguing about; but in fact, both of them are just confused. There is no "right" answer to the issue they are arguing about, because there is no "right" answer to the question of which system of units you should choose. Physically, what has happened in this hypothetical scenario is that ##\alpha## has changed; but, as I said before, how you divide up that change into changes in ##c##, ##e##, and ##h## depends on your choice of units. Physicists #1 and #2 are not (though they think they are) making different claims about "what really happened". They are just choosing different units. What "really happened" is the same either way: the light clock-mirror output number increased while the rod strain gauge stayed at zero. Describing this as a change in ##\alpha## relates that "real" change to the physically meaningful dimensionless constant in our models.
Likes Sorcerer, m4r35n357, Dale and 1 other person
  • #43
  • #44
Almost. It means that the value of c cannot change in the current SI units. I could make a different system of units whose unit of length in meters is a function of time and c would change in those units.
Yes.
If the fine structure constant is changed then the measurements will be physically different. A pulse of light from a Cesium clock would take a different number of oscillations to cross the same number of atoms in a rod.
This is incorrect, even with commonly used unit systems. Take, for example, SI units and CGS units. The SI unit of charge, the coulomb, is not a constant multiple of the CGS unit, the statcoulomb. The SI system treats the coulomb as a base unit with its own dimensionality while CGS treats the statcoulomb as a derived unit based only on the gram, centimeter, and second.
Buzz Bloom said:
I assume a suitable device which measures ...
The raw measurements obtained from this device depend only on the value of the fine structure constant
What I would mean by it is that the outcome of a physical measurement depends on the fine structure constant, not the speed of light. That includes measurements purportedly designed to measure the speed of light.
Likes Buzz Bloom
  • #45
Buzz Bloom said:
I am now curious as to whether this phenomenon also applies to other unitless constants.
The same reasoning I described would apply to any unitless constant.
Buzz Bloom said:
αG = (me/mP)
Note that, while this ratio is indeed dimensionless, the Planck mass itself is not; and if you try to construct a field theory for gravitation, the coupling constant you end up with in that field theory, the analogue of ##\alpha## for electromagnetism, is not dimensionless; it is in fact the inverse Planck mass squared (in "natural" QFT units, in which ##c = \hbar = 1##). Many physicists have speculated that this indicates that what we know of as gravitation is not really a fundamental interaction; that it "emerges" from some other underlying theory, in which there is a coupling constant that is dimensionless.
This same sort of issue appears in the Standard Model of particle physics, where (in the low energy version that we use to analyze experiments we can actually do) there has to be at least one constant with units of mass. This is usually taken to be the Higgs mass, and the other masses are given as dimensionless numbers times the Higgs mass. The currently accepted explanation for this is that the Higgs mass is emergent from spontaneous electroweak symmetry breaking; at high enough energies (as in the very early universe, before electroweak symmetry breaking occurred), all of the Standard Model fields are massless.
Likes Buzz Bloom
  • #46
This does not explain why there is one dimensionful parameter in SM.
However you slice it, there is one explicitly dimensionful constant in SM Lagrangian: the constant coefficient at Higgs quadratic term. Its value is ~88.45 GeV squared (= Higgs mass squared / 2)
  • #47
Yes, there is, but it's not correct to just say it's the Higgs quadratic term.
In the low energy Lagrangian (the one that describes the SM at energies well below the electroweak symmetry breaking energy), yes, there is a Higgs quadratic term with coefficient ##m_H^2##. Here ##m_H## is based on the vacuum expectation value of the Higgs field.
In the high energy SM Lagrangian, however, the Higgs boson does not have a mass; electroweak symmetry is not broken and the vacuum expectation value of the Higgs field is zero. In this Lagrangian, there are no mass terms anywhere; all the fields, including the Higgs (which has four degrees of freedom in this Lagrangian, not just one), only have kinetic terms, not quadratic mass terms.
What the SM cannot explain is why the Higgs field well below the electroweak symmetry breaking energy takes the particular vacuum expectation value it does. That is really the dimensionful parameter that the theory cannot derive from something else but has to put in by hand.
  • #48
In that regime all of the coupling constants are dimensionless?
  • #49
As I understand it, yes, that's the case.
  • #50
PeterDonis said:
In the high energy SM Lagrangian, however, the Higgs boson does not have a mass; electroweak symmetry is not broken and the vacuum expectation value of the Higgs field is zero. In this Lagrangian, there are no mass terms anywhere.
I never saw it. Where can I see the high energy SM Lagrangian?
IIRC in general Lagrangian should contain all terms compatible with postulated symmetries of the theory. A quadratic term of Higgs field is allowed. Why is it absent in high energy Lagrangian?
