Whats the difference between recursive formula and general term?
The discussion clarifies the distinction between recursive formulas and general terms in sequences. A recursive formula, such as Tn = Tn-1 + 2 with T1 = 8, defines each term based on the previous one. In contrast, a general term, exemplified by tn = 3n + 1 for the sequence 1, 4, 7, 10, provides a direct expression for any term without referencing prior terms. The general term is preferred for efficiency, especially when calculating distant terms like the 100th term.
  • Understanding of recursive sequences
  • Familiarity with general term expressions
  • Basic algebraic manipulation
  • Knowledge of sequences and series
  • Study the differences between recursive and explicit formulas in sequences
  • Learn how to derive general terms from given sequences
  • Explore the application of recursive formulas in programming
  • Investigate the efficiency of recursive versus non-recursive algorithms
Students, educators, and anyone interested in mathematics, particularly in understanding sequences and their representations.
supernova1203
To solve this question i came up with what i think is the recursive formula, the question is in the attachment, the recursive formula i came up with is
Tn=tn-1+2 when t1=8
using the formula i can solve the questions but then it asks me to come up with a general term as well...what is the difference between the recursive formula and the general term? Are they the same thing as i think they are?
When you're asked to find the general term, you are asked for an expression that usually involves variables. This general term can be defined recursively or non-recursively. For instance, if you have a sequence defined as follows:
1, 4, 7, 10, ...
1 is the 1st term (or t1).
4 is the 2nd term (or t2).
7 is the 3rd term (or t3).
10 is the 4th term (or t4).
I want to find the nth term of the sequence, or tn. I note that each successive term is 3 more than the previous, so I could define it recursively as thus:
tn = tn-1 + 3, with t1 = 1
Or I could define it non-recursively, which I think is the better way to go:
tn = 3n + 1
I like the 2nd way better in this case (and in your problem), because you're not required to find the previous terms. Say you want to find the 100th term. It will be quicker to use the non-recursive formula.
1, 4, 7, 10, ...
tn = 3n + 1
ah... ty :)
