What's different on electron level when voltage is higher?
  • Context: Undergrad
  • Thread starter Thread starter kraku
    Electron Voltage
The discussion revolves around the behavior of electrons in a circuit when the voltage is increased, exploring the relationship between voltage, current, and electron dynamics. Participants examine concepts related to power, kinetic energy, and the effects of electric fields on electron movement, with a focus on theoretical and conceptual implications rather than practical outcomes.
  • Some participants propose that voltage can be thought of as a measure of energy per charge, suggesting that higher voltage leads to different behavior of electrons even if the current remains constant.
  • Others argue that increasing voltage increases the electric field, which in turn increases the kinetic energy of electrons, potentially leading to higher speeds.
  • A later reply questions whether higher voltage means electrons move faster or if they simply reach a certain speed more quickly, drawing analogies to bulldozers and hills to illustrate energy concepts.
  • One participant notes that electron energy is proportional to voltage, while speed is related to the square root of voltage, but cautions that electron speeds in circuits are generally low.
  • Another participant highlights that the electric field's effect on kinetic energy is significant primarily in a vacuum, while in a conductive material, electrons experience collisions that limit their effective speed.
  • Concerns are raised about the interpretation of voltage and drift velocity, with some clarifying that drift velocity is directly proportional to the electric field rather than the square root of voltage.
  • Discussion includes distinctions between electron flow in resistive circuits versus space charge devices, emphasizing the complexities involved in understanding energy transfer in different contexts.
Participants express multiple competing views regarding the relationship between voltage, electron speed, and kinetic energy. There is no consensus on the precise implications of voltage changes on electron behavior, and several interpretations coexist within the discussion.
Some statements may oversimplify complex interactions between voltage, current, and electron dynamics. The discussion touches on various models and assumptions, including the behavior of electrons in different materials and conditions, which may not be universally applicable.
kraku
I'm trying to form a mental image what's happening with the electrons when you think of the following equation:
Power = volts*amperes
volts = joules/coulomb
amperes = coulomb/second
Amperes I understand that they tell you how many electrons go through a certain point every second.
But when I look at the volts, it says "joules/coulomb"? This indicates that the electrons in the circuit can somehow behave differently or be different. If I change the volts but the amperes stay the same (ie. same amount of electrons running through the circuit), how can the electrons cause different behavior if they have the same charge and (I assume) same speed?
Do the volts describe some kind of power by which the electrons are forced forward, even though with their regular speed. An analogy to this would be a bulldozer vs. human pushing an object at the same speed: bulldozer has much more power behind it's movement and doesn't stop easily when it hits obstacles.
What's going on here? What are the electrons doing differently when the voltage is higher?
A better analogy would be that volts are like height when we're pushing the electrons uphill (or letting them roll downhill). If the hill is twice as high, it will take twice as much energy (Joules) to push the same amount of charge (Coulombs) up the hill (or twice as much energy will be released if we let the same amount of charge roll downhill).
Amperage is proportional to the number of electrons per unit time.
Voltage is related to the kinetic energy of each electron - increasing the voltage in the circuit increases the electric field at the electron, increasing its acceleration within that field and so increasing its kinetic energy.
@pumila:
With kinetic energy do you mean that the electron moves faster and faster or that it quickly reaches a certain speed but is harder to slow down like described in my bulldozer analogy?
So basically with higher voltage the electrons just move faster? Does this mean that voltage transformers "fling" the electrons with higher/slower speed along the electric circuit?
Electron energy is proportional to the voltage, and speed to the root of voltage.
Higher voltages 'fling' electrons faster - but bear in mind that electron speeds in most circuits are in fact quite low.
Careful, there is some near misinformation in this thread.
The electric field only has a significant effect on KE of an electron when in a vacuum, as in a CRT. In a circuit where the mobile electrons are part of an electron gas they have a very high thermal velocity, thus a high KE, but they move very slowly under the influence of the E-field. Their energy is lost by the frequent collisions (actually near collisions) with other electrons and the metallic crystal structure. This is the heat generated due to current flow.
It seems there have been some potentially misleading statements in this thread. There is multiple things that can be meant by voltage, but let's concentrate on the electrostatic potential, also known as the Galvani potential. This is defined as the line integral of the electric field.
It is wrong to suggest the electron drift velocity is proportional to the square root of the applied voltage. Consider a section of wire with constant conductivity, with voltage V across it. The E field would be V/d, and the drift velocity is directly proportional to E, and thus directly proportional to the applied voltage V.
I think it is misleading to claim the voltage is generally related to the electron drift velocity or the kinetic energy of electrons. We might consider a capacitor, where there are two parallel plates, one with a positive charge and one with negative charge. We could assume that all the charge has zero kinetic energy and there would still be a voltage difference between the plates.
An electron flow through a resistive circuit component is different to electron flow in space charge devices. In the former you will get a balance speed where the kinetic energy increase from the driving voltage is balanced by the kinetic energy loss from interaction with the conducting matrix. In the latter there is no such kinetic energy loss.
Sorry if I seemed to oversimplify things but a complete answer is several chapters long.
Thinking about it, the originator is more likely interested in the effects within a resistor, so my reply should probably be ignored - just been doing a lot of crunching with low energy electron beams so took that context. I think there is also a difference in approach - I would take the emf as the source energy and see how the energy changed, to thermal in a resistor, staying as electric field energy in a capacitor, or to magnetic energy in an inductor. Never mind semiconductors or space charge devices, it gets too complicated. The inductor presents some challenges - Feynman (in his chapter on electromagnetic inertia) and others rejected the idea of electromagnetic inertia, so we treat the kinetic energy separately from magnetic field energy (must be both as current is flowing) but then we need to know where the induced magnetic field energy of the standalone electron comes from to add to the extended magnetic field energy of inductor to close the equation and Feynman is silent on this. So the only way is to cheat and treat the total induced magnetic field energy as an enhanced kinetic (inertial) energy which seems to work in practice as a mathematical wheeze although it is in violation of Feynman et all in terms of the model. At least the equations can be closed. But there are probably several other approaches, let me know if you know one, I am collecting them at moment.
  • · Replies 22 ·
  • · Replies 19 ·
  • · Replies 28 ·
  • · Replies 38 ·
  • · Replies 16 ·
53K
